Originally Posted By: fdcg27
The earth currently supports an industrialized population of more than three times that and a multiple of that industrialized population in developing countries, maybe more accurately called by that non-PC term the third world.
This is all probably sustainable.
What is unsustainable is for the masses of India and China to adopt EU and American lifestyles, yet this is what they aspire to, as do their governments.
Everyone wants what they see others have (within reason)....and t's unfair of us in privilige to deny them.
Read this book a long time ago...
https://www.clubofrome.org/report/factor-four-doubling-wealth-halving-resource-use/
It's well worth the time taken.
If we follow the economically "rational" approach to the future, for resource consumption and energy, we get the wrong answers.
* Goods that don't last, and take the shortest possible time to get to landfill while still being considered worth buying
* inefficient use of energy across the board.
Like I posted previously, the exponential growth of energy use is the issue, not population...trying to match the curve with renewables is a fool's errand.
An example from the book, and as a Mechanical Engineer, I've been at all facets of this part of the chain.
* design engineer designs a heat exchanger.. The codes have fouling factors, and he applies these. Designs for specified heat rejection with 10% of the tubes plugged after 25 years of service. The kit needs flow X at temperature Y
* the guy writing the supply spec for the process will look at that, and knowing that pumps wear and degrade over time, will give a +10% margin on the specified pump, and insert a performance test clause with penalties to ensure that the needs are met.
* Bidder gets the spec, notices the performance test requirements, and has two paths...custom trimmed impeller to meet the spec, or next size up pump, guaranteed to meet the spec comfortably...latter is easier and cheaper, plus he has remedies if his pump supplier doesn't meet target.
* Customer, knowing how expensive inventory is, doesn't want custom impellers sitting on a shelf forever, wants an off the shelf solution..prefers the latter too...for plant standardisation, they may in fact specify that the pump needs to be same as the handful already on site.
So the pump is 1.1 X 1.15 bigger than it needs to be, and even THAT was allowing a 10% plugged future state....1.1 x 1.15 x 1.1 ~ 1.4...the pump is 1.4 times bigger than it needs to be.
While the performance test is passed, the process is unstable, so that discharge valves are throttled back, or (better) an orifice plate installed.
For the next 25 years, that pump is now using 40% more energy than it has any GOOD reason to.
It's just our "get it done for the least cost" drivers that push the behaviours.
