Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
100 registered members (69GTX, AndyB, 97f150, Anduril, 14Accent, 240_Ed, 4 invisible), 2,087 guests, and 49 spiders.
Topics296,779
Posts4,958,714
Members66,969
Most Online2,577
Jan 14th, 2019
Fixed My Pulsating Brakes #4718678
04/06/18 05:03 PM
04/06/18 05:03 PM
MIchigan
Warstud Offline OP
Warstud  Offline OP
MIchigan
My brakes have pulsated for a while now and I've just lived with it. But recently I got a front-end alignment after I had new tires installed and now my brakes don't pulsate anymore. I wasn't aware of this...were you ?
Re: Fixed My Pulsating Brakes [Re: Warstud] #4718786
04/06/18 06:10 PM
04/06/18 06:10 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Yes, its a very common and often overlooked problem. The brakes were probably not the issue in this case, but corrosion buildup on the back of the wheels where it sits on the rotor face.
You need to clean the back of the wheels especially aluminum ones. there are a few ways of doing this depending on what tools you have available and the amount of corrosion.
I use a 2" Roloc disk on an angle die grinder but a wire wheel on a drill will do, I usually finish with a 5 or 6 inch orbital sander with a 150 grit paper on low.
Hold it dead center and just move it slightly, it ensures the mounting surface is flat. Don't forget the center hole, a small wire wheel is best for this.
A smear of never seize thinly applied with a finger will prevent it from further corrosion until the wheel is removed again.
Re: Fixed My Pulsating Brakes [Re: Warstud] #4718823
04/06/18 06:43 PM
04/06/18 06:43 PM
Michigan
ZZman Offline
ZZman  Offline
Michigan
I had the wife's tires rotated at Discount Tire and they rebalance them and do the above mentioned cleaning of the hub and wheel
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram Ultra
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Fixed My Pulsating Brakes [Re: Trav] #4719316
04/07/18 08:46 AM
04/07/18 08:46 AM
MIchigan
Warstud Offline OP
Warstud  Offline OP
MIchigan
Trav....I think the front end alignment fixed my pulsating brakes.
Re: Fixed My Pulsating Brakes [Re: Warstud] #4719569
04/07/18 01:29 PM
04/07/18 01:29 PM
Leamington, ON, Canada ..... r...
Papa Bear Offline
Papa Bear  Offline
How could that possibly be ?? ..... they are not related
2016 Dodge GC Deep Cherry 5W-30 Dino
2013 SYM Wolf Classic 150 T4 15W-40
2009 V-Star 250 Black Cherry 20W-50 Dino
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: Fixed My Pulsating Brakes [Re: Warstud] #4719639
04/07/18 02:50 PM
04/07/18 02:50 PM
ME
eljefino Offline
eljefino  Offline
ME
Wifes HHR got "pad deposits" on the rotors.
That awful car also had a bad intermediate steering shaft, and worn-out lower control arm bushings.
I could do a brake job and it would be mint for 500 miles. Then the slightest brake judder would get amplified by the shoddy front end.
Tight front end forced the brakes to do their own self-cleaning job and not get stuck in a harmonic resonance.
Re: Fixed My Pulsating Brakes [Re: Warstud] #4720295
04/08/18 07:32 AM
04/08/18 07:32 AM
OH
grampi Offline
grampi  Offline
OH
If the mounting surface was not perfectly flat when the new rotors were installed, you'd notice the pulsing brakes right away. I have pulsing brakes, but they weren't doing it right after I installed them. It came on slower over time, so I think my problem is more than likely something adhering itself on the braking surface of the rotors...
Re: Fixed My Pulsating Brakes [Re: Warstud] #4720305
04/08/18 07:44 AM
04/08/18 07:44 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I've seen pad deposits build up slowly on the rotor and cause the wobbling. Usually if you take it out and do several hard, almost lockup 50-5 mph stops and get the rotors good and hot (smoking) it will cure the problem.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Fixed My Pulsating Brakes [Re: Warstud] #4721199
04/09/18 05:26 AM
04/09/18 05:26 AM
Trav Offline
Trav  Offline
No brake work, that eliminates pad deposits and all the rest of it. They removed the wheels, balanced them and if they did it right cleaned the back of the wheels mounting area then did an alignment.
Alignment can cause or exacerbate a lot of symptoms but AFAIK not create pulsation that comes from rotating parts and what rotating part did they touch, the wheels.
Hey you might be right but I don't think so. JMHO which wont buy the morning coffee.
Re: Fixed My Pulsating Brakes [Re: SHOZ] #4721213
04/09/18 05:58 AM
04/09/18 05:58 AM
OH
grampi Offline
grampi  Offline
OH
I guess my question would be, what's in the pads that leaves deposits on the rotor? Is it cheap pads, or do they all do it?
Re: Fixed My Pulsating Brakes [Re: grampi] #4721215
04/09/18 06:00 AM
04/09/18 06:00 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Cheap pads will certainly cause this but I've had the problem with quality performance brake pads too. Driving style and automatic transmissions make this worse.
Re: Fixed My Pulsating Brakes [Re: SHOZ] #4721323
04/09/18 08:09 AM
04/09/18 08:09 AM
OH
grampi Offline
grampi  Offline
OH
What material is coming from the pads that adheres itself to the rotors?
Re: Fixed My Pulsating Brakes [Re: Warstud] #4721526
04/09/18 10:41 AM
04/09/18 10:41 AM
NorthEast
Vikas Online content
Vikas  Online Content
NorthEast
After the alignment, did the mechanic took it out for a test drive? Were you in the car during the test drive?
Astute readers might figure out where I am going with this questioning :-)
Re: Fixed My Pulsating Brakes [Re: grampi] #4721939
04/09/18 04:42 PM
04/09/18 04:42 PM
Canada
camrydriver111 Offline
Canada
I got pulsating brakes 10,000 km after I put ceramic pads on my BMW.
The piston side of the rotor was badly scored. So if the brakes are relatively new check both sides of the rotor to see what's going on.
I think it was a bad pad or perhaps I forgot to clean the anti-rust oil coating prior to installation?
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
Re: Fixed My Pulsating Brakes [Re: Warstud] #4722897
04/10/18 03:32 PM
04/10/18 03:32 PM
MIchigan
Warstud Offline OP
Warstud  Offline OP
MIchigan
It's a mystery to say the least...I removed the wheels and had the tires installed at WM. I doubt they cleaned off any corrosion off the wheel. Maybe it had to do with the uneven wear of the tires but I didn't notice the brakes working any better after the new ones were installed.
