1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
29 registered members (citationxeleven, Char Baby, BobGoblin, Bailes1992, billt460, Blkstanger, 1 invisible), 905 guests, and 36 spiders.
Topics296,903
Posts4,961,308
Members66,997
Most Online2,688
Jan 19th, 2019
API SN Plus coming in May 2018! #4718639
04/06/18 04:39 PM
04/06/18 04:39 PM
Los Angeles, California
Gokhan Online content OP
Gokhan  Online Content OP
I'm surprised that this hasn't been big news here. The next "minor" update to the API PCMO is coming next month. It will be called API SN Plus and it's a minor update before API SP becomes available in around 2020 so that they will have oils already certified for LSPI protection in TGDI engines (or in any other engine in which it happens) without having to wait for that. Pennzoil will be the first company to offer it in May 2018. Be the first one to put it in your engine!
It only includes LSPI protection. Unfortunately there is no timing-chain protection. For timing-chain protection in TGDI engines, avoid 0W-xx oils for now until the test is included in API SP and use 5W-xx or, preferably, 10W-xx or thicker (see what's thick oil).
Pennzoil SN Plus
Oronite SN Plus
Lubrizol SN Plus
1985 Toyota Corolla LE, 4A-LC engine, ~ 272,000 M
Toyota (TGMO) 0W-20 SN high-moly GTL (© 2015 reformulation)
Mobil 1 EP M1-103 filter, 90430-12031 drain gasket
Re: API SN Plus coming in May 2018! [Re: Gokhan] #4718643
04/06/18 04:42 PM
04/06/18 04:42 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4631612/Re:_Est_first_use_date_for_API
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4679768/Why_isn't_Pennzoil_Ultra_Plati
18 Sportage 2.4L AWD:
Now: M1AP 5/20 + M1-104
Next: QSUD 5/30 + S2808XL
13 Santa Fe Sport 2.0T:
Now: PPEuroL 5/30 + OEM
Next: EDGE 5/40 + S2808XL
Re: API SN Plus coming in May 2018! [Re: Gokhan] #4718648
04/06/18 04:45 PM
04/06/18 04:45 PM
Great White North.. eh
webfors Offline
webfors  Offline
Very interesting!
Does this make Dexos 1G2 obsolete?
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w20, Fram DL11665
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: API SN Plus coming in May 2018! [Re: Gokhan] #4718653
04/06/18 04:49 PM
04/06/18 04:49 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
The Kendall Synthetic Blend I plan to use next already is SN Plus. Pennzoil says it's oils already meet it as well.
Re: API SN Plus coming in May 2018! [Re: Gokhan] #4718654
04/06/18 04:49 PM
04/06/18 04:49 PM
PimTac Offline
PimTac  Offline
Valvoline’s reformulated synthetics VAS and VME both are SN + right now. I’m sure other major brands are as well.
Cannot see signatures any longer so it doesn’t matter.
Re: API SN Plus coming in May 2018! [Re: webfors] #4718657
04/06/18 04:50 PM
04/06/18 04:50 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Originally Posted By: webfors
Very interesting!
d1G2 goes a step further with timing-chain protection as identified by Gokhan in the introductory post.
Re: API SN Plus coming in May 2018! [Re: Gokhan] #4718667
04/06/18 04:56 PM
04/06/18 04:56 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
So why is this called SN + instead of SO (or I would guess SP since O looks like 0)?
We have been on SN for quite a while now.
2018 Hyundai Santa Fe: Dealer oil, Mahle filter, 5k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: GTX HM 5w-20, EcoGard, 1yr
1994 Honda VT1100c: Peak 15w-40, PSL, 5k
Re: API SN Plus coming in May 2018! [Re: wemay] #4718668
04/06/18 04:56 PM
04/06/18 04:56 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Very interesting!
Dexos also limits the MRV to 2/3 of the API value.
It's definitely a spec that is desirable to have in an oil.
Pick SN, ACEA, Dexos, and the german specs over "just SN GF-5"
Re: API SN Plus coming in May 2018! [Re: Gokhan] #4718700
04/06/18 05:14 PM
04/06/18 05:14 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Re: API SN Plus coming in May 2018! [Re: blupupher] #4718706
04/06/18 05:19 PM
04/06/18 05:19 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
The next spec to be released was supposed to be SP, but delays in developing the qualification tests has led to a delay. The "SO" designation was skipped because it was too easily confused for "S0". The API has also skipped other designations in the past, such as SI and SK, because they would have been confused as being for spark ignition engines only.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: API SN Plus coming in May 2018! [Re: Gokhan] #4718802
04/06/18 06:26 PM
04/06/18 06:26 PM
USA
slacktide_bitog Offline
USA
API's SP should be made equivalent to at least A1/B1-12 spec (remember, ACEA dropped A1/B1 from the 2016 sequence)
Re: API SN Plus coming in May 2018! [Re: Gokhan] #4718937
04/06/18 08:44 PM
04/06/18 08:44 PM
Hammehead Offline
Hammehead  Offline
Colors don´t match with title in that spider graph laugh .
ToYota Corolla XEI 2010 1zzfe
Kawasaki Ninja ZX9R B4
Taurus GL Vulcan
Citroen C5 phase I
I used to use syn, now whatever is on sale and never had problems. This noob knows stuff.
Re: API SN Plus coming in May 2018! [Re: Hammehead] #4718943
04/06/18 08:50 PM
04/06/18 08:50 PM
red + blue = purple wink
It's a GIF image. Let's see if this works:
Re: API SN Plus coming in May 2018! [Re: Gokhan] #4718977
04/06/18 09:43 PM
04/06/18 09:43 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Purple is the overlapping of SN and SN Plus.
Red is the extra protection SN Plus extends past SN.
Blue shows the limit of SN.
Re: API SN Plus coming in May 2018! [Re: Gokhan] #4719383
04/07/18 10:10 AM
04/07/18 10:10 AM
Indy
69Torino Offline
69Torino  Offline
Indy
Hopefully there's a mass clearance of SN oils at chain stores to go along with it.
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2005 Ford Freestyle
2008 Hyundai Santa Fe
2015 Kia Optima
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
