Is RL Shockproof yellow metal safe?
Most modern gear oils are Yellow Metal safe.
Just don't use this in a manual transmission as it's application is for racing differentials.
where are you getting your information from? because i just dumped 2 bottles of heavy shockproof + 1/2 quart of MTL into my nissan's manual transmission.
Please explain why you would use a product in an application where it says not to use it.
Not a good idea.
I am getting my information from 30 years of formulating lubricants, where are you getting your mis-information?
mostly because i read about it here....
http://www.motoiq.com/MagazineArticles/I...f-the-Pros.aspx
i read that it takes 15 minutes to warm up, which this is in my "track" car, and not much of a daily driver, so i figured why not.
oh, and the place i was buying it from didn't have the MT-90 in stock.
It should be fine , in particular in a track car.
The approach of the builder makes a lot of sense and it should help.
I would personally opt for a monograde SAE 140 or 250 in upgrading protection capacity for its predictability.
Not a good idea.
Thirty years of experience is not necessary. You can read it right off of RED LINE's web page.
HEAVY SHOCKPROOF®
Film thickness greater than an SAE 75W250, yet low fluid friction like 75W90
Many performance racing applications like Sprint/Midget/Dirt Late Model Differentials, Detroit Lockers and spools, NHRA Top Fuel and Funny Car rear ends
Not recommended for most synchro applications due to the product's extreme slipperiness
Ed
