Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
81 registered members (AdRock, askani79705, 69GTX, asiancivicmaniac, aleneros, 9 invisible), 1,182 guests, and 43 spiders.
Topics297,006
Posts4,963,324
Members67,013
Most Online2,821
Jan 21st, 2019
Tire wont take air #4718431
04/06/18 01:28 PM
04/06/18 01:28 PM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
Got new tires put on in the fall. Went to put air in them to top them off and one of the tires wont accept air. Is this just the valve core issue where I can take that needle out or do I need to take it to the shop and get an all new valve stem? I aired up the other tires just fine so I doubt its my air chuck. Its at 28 lbs when should be 33. Also is the valve core vehicle speciffic?
'13 Toyota Tundra 5.7-Idemitsu
'08 Hyundai Elantra-Mobil 1
'96 Ranger R72 90hpJohnson
'03 Ski Doo REV 600 H.O.
�01 Kawasaki KDX 220r
Re: Tire wont take air [Re: pda1122] #4718455
04/06/18 01:50 PM
04/06/18 01:50 PM
Texas, USA
WylieCoyote Offline
WylieCoyote  Offline
Texas, USA
Valve cores may all have a slightly different design, and may render them non-interchangeable, but I've never heard of replacing cores. You should replace the entire stem. If your chuck worked on the other 3, the issue definitely isn't with your chuck. There's something blocking the air path in your stem. Be thankful that a foreign object isn't blocking your stem open. That's a lot less fun.
Re: Tire wont take air [Re: pda1122] #4718460
04/06/18 01:59 PM
04/06/18 01:59 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Probably just a new schraeder valve. Almost all are the same. If you have TPMS sensors, make sure to use a chrome one. The brass ones will cause galvanic corrosion.
We have to replace them quite often.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Tire wont take air [Re: pda1122] #4718493
04/06/18 02:28 PM
04/06/18 02:28 PM
Long Valley, NJ
Sluggo0018 Offline
Sluggo0018  Offline
Long Valley, NJ
I had a similar situation last year. The car in question had aftermarket stainless steel valve caps. I couldn't get the tire to take air, but it was holding pressure. I was ready to have a new stem installed. Turns out that the valve caps have a rubber o-ring that became lodged in the tip of the stem. I carefully pulled it out with tweezers and all was well.
Re: Tire wont take air [Re: pda1122] #4718512
04/06/18 02:44 PM
04/06/18 02:44 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Unscrew the core a few turns. Inflate and screw it back down.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Tire wont take air [Re: pda1122] #4718536
04/06/18 03:05 PM
04/06/18 03:05 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
Take it back to the tire shop. They should replace the cores for free or whatever is causing the tire to not hold air smile
Re: Tire wont take air [Re: pda1122] #4718629
04/06/18 04:30 PM
04/06/18 04:30 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I was blaming the HF inflator tip. Bad rap. It is the core. Use something to push in on the valve thingy. Exercise the thingy a few times, then try.
Thick oil is better grin2
Re: Tire wont take air [Re: Chris142] #4718677
04/06/18 05:02 PM
04/06/18 05:02 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
This pretty much works all the time.
The cores are universal - the valve stem core from any old bicycle or wheelbarrow tire (even a Boeing 747!) will work just fine.
Re: Tire wont take air [Re: pda1122] #4718745
04/06/18 05:45 PM
04/06/18 05:45 PM
iowa
Traction Offline
Traction  Offline
iowa
I've seen plenty of messed up valve cores, especially on the aluminum TPMS valve stems that people run around for 2-3 years with a missing valve cap, or even using a plain black plastic one, which do not have a o-ring like they are suppose to have. After that they self destruct in no time.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Tire wont take air [Re: Traction] #4718784
04/06/18 06:08 PM
04/06/18 06:08 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
This 1000%
I just worked on a TPMS equipped Dodge Caliber that had this exact problem
It didn't end well for one valve stem...
All I wanted to do was air up the tire, now this
Hope it never needs air whistle
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Tire wont take air [Re: pda1122] #4719835
04/07/18 06:05 PM
04/07/18 06:05 PM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
New valve core seemed to fix the issue. Thanks for all the help!
Slime valve cores: $1.39
Slime 4 way valve tool: $1.39
I priced out the parts and Auto Zone was by far cheapest. Glad I was able to fix on my own time, not wait at the shop, especially for something so small and cheap to fix your own.
Re: Tire wont take air [Re: pda1122] #4720309
04/08/18 07:46 AM
04/08/18 07:46 AM
ME
eljefino Offline
eljefino  Offline
ME
approved
You can also find valve cores in the parking lot of any tire store anywhere. LOL
