2018 Ford 2.0 EcoBoost
by mpgo4th - 02/28/20 03:30 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
117 registered members (4WD, 762fermeandyou, 28oz, 01rangerxl, 2K2AcuraTL, 77GrandPrix, 6 invisible), 2,236 guests, and 16 spiders.
Topics302,048
Posts5,207,999
Members70,825
Pennzoil Platinum D1G2 5w30 #4718932 04/06/18 08:39 PM
W
webfors Offline OP
W
They have added a little marketing fluff on the front of the bottle.
https://www.dropbox.com/s/3t361zv10i1ngyb/2018-04-06%2020.52.43.jpg?dl=0
Does anyone have a link to the new D1G2 PP spec sheet?
17 Cadillac ATS 2.0T, Edge D1G2 5w30, Champion COS10590
17 Dodge GC, VWB 5w30, Mopar MO-349
18 DL1000XT, Valvoline Dino 20w50, Suzuki OEM OF
Small engines; RT5 10w30
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4718958 04/06/18 09:14 PM
W
webfors Offline OP
W
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4718979 04/06/18 09:49 PM
W
webfors Offline OP
W
What's with the drop in flash, decrease in hot viscosity, but worse cold pumping numbers?
http://www.pennzoil.com/en_us/products/f...c-Motor-Oil.pdf
http://www.shell-livedocs.com/data/published/en/c18eb3e5-7a5f-4471-88a5-1291276dea89.pdf
I'm looking forward to seeing PP D1G2 UOAs.
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4718993 04/06/18 10:19 PM
G
Gokhan Offline
G
I've just calculated the A_Harman index. (See calculation of the A_Harman index.) Closer to 1.000 is better. 1.000 means no VII.
PPPP 5W-30 assuming HTHSV = 3.1 cP: A_Harman index = 0.931
PPPP 5W-30 dexos 1 Gen 2 assuming HTHSV = 3.1 cP: A_Harman index = 0.975
Both are solid oils with little VII but PPPP dexos1 Gen 2 seems exceptional. Even if I assume HTHSV = 3.0 cP, I get A_Harman index = 0.944, larger than the non-dexos1-Gen-2 formulation.
dexos1 Gen 2 requires thicker base oil for protection of the timing chain in TGDI engines. (See Do you think that's thick oil? Think again?) So, they used a thicker base oil (larger CCS) and less VII to achieve similar KV100 viscosity for the blended oil for similar protection of the bearings but greater protection of the valvetrain, timing chain, rings, and so on.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 4,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Pennzoil Platinum D1G2 5w30 [Re: Gokhan] #4719135 04/07/18 05:39 AM
W
webfors Offline OP
W
Interesting! I haven't spent much time catching up on the latest knowledge trends at BITOG.
So there should be less focus on KV100 viscosity, and more focus on base oil viscosity, with a desire for less VII. I recall a day when oil with very high VI were the jewel of BITOG. Times are a changing...
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4719267 04/07/18 07:59 AM
CT8 Offline
The oil seems to be on the thin side of the 30 wt
2015 F150 2.7
2018 F350 6.2
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4720026 04/07/18 09:04 PM
ChrisD46 Offline
*I'm almost 4,000 miles in on my last change of PPPP 5W30 DEXOS 1 Gen 2 in my 2017 non - turbo 2.4 L GDI Sonata . I'm not sure how much extra protection I get since I have non - turbo GDI ? I will say it runs smooth with zero consumption (low NOACK ?) as compared to factory fill and syn blend the dealer put in (now have 14K miles on the vehicle). I believe this new Pennzoil has to be as good (or better) than any other WM bought oils .
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Pennzoil Platinum D1G2 5w30 [Re: ChrisD46] #4720103 04/07/18 11:19 PM
O
OilUzer Offline
O
Originally Posted By: ChrisD46
*I'm almost 4,000 miles in on my last change of PPPP 5W30 DEXOS 1 Gen 2 in my 2017 non - turbo 2.4 L GDI Sonata ...
I use the same oil in our 2.4 L DI Tuscon (same engine I think) and its running quiet according to my wife. I think I had to add a little oil maybe 6 fl oz or less in almost 6K miles. I didn't have to add oil since the oil was just a little from top mark but I like to keep it full ... the car has 60K + on it.
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4720161 04/08/18 03:38 AM
O
OilUzer Offline
O
when I searched for 10W-30 I could only find the 2014 document (pdf). yours is 2017 ...
I went to your site above to get the 10W-30 info and it wants me to sign in and there is no option to create an account!
can you provide the link for 10W-30 also.
Thanks
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4720164 04/08/18 03:47 AM
SR5 Offline
It's also still Euro ACEA A5/B5 rated, which is a good spec and not all oils carry it.
It's KV100 at 9.8 cSt is so close to the 20 grade / 30 grade border that I would be tempted to use it in both 5W30 and 5W20 applications. Even 0W20 if not super cold.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Pennzoil Platinum D1G2 5w30 [Re: webfors] #4720167 04/08/18 03:52 AM
O
OilUzer Offline
O
There is no NOACK in the datasheet. I have the old (2014?) NOACK from another thread.
Does anyone have the 2017 or 2018 NOACK for the 5W-30 and 10W-30?
Re: Pennzoil Platinum D1G2 5w30 [Re: OilUzer] #4720286 04/08/18 07:23 AM
W
webfors Offline OP
W
Not sure anyone knows for sure. It's definitely not published by Shell.
Re: Pennzoil Platinum D1G2 5w30 [Re: OilUzer] #4721124 04/09/18 01:51 AM
dailydriver Offline
I'd also like to know this info, as well as the starting TBN. wink
2016 Ford Fiesta ST 17K miles
Ravenol REP 5W-30
Fram XG3600 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Pennzoil Platinum D1G2 5w30 [Re: dailydriver] #4721214 04/09/18 05:59 AM
V
Virtus_Probi Offline
V
I believe that SOPUS told us that their NOACK loss test methodology is so poor that they're ashamed to give us the results.
OK, I stretched the truth slightly there...
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: Pennzoil Platinum D1G2 5w30 [Re: OilUzer] #4721245 04/09/18 06:48 AM
ChrisD46 Offline
5K miles on an OCI is about all I would want to drive on any oil (even preferred synthetic) with a DI engine (5K OCI is my limit in mixed driving) ...
