New car wax score
by Marco620. 01/16/19 02:42 PM
Bought a used Cherokee Trailhawk
by Sunnyinhollister. 01/16/19 02:34 PM
Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
115 registered members (4WD, 2004tdigls, 28oz, advocate, 2002 Maxima SE, 9 invisible), 2,206 guests, and 35 spiders.
Topics296,645
Posts4,956,535
Members66,950
Most Online2,577
Jan 14th, 2019
Any husky chainsaw people here ? #4717184
04/05/18 11:12 AM
04/05/18 11:12 AM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
a few years ago i bought a husky 40 chainsaw at a garage sail for $20. took it home and it ran and died quickly. i figured out that it was the coil. got tired of messing with it so it sat.
i decided to try to fix and get a new coil. i don't want to throw $60-80 for a new husky coil. i can get a cheap chinese replacement for about $10.
the issue i am having is figuring out which coil to get. the ebay ones seem to list a coil for a husky 50 will work. but looking at the pix my coil has a extra wire .
So do i need the extra wire? it seems to be some kind of ground.
here is a ebay one . looks real close to mine
https://www.ebay.com/itm/Ignition-Module-Coil-For-Husqvarna-50-51-55-61-254-257-261-262-266-268-272/173019587578?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3D086e01e8912e4d0eba600e2677bffb8e%26pid%3D100033%26rk%3D6%26rkt%3D8%26sd%3D382396208035%26itm%3D173019587578&_trksid=p2045573.c100033.m2042
here is mine. will the ebay one work?
Re: Any husky chainsaw people here ? [Re: WhyMe] #4717188
04/05/18 11:18 AM
04/05/18 11:18 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I see a wire in the eBay listing, is that not the same? Different connector, but probably the same?
Also, how did you determine the coil was bad? Did you confirm that the spark plug isn't sparking and that it isn't the spark plug that needs replacing?
Re: Any husky chainsaw people here ? [Re: WhyMe] #4717201
04/05/18 11:32 AM
04/05/18 11:32 AM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
the wire in the ebay goes on to the top tab. the yellow wire that goes into the winding is not there. not sure if the yellow wire is needed. it will start and run when dead cold. after a minute or so it dies and won't restart till its cold again. i checked for spark while warm and it has not.
i don't want to throw too much money at it as its just gonna sit
Re: Any husky chainsaw people here ? [Re: WhyMe] #4717219
04/05/18 11:52 AM
04/05/18 11:52 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Hm, I see that you have a separate tab where the eBay model has the wire. Maybe like you said, it isn't needed as in, it will ground through the mounts?
Maybe grab this one: https://www.ebay.com/itm/husqvarna-50-coil/162721260767?hash=item25e2f164df:g:H34AAOSwj99Z6-F5
Re: Any husky chainsaw people here ? [Re: WhyMe] #4717373
04/05/18 03:20 PM
04/05/18 03:20 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Some of the Husky coils are rev-limiter coils. These are the ones that the saw modification groups discard. If I remember correctly, the black coils were non rev limited.
Re: Any husky chainsaw people here ? [Re: WhyMe] #4717434
04/05/18 04:40 PM
04/05/18 04:40 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Just a friendly reminder when posting links that are a mile long.......
Delete the " ? " and everything after the ? before you submit.
NONE of this:
Needs to be included!
