4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
78 registered members (4WD, 2010Civic, Agnosto, AlaskaMike, AdditiveOCD, 8 invisible), 1,482 guests, and 68 spiders.
Topics286,042
Posts4,901,388
Members67,551
Most Online2,967
Mar 10th, 2019
Bad O2 or Cat? I have data to help determine. #4719619
04/07/18 03:35 PM
04/07/18 03:35 PM
San Antonio, TX
Datarock Offline OP
Datarock  Offline OP
San Antonio, TX
I have 2008 Nissan Versa Hatchback. The MIL has recently come on and it is showing a P0240 (Catalyst System Efficiency Below Threshold Bank 1).
I know it's sometimes hard to diagnose the correct reason for this code so I have provided some data that I hope can assist with pointing to the right component that is bad. I am thinking it's the bank one O2 Sensor but would like a second opinion.
Car runs great and I have not noticed any difference in MPG or performance.
2017 Kia Forte S - PP 5W-30
2018 Kia Niro Hybrid - Magnatec 5W-30 (Will be switching to PP 5W-20 next change)
Re: Bad O2 or Cat? I have data to help determine. [Re: Datarock] #4719626
04/07/18 03:41 PM
04/07/18 03:41 PM
USA
mk378 Offline
mk378  Offline
USA
You need to look at the time graph of both sensors. If they are both swinging at about the same rate, that means the sensors are OK but the cat is not doing much. If you see varying voltage from both sensors, a P0420 is most likely the cat. Also make sure there are no exhaust leaks.
Re: Bad O2 or Cat? I have data to help determine. [Re: Datarock] #4719630
04/07/18 03:43 PM
04/07/18 03:43 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I had a car that would throw that code, I kept resetting it and eventually it went away.
I thought it was P0420, not P0240? Perhaps I am mistaken.
It could be the rear 02 or the cat. I think you need a scan tool to observe the signal from that rear 02 sensor to see if it is lazy or malfunctioning.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Bad O2 or Cat? I have data to help determine. [Re: Datarock] #4719638
04/07/18 03:48 PM
04/07/18 03:48 PM
ME
eljefino Offline
eljefino  Offline
ME
It seems weird that the O2 sensor diag is not a prerequisite for the cat. I'd definitely fix that first so its I/M can "click in".
Re: Bad O2 or Cat? I have data to help determine. [Re: Datarock] #4719686
04/07/18 04:44 PM
04/07/18 04:44 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
I have never heard of an O2 sensor after the cat going bad, ever.
Re: Bad O2 or Cat? I have data to help determine. [Re: Datarock] #4719687
04/07/18 04:45 PM
04/07/18 04:45 PM
VA
thastinger Offline
thastinger  Offline
VA
can you log your short term fuel trims and O2 voltage? or at least see them? Those values should be changing constantly, if the O2 voltage never changes then it is bad
Re: Bad O2 or Cat? I have data to help determine. [Re: Datarock] #4719771
04/07/18 05:57 PM
04/07/18 05:57 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
If you don't want to buy a cat, and emissions inspection in your area are lax, consider a new post cat O2 sensor, with a spacer attached
All of a sudden, it'll be 92% efficient again
Now, if it's broken apart internally, or clogged to the point where your down on power or overheating, track down the misfire that killed the old one, and replace it
Also consider using a better OBD app
This data layout gave me eye cancer, Torque or Torque pro is well worth the $3, then you could properly graph the O2 sensor voltage
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Bad O2 or Cat? I have data to help determine. [Re: Datarock] #4719772
04/07/18 05:57 PM
04/07/18 05:57 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Whats the misfire and fuel fail? Check the misfire count.
Re: Bad O2 or Cat? I have data to help determine. [Re: Datarock] #4719848
04/07/18 07:19 PM
04/07/18 07:19 PM
CZ factory 🏭 KC KS
Marco620 Offline
Marco620  Offline
CZ factory 🏭 KC KS
How many miles on car? I had a weird smell before mine went out.
15' Civic 1.8 i-vtec 221,000 mi 0w20 Redline/Redline CVT/Archoil9100/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/87 E0 fuel/Yokohama
Son of a Navy Corpsman. Support vets!
Re: Bad O2 or Cat? I have data to help determine. [Re: Linctex] #4719873
04/07/18 07:40 PM
04/07/18 07:40 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
Bad oxygen sensors have their own separate codes.
I have
4th gen Maxima, got a code associated with the bank 1 sensor 2 sensor, which is the post-cat oxygen sensor. Don't remember the code, but I remember it translating to the sensor after the cat. I replaced that sensor, and the code never came back. Car has 280k now, had about 260k when the code came on
Re: Bad O2 or Cat? I have data to help determine. [Re: Datarock] #4719912
04/07/18 08:10 PM
04/07/18 08:10 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Replace the failed O2 snsor. Cheaper and easier than the cat. A meter is constantly in motion. If it doest change in the blink of an eye between .2 and .9 V, change it.
Thick oil is better grin2
Re: Bad O2 or Cat? I have data to help determine. [Re: andyd] #4720023
04/07/18 09:55 PM
04/07/18 09:55 PM
Portland, OR
pdxglocker9mm Online content
pdxglocker9mm  Online Content
Portland, OR
Graphs were one of the tools i used to diagnose bad cats.
I would overlay the pre and postcat sensor readings on the scan tool.
If the post cat matched the pre cat graphing basically 75% of the time that was a good indicator of bad cats. We called it ghosting
If the pre and post cat graphs were converse or basically opposite that ususally meant a good cat.
If the post cat or pre cat sensor was a flat line and or very slow to switch but you could see fuel trims rise and fall that usually meant bad sensors.
