Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
36 registered members (claluja, CR94, carlprop, c502cid, bbhero, Brad_C, 3 invisible), 808 guests, and 58 spiders.
Topics286,170
Posts4,903,526
Members67,572
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Supertech 15W40 7.3 Powerstroke #4717604
04/05/18 07:58 PM
04/05/18 07:58 PM
Golden Meadow, LA
mobilaltima Offline OP
Golden Meadow, LA
Should I have any concerns running ST 15W40 CJ-4 in my F250? I usually run Motorcraft 15W40, due to the extra ZDDP levels, with a Napa Gold 1734. I'm just getting tired of spending almost $80 for an oil change for this truck, I just use it in a 50 mile radius, short tripped often, just a beat up old work truck, but I do want the engine to be protected, so if Supertech would offer the same level of protection of the Motorcraft, I'm all for it. Also, should I have any concerns running the spec'd Baldwin B7039 oil filter? The local hardware store has about 20 leftover from when they had a 7.3 delivery truck, theyre selling them for $5 each. My only concern is the Baldwin filter is noticably shorter than the Napa Gold or Motorcraft filter (7 and 3/8 compared to 8 inches long for the Napa Gold and Motorcraft).
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4717607
04/05/18 08:01 PM
04/05/18 08:01 PM
USA
SOHCman Offline
SOHCman  Offline
USA
Run it and do a UOA with she savings?
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4717609
04/05/18 08:02 PM
04/05/18 08:02 PM
maple ridge, bc
2004tdigls Offline
2004tdigls  Offline
maple ridge, bc
the only thing that matters is that the oil has API CJ approval, this exceeds the original specification
use supertech with confidence
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4717613
04/05/18 08:04 PM
04/05/18 08:04 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Or hit the ST with a shot of Lubegard HD Engine Protectant for some additional protection.
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4717616
04/05/18 08:06 PM
04/05/18 08:06 PM
Golden Meadow, LA
Golden Meadow, LA
I don't run the truck hard, I change the oil and filter every 4500k. I should do a UOA just to see what shape the engine is in.
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4717623
04/05/18 08:11 PM
04/05/18 08:11 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I ran that oil in my peterbilt for 3 years. After 3 years it was still servicible.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4717656
04/05/18 08:40 PM
04/05/18 08:40 PM
North of you Idaho
KneeGrinder Online content
KneeGrinder  Online Content
North of you Idaho
I'm not slamming you, its not my style, but I just don't understand why you used Motorcraft oil instead of any 1 of the big 3= Delo, Delvac, Rotella? The factory fill from Navistar I believe was Delo 400. A 5 gallon bucket of Delvac 1300 is about $63.00 around here. I think there is a $25.00 rebate for it right now. Now your 5 gal bucket of oil is $38.00 plus taxes. Keep using the Wix filter, its a good filter.
P.S. There is nothing wrong with using ST at this point, I just think you can get Delvac cheaper or near the same price!
The Baldwin filter is a good filter also, you should have no concerns with the short OCI's your runnin.
08 Tribeca 86k PUP 5w30 wix
06 Accord Hybrid 134k PPHM 0w20 wix
02 Chevy k3500 99k Delvac 1 esp 5w40 wix
00 F350 136k Delvac 1300 15w40 wix
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4717692
04/05/18 09:00 PM
04/05/18 09:00 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I think the shorter filters will work just fine,
thats what the original 6.9 & 7.3 IDI engines used
Re: Supertech 15W40 7.3 Powerstroke [Re: Linctex] #4717734
04/05/18 09:45 PM
04/05/18 09:45 PM
Chris142 Offline
Chris142  Offline
the idi used a shorter 32 micron filter. The power stroke uses a longer 20 micron filter. I would not use the idi filter on a power stroke.
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4717737
04/05/18 09:48 PM
04/05/18 09:48 PM
Golden Meadow, LA
Golden Meadow, LA
The B7039 is not the shorter IDI filter. Its the correct cross to the Motorcraft FL1995 but for some reason Baldwin makes their filter shorter.
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4717898
04/06/18 04:49 AM
04/06/18 04:49 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
The 7.3L PSD is not known to be finicky about oil brands and grades in terms of wear.
It will shear down at 40 grade to a 30 grade, but with you planned OCI that's not a big deal; or feed it a 10w-30 to being with (won't find that in ST products, at least for now ...)
The 15w-40 ST will do just fine. It's every bit as good in terms of wear control as any of the majors, for the type use you describe.
Why not run a UOA with the MC, then run one with the ST. I believe you'll find they both fall well within "normal" expected ranges of wear rates.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Supertech 15W40 7.3 Powerstroke [Re: SubieRubyRoo] #4718769
04/06/18 06:58 PM
04/06/18 06:58 PM
The American West
bbslider001 Offline
bbslider001  Offline
The American West
Absolutely NOT on the 7.3 unless you want HPOP issues and injector issues. The 7.3's fuel system is oil driven and the additives hurt this rather than help it.
OP, ST is a great oil for the 7.3 PSD. I have been running it on my truck and it does very well and it is a CJ-4 with a robust add pack. Run it, save money, and be happy.
Byron
1999 F-350 CCLB SRW 7.3, Supertech 15w-40 protected, 300k miles
1997 F-350 CCLB DRW 7.3, SOLD
2015 Kia Soul Plus
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4720716
04/08/18 04:21 PM
04/08/18 04:21 PM
Maryland
turbowhistle Offline
Maryland
I now have a 2011 Ram 3500 with the 6.7 Cummins and only use Rotella T6 with either the Cummins oil filter or the Mopar oil filter (made for Mopar by Cummins) changing both every 5000 miles.
I used to own a 2002 F350 with the 7.3 made by International, wow what a good motor. Oil and oil filter changes were easy. I mainly used the Motor Craft 15w40 which is made for Ford by Conoco Phillips, really good oil.
I never used the ST diesel oil, as long as it meets the specs, it should be fine. While at WM, I always purchased the MC oil filter as well it was $9.95, cheaper than the dealer.
One good thing about the 7.3, if you ever ran low on oil while driving, the engine would shut down due to the HPOP that pressured the injectors. I never had that issue, just a small oil leak around the turbo-pedistel due to worn pedistel O-Rings, leaked about 1 quart every oil change at 5000 miles. Again, in my opinion, the 7.3 was the best diesel placed in a Ford Truck.
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4723207
04/10/18 10:27 PM
04/10/18 10:27 PM
Texas
Big_3_Only Offline
Big_3_Only  Offline
Texas
I thought that ST was made by Phillips 66 at one point. Is that not the case anymore?
2019 Cadillac XT4
2014 Buick Regal Turbo 45k
2008 Mercury Grand Marquis 211k
2004 Jeep Wrangler 210k
1996 Dodge Ram 230k
1972 GMC Jimmy 450k
1972 Chevrolet C10 400k
Amalie, Kendall, Schaeffer's
Re: Supertech 15W40 7.3 Powerstroke [Re: mobilaltima] #4723274
04/11/18 02:37 AM
04/11/18 02:37 AM
Cave City KY
jakewells Offline
jakewells  Offline
Cave City KY
ST is warren made in my area it has WPP stamped on the bottom of the jug.
1994 Ford F150 302 4R70
Chevron Delo SAE 30 CF/SL Fram XG8A
1978 Chevy Nova 250 I6 Borg Warner T5
Rotella 10W40 Fram XG5
Page 1 of 3 1 2 3
