Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
109 registered members (AmoryBlaine, 4WD, 53' Stude, 2015_PSD, Arctic388, 18 invisible), 1,837 guests, and 38 spiders.
Topics296,966
Posts4,962,564
Members67,009
Most Online2,821
Yesterday at 01:32 PM
Page 1 of 3 1 2 3
Dexos Oil #4716915
04/05/18 06:49 AM
04/05/18 06:49 AM
Cajun Country, La.
BlueOvalFitter Offline OP
Cajun Country, La.
Does this oil have any effects on the internal moving parts of a GM engine? If the internal parts aren't lubricated by a required Dexos oil, will the engine blow up, seize up, cause internal parts to fail, cause the bearings to score, etc.?
Re: Dexos Oil [Re: BlueOvalFitter] #4716923
04/05/18 06:54 AM
04/05/18 06:54 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
OK, I rest my case...
Have you read a GM owner's manual ?
My Colorado specs Dexos 2, but accepts ACEA C3.
Re: Dexos Oil [Re: Shannow] #4716929
04/05/18 06:57 AM
04/05/18 06:57 AM
Cajun Country, La.
Cajun Country, La.
No, because I don't own any GM vehicles.
But, I did read this on the interweb and find it hard to believe;
Randall McFarland on January 7, 2017 at 4:08 pm said:
I bought my 2012 chevy avalanche[54,000 miles]at a ford garage, they had changed the oil[synthetic blend] and filter with motorcraft, with still 500 miles left before oil change was due, my oil pressure dropped to near zero. And yes the oil level was good. Changed the oil to a brand with dexos and its back between 40 and 60 psi. I will use oil w/dexos in my chevy from now on. It says dexos on the oil fill cap for a reason.
Re: Dexos Oil [Re: BlueOvalFitter] #4716937
04/05/18 07:03 AM
04/05/18 07:03 AM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
There is a puzzle piece missing from his story. It can't be the oil. Maybe dilution?
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Dexos Oil [Re: BlueOvalFitter] #4716940
04/05/18 07:05 AM
04/05/18 07:05 AM
socal
barkingspider Offline
socal
The Chevy Colorado 5 cyl engine is the same engine in 2008 and 2012, but dexos oil required on the 2012
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Dexos Oil [Re: BlueOvalFitter] #4716941
04/05/18 07:05 AM
04/05/18 07:05 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
I am pretty much a believer in a wide range of viscosities for any engine but I believe aside form the dumb cafe rules, GM was motivated by the horrible experience they had with the infamous AFM cylinder deactivation problems in trucks up to 2014 with 5.3 liter engines. Part of the solution was a complete re-design and the use of lighter synthetic oils. Billy Bob kept trying to run 40 weight conventional oil in those trucks with disastrous results involving failed lifters.
If you want the job done right......do it yourself.
Re: Dexos Oil [Re: BlueOvalFitter] #4716949
04/05/18 07:09 AM
04/05/18 07:09 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
OK, this is the same interweb that you read that 0W40 would destroy engines that specced lower grades ?
Having started the thread, you then called for closure, and step out lest you carry out autoban sepuku.
Do you HONESTLY believe that what you included there, underline is in the remotest chance possible ?
Can you describe any thought process that you have that would make that plausible ?
Re: Dexos Oil [Re: BlueOvalFitter] #4716951
04/05/18 07:11 AM
04/05/18 07:11 AM
This one is easy. The screen below the pressure sensor got clogged and the thinner synthetic oil that happened to be Dexos unclogged the screen allowing pressure to the sensor.
Re: Dexos Oil [Re: Shannow] #4716959
04/05/18 07:17 AM
04/05/18 07:17 AM
Cajun Country, La.
Cajun Country, La.
I think you follow me around, to try and get me to say something to get me banned. I only have 2 options from getting banned because of you and your ANTAGONIZING replies;
1) Put you on ignore.
2) Just not respond to you.
Tell me, which choice would you make?
Re: Dexos Oil [Re: BlueOvalFitter] #4716963
04/05/18 07:20 AM
04/05/18 07:20 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
I'd seek help...
Re: Dexos Oil [Re: Shannow] #4716965
04/05/18 07:22 AM
04/05/18 07:22 AM
Cajun Country, La.
Cajun Country, La.
I'd seek help...
I have. But the voices differ with me.
Re: Dexos Oil [Re: BlueOvalFitter] #4717089
04/05/18 09:30 AM
04/05/18 09:30 AM
MN
oil_film_movies Offline
MN
GM thinks so. At least enough to affect warranty claims, customer satisfaction, and general (no pun intended) internet reputation.
When GM created dexos, they had several goals:
1. Globally simplify oil specs. That makes it less likely the wrong oil gets put in.
2. Reduce warranty claims from oil problems. See https://www.youtube.com/watch?v=0B6SHa4qv60 for the concerns. Willis mentions a few.
GM knows that everytime LSPI destroys pistons, or AFM systems gum-up, or rings fail, etc., warranty claims go up AND the internet airs their dirty laundry.
3. Apply the dexos-spec fees to pay for some engine research.
4. Extend the length of OCI's for fleet & general customer satisfaction and to avoid government pressure for ecological concerns (California's push).
This is GM becoming more like the Germans. The Germans have had very tough specs for years, and now GM realizes their own engines are being used hard too, especially as more downsizing with DI and turbos proliferate.
Re: Dexos Oil [Re: BlueOvalFitter] #4717109
04/05/18 10:00 AM
04/05/18 10:00 AM
Canada
Uregina09 Offline
Uregina09  Offline
Canada
Another thread that demonstrates either a complete inability to think critically or a penchant for trolling. I'd follow Shannon's advice, BOF.
2018 Ford F150 with 2.7 Ecoboost: Valvoline Full Synthetic 5W30 and Motorcraft FL2062
2016 Toyota RAV4: Pennzoil Platinum 0W20 and Toyota 04152-YZZA1
Re: Dexos Oil [Re: Uregina09] #4717112
04/05/18 10:04 AM
04/05/18 10:04 AM
Cajun Country, La.
Cajun Country, La.
Originally Posted By: Uregina09
Another intelligent thread. I'd follow Shannon's advice, BOF.
Ah, another follower. My advice to you, don't read my posts.
I did get help at my local VA. But, the voices are overpowering my thoughts. grin
Re: Dexos Oil [Re: BlueOvalFitter] #4717116
04/05/18 10:06 AM
04/05/18 10:06 AM
Cajun Country, La.
Cajun Country, La.
I sure am glad we have that NOTIFY button.
Page 1 of 3 1 2 3
