B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
106 registered members (aquariuscsm, AdditiveOCD, Arob, 53' Stude, 13 invisible), 2,338 guests, and 44 spiders.
Topics296,878
Posts4,960,710
Members66,987
Most Online2,688
Jan 19th, 2019
76 K10 Chevy 350 Delvac 15w40 2.5 years 1,100 mi #4719410
04/07/18 10:48 AM
04/07/18 10:48 AM
Jacksonville, FL
FlyNavyP3 Offline OP
Jacksonville, FL
First analysis on the 350 in my 1976 K-10 Chevy truck. The 350 is not original to the truck but is a 1976 350 from some sort of GM Car with an automatic according to the block stamping. I've owned the truck for a little over three years. Had exceptionally low oil pressure when I purchased it and unknown oil from a Valvoline instant oil change judging by the filter I removed when this oil was installed. Immediately prior to this oil change I had the oil pan off to inspect rod and main bearings (all checked out ok) and I installed a Melling M-99HVS oil pump (for those not familiar this is a BBC pump made to fit a SBC that was used in Z-28 engines) in addition to the new oil pump a 28,000 GVW oil cooler was installed and plumbed with -10 AN line with a thermostatically controlled Permacool sandwich adapter. Oil pressure with the new oil pump is now excellent for an old SBC. Oil fill was 4 quarts of Mobil Delvac 1300 15w40 CJ-4 and 2 quarts of Napa All Fleet 15w40 CI-4+, top off oil was .5-.75 quart of Valvoline SAE 30 I had laying around and open. Silicon in the UOA is probably a combination of sealant used on the 4 corners of the oil pan gasket and the new silicon rubber Fel-Pro one piece oil pan gasket and to a lesser extent from silicon sealant used on the valve cover gaskets that were replaced immediately prior to my ownership. High copper is likely due to the new 28,000 GVW copper oil cooler. Filter for this oil change was an AC Delco PF-1218 posted in the filter section. New oil in was 6 Quarts of Napa All Fleet 15w40 CI-4+ and a new Delco filter.
Enjoy!
Luke
Re: 76 K10 Chevy 350 Delvac 15w40 2.5 years 1,100 mi [Re: FlyNavyP3] #4719519
04/07/18 12:51 PM
04/07/18 12:51 PM
Jacksonville, FL
Jacksonville, FL
I forgot to mention... the blackstone comments about fuel were in response to what I wrote on the slip. The Truck has a 4bbl carb with an electric choke and frequently gets started up, backed out of the garage and shut off, then fired up and pulled back in without ever warming up, at all. I fully expected to see a huge dip in flash point and viscosity from all the partial warmups on this engine over the 2.5 years the oil was in service. Granted [censored] fuel is usually under estimated but the solid flash point indicates no huge trouble on the horizon. Oil cooler thermostat starts to open at 165 and is full open at 180F.
Luke
Re: 76 K10 Chevy 350 Delvac 15w40 2.5 years 1,100 mi [Re: FlyNavyP3] #4719575
04/07/18 01:35 PM
04/07/18 01:35 PM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
This is enough to give the PPM fanatics chest pains LOL
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: 76 K10 Chevy 350 Delvac 15w40 2.5 years 1,100 mi [Re: OVERKILL] #4719591
04/07/18 02:00 PM
04/07/18 02:00 PM
Jacksonville, FL
Jacksonville, FL
Yes it probably is. However I'm not at all concerned. It's a 1976 long block with stock steel shim gaskets still in place on the heads. Unknown service history, likely run on leaded fuel for a portion of its life on garbage (by today's standards) oil. It runs absolutely fantastic and the bearings looked great when I had the pan off (bearing clearances were good too) so what the heck run it. I have a new hydraulic roller 454 for the truck when I get around to installing it anyway.
Luke
Re: 76 K10 Chevy 350 Delvac 15w40 2.5 years 1,100 mi [Re: FlyNavyP3] #4719655
04/07/18 03:08 PM
04/07/18 03:08 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I had a 77 K10 - does yours have the NP203 "full time" transfer case?
Re: 76 K10 Chevy 350 Delvac 15w40 2.5 years 1,100 mi [Re: Linctex] #4719691
04/07/18 03:49 PM
04/07/18 03:49 PM
Texas
4WD Offline
4WD  Offline
Texas
I recall putting a conversion kit in that along with locking hubs to run 2 WD when on the road
Re: 76 K10 Chevy 350 Delvac 15w40 2.5 years 1,100 mi [Re: FlyNavyP3] #4719697
04/07/18 03:55 PM
04/07/18 03:55 PM
Texas
4WD Offline
4WD  Offline
Texas
So is this the first UOA after pumping a higher flow rate around in the old iron block?
Re: 76 K10 Chevy 350 Delvac 15w40 2.5 years 1,100 mi [Re: Linctex] #4720078
04/07/18 10:33 PM
04/07/18 10:33 PM
Jacksonville, FL
Jacksonville, FL
No, this truck has a SM465 4sp stick and a NP205 transfer case.
Luke
Re: 76 K10 Chevy 350 Delvac 15w40 2.5 years 1,100 mi [Re: 4WD] #4720079
04/07/18 10:33 PM
04/07/18 10:33 PM
Jacksonville, FL
Jacksonville, FL
Yes it is.
Luke
