Electrical Circuit Questions
San Antonio, TX
Would anybody care to answer the questions?
Circuit 1
Circuit 2
An ideal closed switch or un-blown fuse has zero resistance, thus zero volts for V2 and V3 in the first circuit.
Circuit is working correctly so we can assume these:
V1 Battery: charged = 12 volts. Of course a real battery is not exactly 12 volts.
V2 Fuse: not blown = zero volts.
V3 Switch: closed = zero volts
V4 Bulb: not burnt out = gets battery voltage minus the drop across the resistor, so 6 volts.
In circuit 2, the switch is open, so the entire battery voltage will appear across the switch (V3). Everything downstream of the switch is turned off, zero volts.
When ah were a lad, we 'ad to doo ower OWN 'omework.
Tell that te kids today, they'll not believe yoo.
Yes that looks like a good answer to me and well explained. Nice work.
I'll just add that the assumption is an ideal volt meter that offers infinite resistance, so it doesn't steal any voltage when taking a measurement.
+1
Circuit 1
Looks like V4 is reading to ground.
Bulb condition does not matter.
Circuit 1
And picture two would be a dead short to ground when the switch is closed.
nope 'cuz V4 is a sample point not a load.
Then they used the wrong symbol and should show the volt meter in there. Unless it was so described in the original paper.
Agreed. (Ducked, are you one of the four Yorkshiremen?)
No.
Ideal Volt meter has infinite internal resistance/V. Otherwise it'll load down the CUT and give a false reading.
