'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
99 registered members (AndyB, 69GTX, anndel, 97f150, Anduril, 14Accent, 6 invisible), 2,123 guests, and 51 spiders.
Topics296,780
Posts4,958,724
Members66,969
Most Online2,577
Jan 14th, 2019
Video: GM 5.3 flexing under load - is this normal? #4716506
04/04/18 06:04 PM
04/04/18 06:04 PM
El Oeste
HawkeyeScott Offline OP
El Oeste
Iíve been chasing what has felt like movement in the driveline on my 2008 Suburban 5.3 with the 4L60E. I thought I had it licked after replacing the driverís side motor mount last week. Now, it feels like the movement has returned, though not as bad as before. I just took this video (link below) of the engine moving up on the drivers side under load. Wondering if you all would take a look and let me know if you think this is normal. Again, the mount on this side is one week old. Itís OEM ACDelco FWIW.
If the mount is bad, I have to figure out if it was a lemon or if something is going on that is breaking that mount on that side. Thanks a lot. This is driving me crazy.
https://youtu.be/8A92zWaaPcE
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4716511
04/04/18 06:07 PM
04/04/18 06:07 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Motor mounts should be replaced in pairs. But some movement is normal.
I'd be more worried about that awful buzzing sound.
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4716518
04/04/18 06:19 PM
04/04/18 06:19 PM
USA
WDB Offline
WDB  Offline
USA
IS YOUR TRANSMISSION MOUNT TIGHT? IT WORKS IN CONJUNCTION WITH THE ENGINE MOUNTS. SOME FLEXING IS NORMAL.
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4716527
04/04/18 06:28 PM
04/04/18 06:28 PM
El Oeste
El Oeste
Yes. I did the transmission mount before I checked motor mount. Itís two weeks old. Changing it cut down on what I felt. Thatís what led me to keep looking when I ended up finding the failed motor mount.
Again, what Iím feeling is only on shifts. And really only on the 2-3 shift. Im starting to wonder if something is amiss inside the transmission and while new mounts have helped lessen itís effects, mounts are not the root issue.
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4716532
04/04/18 06:34 PM
04/04/18 06:34 PM
Texas
4WD Offline
4WD  Offline
Texas
Seems more mounts from that side are for sale on eBay Ö
Clinebarger should know Ö
Re: Video: GM 5.3 flexing under load - is this normal? [Re: 4WD] #4716553
04/04/18 07:02 PM
04/04/18 07:02 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
The GMT900 platform is known for left motor mount (Torque side) failure.....Which is odd as the GMT800 platform used a very similar mount.
They usually rip apart when they fail & the engine will move A LOT more than in the video.
I would suspect a "sticky" Slip Yoke, I really need to know if your truck is 4wd or not??
2001 Chevy Camaro L92/4L80E
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4716566
04/04/18 07:17 PM
04/04/18 07:17 PM
El Oeste
El Oeste
Thanks.
It is a 4wd. The yoke was the first thing I did, but only did it with ATF. (Apparently grease on the yoke in this application is a no no?). It didnít change anything, but using ATF, I didnít really expect it to. Part of me wants to do it with grease and see if that works, and then plan on doing the transfer case drain/refill.
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4716585
04/04/18 07:41 PM
04/04/18 07:41 PM
Coastal South Carolina
edwardh1 Offline
edwardh1  Offline
looks average.
can u find another same truck to compare to?
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4716587
04/04/18 07:45 PM
04/04/18 07:45 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
It "only" happening on the 2-3 shift is interesting. Just so you know.....The 2-3 shift on a 4L60E will NEVER be perfectly "clean".
The 2nd Clutch (2/4 Band) has to be pushed OFF while at the same time the 3rd Clutch (3/4 Clutch) comes ON. This is Impossible to accomplish in a perfectly choreographed manner.
As the frictions wear.....The "Timing" can change.
On a good unit.....The 2nd Clutch coming Off & the 3rd Clutch coming On will Overlap ever so slightly.....Which in actuality is a 2nd-4th-3rd shift, But it's in 4th for such a small time on a good unit you can barely tell.
On a unit on the way-out, Heavily worn-out, Or built/modified with mismatched components....The 2nd Clutch will push off before the 3rd Clutch can come On, This will feel like a slip or as we call it a "Cut-Loose". In actuality...It's shifting 2nd-1st-3rd.
The 4L60E & derivatives NEVER used "Shift Timing Corrections" or "Adaptive Shift Strategies" to help mask friction wear like GM Transaxle units (4T65E etc) Because, Well.....It doesn't work on this unit!!
I don't even want to plant the seed that this is a transmission issue!! Maybe taking it to a good transmission technician for a test drive would be the best coarse of action.
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4716602
04/04/18 08:05 PM
04/04/18 08:05 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Originally Posted By: HawkeyeScott
Thanks.
The 4wd Yoke gets a healthy supply of splash lube when the truck is moving, I have never personally seen wiping some ATF on the splines do any good. The 2wd trucks have a sleeve, The ATF in the trans cannot lube the splines.....Being the reason you can use grease.
For testing purposes.....You can absolutely use some grease on the splines!
In the end of all this mess, With GM issuing SEVERAL TSB's......The Slip Yokes were the problem all along. Not that we in the industry didn't figure that out years before.
IF you do come to a conclusion that the slip yoke IS the issue.....Buy a Chromoly Sonnax slip yoke, Cheaper & better quality than the "updated" GM slip yokes.
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4716633
04/04/18 08:32 PM
04/04/18 08:32 PM
El Oeste
El Oeste
Very helpful. Thanks a lot.
Clinebarger, so youíre not concerned about grease on a slip yoke Ďcontamintaingí the ATF in the transfer case? It looks like the splines reach into the case to the point theyíre swimming in Dexron.
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4716667
04/04/18 09:02 PM
04/04/18 09:02 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Not for testing purposes & you don't want to use alot of grease either.
The fluid level is well below the output shaft in the T-Case, But it IS spray lubed buy the lube pump. The contamination issue has to do with the Wet Clutch in Part-Time Auto/Active transfer cases.
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4716713
04/04/18 10:40 PM
04/04/18 10:40 PM
El Oeste
El Oeste
Iím afraid I have the Auto 4WD feature. Still a good idea to at least test with some grease? Thanks again.
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4717702
04/05/18 08:11 PM
04/05/18 08:11 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
It will be fine for such a short time.
Re: Video: GM 5.3 flexing under load - is this normal? [Re: HawkeyeScott] #4718805
04/06/18 06:31 PM
04/06/18 06:31 PM
El Oeste
El Oeste
Just greased up the slip yoke and reinstalled. Unfortunately, no improvement in the condition.
That means addressing the slip yoke, u joints, tranny mount and one motor mount hasnít fixed this oddball feeling I have when the truck shifts. Is it time to focus on the tranny? Could anything in the differential be failing and produce this issue?
(Here is my original description of the issue from a month ago)
https://www.bobistheoilguy.com/forums/ub...iss#Post4688632
