White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
29 registered members (claluja, c502cid, carlprop, Black_Thunder, Blkstanger, BlakeB, 3 invisible), 851 guests, and 33 spiders.
Topics296,866
Posts4,960,379
Members66,982
Most Online2,688
Jan 19th, 2019
7.3L 4R100 E350 new to me, trans recommendations? #4719359
04/07/18 09:23 AM
04/07/18 09:23 AM
utah
dareo Offline OP
dareo  Offline OP
utah
Luck has granted me a rare E350 van with the 7.3 power stroke. Ď01 year with 252k. I have a big stash of Fleetrite Allison rated TES 295 that Iím thinking of using with a pan drop and filter. Or should I buy something else? I got the fleetrite for way less than it normally costs. Since this is such a hard to find van I want to take good care. Is the TES 295 "the best" for this? Thanks
2016 Golf Wagon 5MT, 2014 Accord Sport 6MT, 2016 GMC 1500 SLT 6.2
Re: 7.3L 4R100 E350 new to me, trans recommendations? [Re: dareo] #4719377
04/07/18 09:58 AM
04/07/18 09:58 AM
NC USA
Roadkingnc Offline
Roadkingnc  Offline
NC USA
the filter is just a screen, if the pan gasket isn't leaking, drain the pan and torque converter and refill.
The converter has a drain plug too.
Re: 7.3L 4R100 E350 new to me, trans recommendations? [Re: dareo] #4719499
04/07/18 12:38 PM
04/07/18 12:38 PM
utah
dareo Offline OP
dareo  Offline OP
utah
I finally got underneath this van and to my dismay i do not have a drain plug. Transmission seems to be dated 03, van is 01, so i'm guessing its not the first trans.
Pan is not leaking so i really don't want to take it off. I think i will just vacuum extract fluid from the top and replace once i decide what to put in.
Re: 7.3L 4R100 E350 new to me, trans recommendations? [Re: dareo] #4719539
04/07/18 01:10 PM
04/07/18 01:10 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You can just disconnect a cooler line and run it at idle until the fluid gets bubbles.
Then reconnect the line, and fill to proper level.
This only takes a few minutes.
Valv MaxLife ATF or MERCON V are probably the best choices.
Re: 7.3L 4R100 E350 new to me, trans recommendations? [Re: dareo] #4720648
04/08/18 02:07 PM
04/08/18 02:07 PM
utah
dareo Offline OP
dareo  Offline OP
utah
Thanks for the cooler line tip. That worked very well. 5 gallons of maxlife later and its done. Seems a bit smoother.
Re: 7.3L 4R100 E350 new to me, trans recommendations? [Re: Roadkingnc] #4720782
04/08/18 04:39 PM
04/08/18 04:39 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Incorrect, It should have a Felt Media filter.
2001 Chevy Camaro L92/4L80E
Re: 7.3L 4R100 E350 new to me, trans recommendations? [Re: dareo] #4720788
04/08/18 04:41 PM
04/08/18 04:41 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
The 4R100 isn't very picky on ATF, A TES-295 spec fluid is fine.
