Attic radiant barriers
Utah, USA
In anticipation of summer, I've decided to install some radiant barrier film in my attic. My home is multiple levels with the master bedroom being at the very top. It gets quite warm, predictably, as does the entire top half of the house. I'm not expecting miracles, of course, but would like to hear first hand experiences of those who have it and what benefits (if any) they have seen from it.
This is what I've ordered:
https://www.amazon.com/RadiantGUARD-Radi...6691&sr=8-1
Thanks!
I used the spray-on type back in the mid-90's. The roof trusses made stringing a foil barrier far too difficult. Note that a barrier only works on roofs exposed to the sun. Many don't.
Your A/C ductwork may also need balancing to ensure enough air up top to deal with the heat load.
How is your attic ventilated? Getting rid of the heat buildup with a small fan could be all you need. If you live in a high solar area then maybe a solar powered fan would be the ticket. The design of your attic is the missing part of the puzzle. For a simple peaked roof design, placing vents on each end near the top with fans to exhaust the hot air out will work. Another method would go through the roof with a vent cap.
In a older house I used to live in, the attic had a small window. We would open that with a screen in place and had a regular table top fan pointed out to exhaust the hot air. It might take several hours for any effect to be noticeable.
Good idea, my house faces east but has a tree that blocks the front side of the roof. The sun bakes the west side of the roof during the afternoon, and stays warm into the night. It gets super hot on the second and stays hot because the thermostat is on the first floor. It was brutal before I put a shade in two centrally located skylights.
I would have went with reflectix insulation, that seems to be a popular choice for IR insulation. The stuff you have is nice and thin, so you will probably be able to get better coverage with less cuts.
If you install IR insulation and increase ventilation in your roof the results will be tangible I imagine. I felt a difference installing the shades and retaping the ducting and plenums in my furnace room. It made it so that it was bearable, whereas before it was unbearable for long periods.
Originally Posted By: JohnnyJohnson
What is this going to do to your cellphone reception in the house?
Good question. I don't know. However, cell signal will still be able to come in through the walls, so hopefully it won't affect it too much. I can make and receive calls through the wifi anyways, so I still have that, at least.
The roof is multi-level as well, so I'm not sure. I do know there are vents at the peak of the top roof as well as on the north side under the peak (sorry, not too familiar with roofing and building terminology). *I think* I have ventilated soffits at least on the west side of the house where there is a porch surrounding the front door.
In the attic, there are trusses with varying levels of headspace............from about a foot to being able to stand up straight in spots. A solar powered fan would probably be a great idea. Just have to figure out what type and where to put it.
We used a very similar material about 7 - 8 years ago in conjunction with additional attic insulation. We also wrapped exposed ductwork (insulated flex-duct) and added ridge vents to our ranch style here in N. Texas and you will notice a difference. Not a large financial load up front but do it now while it is cool.
Good to hear it made a difference. Yeah, it's not expensive and definitely want to get it done before it heats up! Wrapping more insulation around the ductwork is a great idea as well. I'll have a look at it while I'm up there.
Keep in mind that the reflected heat does go somewhere and that is back out under the shingles possibly shortening their life.
If you use this stuff you need to make sure each rafter has a soffit and peak vent. Hot air needs to be able to escape from the peak and draw cool air in thru the soffits to keep the roof cool. Without this air flow heat will build up in the roofing and that is not good for them. So yes your bldg is cooler but you need to re-shingle considerably sooner. Additionally in damp areas the lack of ventilation is perfect place for mold to develop.
In Arizona we put a shyt-ton of insulation on the attic floor and heavy insulation on ducts and leave the rafters roof open to freely ventilate. A rafter pink insulation glass side down and stapled to the attic floor has aluminum reflective backing facing the roof that does the same thing. Keeps the cold inside the house and lets the attic breathe.
IMO this is a quick/cheap fix that should be done a different way.
Good points. I'm reading it is a good idea to stop the barrier at least 6 inches from the top so the heat has somewhere to go. The barrier is supposed to be breathable so not too worried about moisture buildup. Our air is pretty dry here for the most part too. I'll definitely make sure there is ventilation between the barrier and the roof as I wondered about that as well. I appreciate the input.
We can't really know the issues that could arise after buying a certain device. The only thing we can do is to look for an in depth review before getting one. But not all blogs include a section where they include customer reviews. This website is one of the few that you can find a "user critics" section on : https://heaterslab.com/best-radiant-barriers/
What's wrong with that website? The home page is broken.
