Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
34 registered members (Brad_C, bbhero, alcyon, 5 invisible), 536 guests, and 60 spiders.
Topics286,442
Posts4,908,263
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Effect of Oil Viscosity on Oil Film Thickness #4719728
04/07/18 05:22 PM
04/07/18 05:22 PM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
Hi Friends,
This is not another "Which is better, thin or thick oil?" thread. As there are tons of discussions about it in this forum smile
But i am a little confused, because Shell's research has different results compared with other researches. (Likely i have missed the point.)
Shell Research:
Quote:
The assumption that lower viscosity lubricants automatically give rise to thinner oil films in
key lubricated contacts in a gasoline engine is also open to question, particularly in the case
of piston rings. Laser Induced Fluorescence measurements have found that, in a Nissan
gasoline engine, the mid-stroke top ring oil film thickness was greater for an SAE-5W/20
lubricant than it was for an SAE-15W/40 lubricant. These effects were also observed in our
laboratory for monograde lubricants. Similar effects have been observed by S.L. Moore of
BP36. Figure 20 illustrates the observations. A qualitative explanation of such an effect
could be as follows : There are two routes by which lubricant reaches the top piston ring.
Route #1 (the “conventional” route) is that oil is left on the liner by the passage of the
preceding ring. The higher the oil viscosity, the larger will be the oil film thickness left on
the liner. Route #2 involves oil being transported to the top piston ring via the ring gaps
(such flows have been observed by Nakashima et al37), and this is thought to favour lower
viscosity lubricants. The precise balance between oil transported by the two routes will
determine whether the oil film thickness under the top ring is greater for a lower viscosity
oil or not.
However, another research shows that OFT is higher with 20w40 than 10w40
Quote:
Comparison of the performance of both SAE
10W40 and SAE 20W40, showed that the increase of
frictional power losses and oil film thickness in case of
SAE 20W40 was strongly related to its high viscosity
compared with SAE 10W40. The high viscosity of the
SAE 20W40 was substantially responsible for the
increase in shear stress in oil film, and could be a
strong reason for the increase in hydrodynamic friction
with the use of the SAE 20W40 oil.
Another research:
Quote:
The oils were compared with each other at different loads and speeds as depicted in
Figure 4.29 and Figure 4.30. Oils 026A, 001C, 004B and 001A which have similar
viscosity give similar OFT and oil AW004 which has the lowest viscosity of all oils
shows a smaller OFT, as expected. On the other hand, oil 097A has the highest OFT as
it has the highest viscosity.
Source:
https://priuschat.com/attachments/fuel-efficient-motor-oil-technical-article-pdf.11772/
https://www.researchgate.net/publication...bustion_engines
http://openaccess.city.ac.uk/11916/1/Oil%20Transport%20in%20Piston%20Ring%20Assemblies.pdf
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: NICAT] #4719807
04/07/18 06:34 PM
04/07/18 06:34 PM
workbench CZ-USA KS KC
Marco620 Offline
Marco620  Offline
Interesting read. Thank you for posting.
15' Civic 1.8 i-vtec 222,222+ mi Redline oil/cvt fluid & Archoil9100
Just say no to drugs, union made cars and amsoil.
Son of a Navy Corpsman. Support vets!
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: NICAT] #4719831
04/07/18 07:02 PM
04/07/18 07:02 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
I agree with Shell.
This
Quote:
The high viscosity of the SAE 20W40 was substantially responsible for the increase in shear stress in oil film, and could be a strong reason for the increase in hydrodynamic friction with the use of the SAE 20W40 oil.
is discussing the fact that higher viscosity oils result in higher hydrodynamic friction and shear stress, a different topic. The thicker the oil, the more HP you're putting into the oil to shear it and the higher the oil temp.
OFT and MOFT are highly dependent on base oil types and additives. I can can have a low viscosity finished oil show good OFT and MOST by the selection of different base oil viscosities, base oil types, and vII's used.
As for the third article, what was the Delta OFT between the two oills?
Furthermore, I doubt all three studies used the same type of engine or test equipment, loads, etc.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: NICAT] #4719851
04/07/18 07:20 PM
04/07/18 07:20 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
The Shell quote gives two of the mechanisms potentially involved in the piston ring situation, and suggests that thicker oil films can develop in that situation with thinner oil because it gets past the rings in greater volume, i.e. there is more flow.
As I read it, this is to some extent a special case, and does not conflict with the general positive relationship between viscosity and film thickness, where the supply of oil is not limited.
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: NICAT] #4719861
04/07/18 07:31 PM
04/07/18 07:31 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: NICAT
Shell Research:
Quote:
Laser Induced Fluorescence measurements have found ....
I would like to know a little more of how this testing method functions.
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: NICAT] #4719871
04/07/18 07:37 PM
04/07/18 07:37 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Rings are not my primary concerns Bearings and cam lobes, then rings. hide
Thick oil is better grin2
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: NICAT] #4719917
04/07/18 08:13 PM
04/07/18 08:13 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
I've replaced far, far more rings than bearings or camshafts because of wear....
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: Silk] #4719963
04/07/18 08:58 PM
04/07/18 08:58 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I was just going to say that rings tend to wear out more than most other lubricated parts.
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: Silk] #4720051
04/07/18 10:37 PM
04/07/18 10:37 PM
MN
oil_film_movies Offline
MN
Yer Lord of the Rings! Shot in NZ.
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: Ducked] #4720110
04/08/18 01:04 AM
04/08/18 01:04 AM
Down Under
SR5 Online content
SR5  Online Content
Down Under
Originally Posted By: Ducked
The Shell quote gives two of the mechanisms potentially involved in the piston ring situation, and suggests that thicker oil films can develop in that situation with thinner (lower viscosity) oil because it gets past the rings in greater volume, i.e. there is more flow.
I think you nailed it Ducked. (Slight add to above for clarity)
Quote:
Route #2 involves oil being transported to the top piston ring via the ring gaps, and this is thought to favour lower viscosity lubricants.
This is one of the special cases where flow is one of the limiting effects. For general engine lubrication, in a moderate / warm temperatures, the constant displacement oil pump gives the same flow for all reasonable viscosities. So normally flow is not a limitation. Here the small gap in the rings allows more low viscosity oil through, and given that the ring space is not saturated and can take more, then this does help.
Very interesting point.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: Linctex] #4720113
04/08/18 01:33 AM
04/08/18 01:33 AM
Azerbaijan
NICAT Offline OP
NICAT  Offline OP
Azerbaijan
https://www.dantecdynamics.com/measurement-principles-of-planar-lif
My car has over 1.000.000 km on it, and both camshaft and crankshaft were in great condition during the rebuilt. Only replaced the rings.
Not sure about bearings, but they were not causing any symptoms smile Just replaced them also, since they were cheap.
Cheapest mineral oil was used the whole time.
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: NICAT] #4720119
04/08/18 02:18 AM
04/08/18 02:18 AM
Balearic Islands , Spain
FordCapriDriver Offline
Locally here in Spain a company called Cepsa ( major Spanish oil company ) makes a Mineral 20W-40 API SF/CF oil, it has quite high Zddp and is very cheap and i've been tempted to try it in the Capri for some time and see how it likes it compared to 20W-50 smile
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: NICAT] #4720120
04/08/18 02:21 AM
04/08/18 02:21 AM
Down Under
SR5 Online content
SR5  Online Content
Down Under
That's great 1 million KM on cheap mineral oil.
May I ask a few questions?
- what car / engine
- what oil viscosity (eg 15W40)
- what oil specification (eg API SL)
- what oil change interval (OCI)
Thanks in advance.
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: SR5] #4720151
04/08/18 04:08 AM
04/08/18 04:08 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Yeh, sorry. "Thinner oil" was definately ambiguous in that context.
Not happy about this.
Doesn't mesh with my "thicker is better" mantra and may contra-indicate my SAE40 / Delvac 15W40 blend.
Re: Effect of Oil Viscosity on Oil Film Thickness [Re: NICAT] #4720154
04/08/18 04:13 AM
04/08/18 04:13 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
But there's other Shell papers that show increased oil consumption with thicker oils, and the rings being less able to scrape them off.
Rings are the area where I've come across diametrically contradictory studies
Page 1 of 3 1 2 3
