Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
Oil weight and FM
by Brian553. 01/22/19 01:07 PM
New Bridgestone Blizzak WS90
by SubLGT. 01/22/19 12:59 PM
Southwest Airlines slides off runway
by JustN89. 01/22/19 12:55 PM
phenolic caliper pistons
by bionictony. 01/22/19 12:31 PM
SS snowblower auger to scraper gap?
by dwcopple. 01/22/19 11:47 AM
PP HM 10W-30 at Walmart for $15
by 28oz. 01/22/19 11:30 AM
2012 Camry ATF change- now or later?
by TmanP. 01/22/19 11:20 AM
Oil sampling tube
by kevmor99. 01/22/19 10:00 AM
Gas trimmers
by weeksjake. 01/22/19 09:11 AM
Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
109 registered members (2strokeNorthstar, AdditiveOCD, 2015_PSD, 28oz, 6 invisible), 2,217 guests, and 36 spiders.
Topics296,986
Posts4,963,029
Members67,013
Most Online2,821
Jan 21st, 2019
1/4 copper compression fitting leak #4717275
04/05/18 01:22 PM
04/05/18 01:22 PM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
Trying to connect plastic tubing to copper for fridge/ice maker
Got this coupling from home depot.
Put the sleeve in the plastic worked fine
But the copper tubing connection the to coupling has a tiny leak.
The coupling came with a ferrule in it, tried that first, tiny leak , 1 drop leaks down pipe per minute.
I cut the old ferrule and pipe off, and added a new ferrule.
Same thing, leaking
Tips,
advice?
08 Honda Accord EX-L 2.4L M1 EP 0w20 145k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 193k
95 Yamaha Jog
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4717279
04/05/18 01:29 PM
04/05/18 01:29 PM
USA
mk378 Offline
mk378  Offline
USA
Push-in fittings are the way to go these days.
With the compression fitting, assemble the ferrule and nut hand tight, then put the tube in-- making sure it goes all the way in-- then tighten the nut.
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4717290
04/05/18 01:42 PM
04/05/18 01:42 PM
Minnesota
bruckus Offline
bruckus  Offline
Minnesota
Like mk378 says, it seems like the Sharkbite fittings or similar are easy and reliable. On the one you have make sure all the surfaces are clean and damage free. Any scratches and such will cause a leak. Sometimes the will self seal after awhile.
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4717292
04/05/18 01:48 PM
04/05/18 01:48 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
If the copper tube was clean and not deformed or scratched then you just need to compress it to seal. Dont be afraid to crank down the compression fitting until the edges of the brass ferrule COMPRESS onto the copper pipe and seal. It wont seal over time more so make sure its not leaking before you put it away.
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4717294
04/05/18 01:50 PM
04/05/18 01:50 PM
ME
eljefino Offline
eljefino  Offline
ME
Polish up the outer surfaces of both copper and plastic with some fine grit sand paper.
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4717349
04/05/18 02:57 PM
04/05/18 02:57 PM
Ceciltucky Maryland
Oldtom Offline
Oldtom  Offline
Ceciltucky Maryland
I have had good luck putting a drop of oil on the threads of brass compression fittings. The oil lets the "sticky" brass threads tighten up better. keep the oil out of the water line proper.
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4717375
04/05/18 03:20 PM
04/05/18 03:20 PM
Central Virginia
Silverado12 Online content
Silverado12  Online Content
Central Virginia
Lime in the water will seal a small leak by itself. I would bear down on the compression fitting a little tighter.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4717398
04/05/18 03:43 PM
04/05/18 03:43 PM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
They don't make a 1/4 OD push to connect
I used some steel wool on the copper end
I'll just have to get another coupling and try again.
01 Kymco People 50
95 Yamaha Jog
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4717416
04/05/18 04:09 PM
04/05/18 04:09 PM
USA
mk378 Offline
mk378  Offline
USA
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4717431
04/05/18 04:32 PM
04/05/18 04:32 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Permatex liquid teflon thread sealant.
Just smear a very light coat on the "barrel" (none on the threads) - done
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4717578
04/05/18 06:37 PM
04/05/18 06:37 PM
Canada
expat Offline
expat  Offline
Canada
As above, or I have used a wrap of teflon tape.
Re: 1/4 copper compression fitting leak [Re: mk378] #4720340
04/08/18 08:20 AM
04/08/18 08:20 AM
Chicago, IL
Brybo86 Offline OP
Brybo86  Offline OP
Chicago, IL
Those are 1/4in ID not OD
Came out to 3/8 OD.
I got it all connected with a second new 1/4 OD union coupling
01 Kymco People 50
95 Yamaha Jog
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4720374
04/08/18 09:01 AM
04/08/18 09:01 AM
USA
mk378 Offline
mk378  Offline
USA
You must have had the wrong part. Lowes and similar stores definitely sell them for 1/4 inch OD (as well as 3/8 and 1/2). Small tubing is trade-sized by OD.
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4720390
04/08/18 09:19 AM
04/08/18 09:19 AM
KS
red7404 Offline
red7404  Offline
KS
for what its worth. i cant stand compression fittings. i like double flare. like on a break line. NEVER had one fail. and plastic is NOT even right for any thing.
Re: 1/4 copper compression fitting leak [Re: Brybo86] #4720688
04/08/18 02:50 PM
04/08/18 02:50 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
You're not supposed to use the brass ferrule on plastic tubing. It cuts into the tubing causing a leak. Use a plastic ferrule. Tighten the **** out of the copper side, with a back up wrench holding the fitting.
35 years experience as a pipe fitter/journeyman plumber/welder/-6 years as an ABC pipe fitter teacher.
