Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
25 registered members (avi1777, AHernandez, BlakeB, Aero540T, billt460, 3 invisible), 499 guests, and 60 spiders.
Topics286,171
Posts4,903,560
Members67,572
Most Online2,967
Mar 10th, 2019
Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) #4718709
04/06/18 06:22 PM
04/06/18 06:22 PM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
Re: Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) [Re: wemay] #4718721
04/06/18 06:31 PM
04/06/18 06:31 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Very useful thanks...not that I can do anything with it.
Would love to see flashpoint.
Re: Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) [Re: wemay] #4718735
04/06/18 06:39 PM
04/06/18 06:39 PM
Kendall, FL
wemay Offline OP
wemay  Offline OP
Kendall, FL
Me either but i know we have a lot of EB owners on here. Would have loved to see Magnatec in this comparison. wink
M1HM 10W30, OEM
PPeL 5W30, OEM
Re: Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) [Re: wemay] #4718748
04/06/18 06:46 PM
04/06/18 06:46 PM
Texas
4WD Offline
4WD  Offline
Texas
I was already running 5w40 in my ecoboost over the shear (and or fuel diluted oil) business
Re: Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) [Re: Shannow] #4718755
04/06/18 06:47 PM
04/06/18 06:47 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
It's a good datapoint, and I'm 100% convinced the modern crop of direct injected, high boost engines need sufficient viscosity for long life, regardless of brand. The viscosity loss is being seen on other similar engines/brands, including the new Honda 1.5L turbo.
EDIT: I'm running 10W-30 M1 EP in my 2011 Ecoboost, and the oil is clearly not up to the task by 5000 miles.
Remarkably, some ecoboost owners are amazed that their engines use no oil what so ever, over oil change intervals well beyond the recommended interval. What they fail to realize is that a good portion of what is in the sump, is simply the less volatile components of gasoline.
Re: Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) [Re: Cujet] #4718897
04/06/18 09:02 PM
04/06/18 09:02 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I'd like to see some really GOOD lab results confirm/refute this statement.
Re: Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) [Re: Cujet] #4718909
04/06/18 09:12 PM
04/06/18 09:12 PM
Texas
4WD Offline
4WD  Offline
Texas
I just had to ask myself what I thought those torque dense 3.5L engines would be FF with across the pond
So, since I dont need 0w ... ran 5w40
It was that are spend the money on UOAs ... had seen enough of them
Re: Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) [Re: Linctex] #4718982
04/06/18 11:00 PM
04/06/18 11:00 PM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
Me too...and what do you define as the recommended interval? Ford recommends following the OLM, which at maximum is 10,000 miles. How many owners do you know going beyond 10,000 miles?
I have two UOAs with Mobil 1 5W-30 and both had sheared down to a 20 weigh oil and two Schaeffer 5W-30 that stayed in spec. However, my iron count on the M1 was better than the Schaeffer. What is worse? More wear metals or thin oil?
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) [Re: wemay] #4718995
04/06/18 11:24 PM
04/06/18 11:24 PM
'Stralia
'Stralia
Re: Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) [Re: Shannow] #4719024
04/07/18 12:14 AM
04/07/18 12:14 AM
Texas
4WD Offline
4WD  Offline
Texas
So the guy who works this the hardest saw what I saw UOA very early so I speed read past lots of reads and find him
Folks even if you have to run OEM spec oil for the first 20k and change early to feel safe wait a bit on these UOAs
No oil will stop the break in process and no owner should want to
The first 500-1000 miles is brakes, gas peddle, etc thats just the vehicle break in for the engine break in
Re: Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) [Re: wemay] #4719158
04/07/18 07:11 AM
04/07/18 07:11 AM
MA.
Camprunner Offline
Camprunner  Offline
MA.
I do know that Ford tested several eccoboost motors with used extremely depleted motor oil and ran the tar out of them! The result after tear down was the engine wear compared to fresh oil testing was insignificant the used oil showed little to no wear over the fresh oil tests.
Re: Ecoboost 3.5 V6 shearing comparo 3 oils (PU once) [Re: wemay] #4719261
04/07/18 08:52 AM
04/07/18 08:52 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Shearing or fuel dilution?
2015 Ford F150 2.7
2018 Ford F350 6.2
