The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
44 registered members (berniedd, 555, avi1777, aleneros, carlprop, Brad_C, 2 invisible), 602 guests, and 67 spiders.
Topics286,097
Posts4,902,482
Members67,560
Most Online2,967
Mar 10th, 2019
Rusty side steps #4719408
04/07/18 11:48 AM
04/07/18 11:48 AM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
What do you guys recommend for rusty black powder coated side steps? I tried using a cheap spray can of black rust paint but it didnt even last the winter.
‘19 Grand Caravan- factory fill
'13 Toyota Tundra 5.7-Idemitsu 0w-20/OEM
'08 Hyundai Elantra-Havoline 5w-30/Fram 9688
'96 Ranger R72 90hpJohnson
'03 Ski Doo REV 600 H.O.
‘01 Kawasaki KDX 220r
Re: Rusty side steps [Re: pda1122] #4719420
04/07/18 12:05 PM
04/07/18 12:05 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Same experience. Best be if you wanted to spend the money would be to have them sand blasted, then prime and paint them with rust primer and rust paint. You might even then spray them with truck bed liner if you didn't mind the look. Might might be best just to get a new set.
If you want the job done right......do it yourself.
Re: Rusty side steps [Re: pda1122] #4719425
04/07/18 12:11 PM
04/07/18 12:11 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
I'd remove them, and then either grind to bare metal, or at least get off any loose flake, ospho/phosphate etch, potentially zinc prime, then paint.
I wouldn't count on anything lasting forever if the original coating didn't last and the metal is that corrosion prone. Perhaps line x or similar...
Re: Rusty side steps [Re: pda1122] #4719672
04/07/18 04:29 PM
04/07/18 04:29 PM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
Can you protect them at all with mudflaps? Some actually don't look too bad.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Rusty side steps [Re: pda1122] #4720673
04/08/18 03:36 PM
04/08/18 03:36 PM
Clermont, Fl
007 Offline
007  Offline
Clermont, Fl
Are we talking about running boards or step tubes? If tubes the goods ones finish is warranted for life. The cheaper ones which use cheaper steel are only warranted for a year a two. Once compromised its just best to replace!
Re: Rusty side steps [Re: pda1122] #4721386
04/09/18 10:00 AM
04/09/18 10:00 AM
PimTac Offline
PimTac  Offline
I had a Ford Ranger bumper with the junk aluminum paint that peeled and bubbled. I sanded the whole thing, applied Rustoleum primer and then a flat black paint with a brush. It looked better than factory and it never showed any rust or peeling. I stepped on that bumper loading stuff in the back.
Cannot see signatures any longer so it doesn’t matter.
