2019 Subaru Crosstrek FB20D - Oil choices
by cluster5. 03/26/19 09:31 PM
.05 Cent haynes manual
by Jman26063. 03/26/19 09:02 PM
Pennzoil Canada Rebate
by Snagglefoot. 03/26/19 09:01 PM
Burned out blinker
by Chris142. 03/26/19 09:00 PM
Best Moly add for timing chain health?
by RichR. 03/26/19 08:53 PM
Kenmore dishwasher quit.
by Trotter. 03/26/19 08:49 PM
Urethane with integrated clear coat cure time?
by FixItDad28. 03/26/19 08:39 PM
Chevron rykon premium mv alternative?
by Framer. 03/26/19 08:12 PM
Got a bunch of new old stock oil and filters...
by dogememe. 03/26/19 07:04 PM
Right turn signal blinking super fast
by das_peikko. 03/26/19 06:55 PM
Another fun car to work on.
by Chris142. 03/26/19 06:48 PM
Equivalent LED T8/T12 tubes?
by y_p_w. 03/26/19 06:37 PM
Do you use chemicals on your lawn?
by ZZman. 03/26/19 05:21 PM
Baked Cabbage Steaks
by StevieC. 03/26/19 02:57 PM
Best Store Bought BBQ Sauce?
by Redright9. 03/26/19 02:26 PM
Hankook tire rebate
by FordBroncoVWJeta. 03/26/19 01:14 PM
Framer, Joe_Gibbs, PerryPerrister, brak132, mike001100
67635 Registered Users
79 registered members (advocate, alcyon, bbhero, 4WD, 555, 2015_PSD, 9 invisible), 1,699 guests, and 108 spiders.
Topics286,477
Posts4,909,138
Members67,635
Most Online2,967
Mar 10th, 2019
Intermediate starting issue: 00 Ford Escort 2.0L #4719088
04/07/18 04:49 AM
04/07/18 04:49 AM
usa
miteclipse Offline OP
usa
Hi,
A few months ago when trying to start, the car would crank over but not start. When I turn the key off and turn back on, the car would fire up. This happen about 2 more times over a 3 week span. I took the car to the mechanic where the problem did not replicate. Mechanic said it could be a fuel pump but said to bring it back when the issue was constant. Yesterday the issue came up again.
Any ideas on what it could be? I don't want to take the car in if the problem won't reappear while at the shop.
Thanks.
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: miteclipse] #4719101
04/07/18 05:12 AM
04/07/18 05:12 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Sounds like a marginally operating fuel pump. Someone needs to check priming and operating fuel pressure with a gauge. By working the key you are repriming and building up pressure.You might have to leave the car at the shop overnight so they can check it from a cold start. I am assuming the fuel filter has been replaced already.
The "thinking" man's friend.
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: miteclipse] #4719107
04/07/18 05:25 AM
04/07/18 05:25 AM
usa
usa
I bought the car used about 10+ years ago. I have to believe that the fuel filter has yet to be changed.
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: miteclipse] #4719147
04/07/18 07:00 AM
04/07/18 07:00 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Start by doing so basic diagnosing before starting, check for power to the ignition and pump, check grounds, etc.
This can be a pain because its intermittent and it does fire the next turn of the key. You may also be dealing with a wonky ignition switch.
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: miteclipse] #4719149
04/07/18 07:01 AM
04/07/18 07:01 AM
Brittany / Canada
Popsy Offline
Popsy  Offline
Brittany / Canada
Does it have some sort of anti-theft system?
Also +1 with fuel filter, try changing it to see if it helps.
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 AFE 0W20 | Colt Ralliart, 300V 0W40
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: miteclipse] #4719168
04/07/18 07:22 AM
04/07/18 07:22 AM
NY
Kage860 Offline
Kage860  Offline
NY
Theres a check valve built into most fuel pumps that prevents fuel from leaking back from the fuel rail into the tank while shut down. Yours is probably leaking back. So, it sounds like a fuel pump replacement will fix that. In the meantime, toggle the key a few times before you start it up to get the fuel pressure up.
2007 Jeep Liberty PP 0w-20 / Carquest Blue, 6k oci
2015 Nissan Rogue PP 0w-20 / Pronto, 5k oci
2019 Audi Q7 - Castrol 5w-40 / OEM Filter
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: miteclipse] #4719182
04/07/18 07:37 AM
04/07/18 07:37 AM
northern NY
Driz Offline
Driz  Offline
northern NY
Anyone who keeps old cars nowadays needs a fuel pump pressure tester. They are fairly cheap and essential for modern old cars. Fuel systems are the Usual Suspect with these cars. Same goes for some sort of code reader. These two things will solve many of your old car issues and the partes are expensive and painful enough that just throwing parts at problems doesn’t work anymore.
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: miteclipse] #4719207
04/07/18 08:04 AM
04/07/18 08:04 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Had this same problem with one of my old Civics-got the wiring diagram, checked relays, put the meter on the fuel pump leads whenever it did it. Futzed around with it for 2-3 weeks, finally put a fuel pump in it, never screwed up again. My rationale is, if it's an older car, it's probably bad anyway. Also never let it get below 1/4 tank on the gauge!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: Popsy] #4719479
04/07/18 01:22 PM
04/07/18 01:22 PM
usa
usa
No anti theft system
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: bullwinkle] #4719490
04/07/18 01:31 PM
04/07/18 01:31 PM
usa
usa
Gas gauge was just over 1/4 before I filled it up then the issue happened. Come to think about it the issue has only occurred when the gauge reads 1/4. I like to fill up at 1/2.
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: miteclipse] #4719747
04/07/18 05:40 PM
04/07/18 05:40 PM
Brittany / Canada
Popsy Offline
Popsy  Offline
Brittany / Canada
I meant no « code » system with a chip in the key?
since it happens with tank around 1/4, I’d double check fuel pump and fuel filter though
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: Popsy] #4719915
04/07/18 08:11 PM
04/07/18 08:11 PM
usa
usa
Ah, yea the car does not have that.
Does anyone have any tips for checking fuel pump and filter? I do have a volt meter, just not too familiar with testing.
Thanks to everyone for all the help so far.
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: miteclipse] #4721334
04/09/18 09:22 AM
04/09/18 09:22 AM
Kansas, USA
Eric Smith Offline
Eric Smith  Offline
Kansas, USA
Check your crankshaft position sensor. On the Focus you can reach it on the passenger side back of the engine, the Escort has the similar 2.0 SOHC. Try unplugging and re-plugging. Our Focus had intermittent issue's with misfiring that would be cured by turning it off and back on. My money would be on that before fuel issue.
05 Chevy 3500 (Class C RV) 62k
04 Escape 162k
02 Focus 142k
00 Dakota 91k
91 Festiva 257k .. Rust bucket
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: Popsy] #4721403
04/09/18 10:20 AM
04/09/18 10:20 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
I always figured that the Escort name plate on the car was enough of a theft deterrent.
The Motorcraft filters for these cars have a case that's stainless steel, and that s enough of a reason to prefer them. I am assuming that they would be using the same filter as my 1995 Escort.
Re: Intermediate starting issue: 00 Ford Escort 2.0L [Re: miteclipse] #4721407
04/09/18 10:21 AM
04/09/18 10:21 AM
zzyzzx Offline
zzyzzx  Offline
Do some research over the FEOA.net http://www.feoa.net
