Help! Water leak under slab
Jupiter, Florida
FL acreage property, concrete block home with a monolithic slab. Pipes under slab.
Yesterday, walking barefoot I notice a hot section of tile floor. Sure enough, its where I remember the water pipes being. Turn off the water heater inlet overnight and the floor cools. Turn on the water heater inlet and a rush of water is heard. Rinse-repeat. Yup, I've got a substantial leak.
The hot-spot is about 13-14 feet in from the wall. I suppose one could tunnel underneath in wintertime, when the water table is low. As my house is on a bit of a mound.
I'd really hate to break up the tile floor and destroy the slab. As of right now, I don't have any known or major slab cracks, or any water in the home.
Of course, the hot spot may not be where the leak is. As some of the pipes have insulation.
Suggestions? I have zero idea how to deal with this, other than to tunnel under and solder in a new section.
Installing new plumbing in the attic is prob exceptionally difficult.
Copper pipes? I don't know if they make pipe cameras that work with that size of pipe, but if they do having a look to see where the problem is would be a good start.
Also for hot water, pex in the attic might be surprisingly easy to install even down into the walls. You'll get instant hot water in the summer too!
If you do not want to break the slab to fix the leak, your only other option is to re route the pipe. This will save your floors but u will have holes in the drywall to patch and paint. Re route is a better option as u now have new pipe vs new patched old
My mother's house had that problem twice with cold-water pipes. Solved once by rerouting around the outside of the house, underground. The second time by slipping a special plastic pipe inside the copper pipe for the whole distance---a more elegant and less expensive solution. Some plumbers in your area should know how to do that if the problem is not rare there.
I would agree...
Depends on what's currently buried and its age. It might be possible to use a thermal camera to pinpoint the leak. The risk, not knowing why the pipe burst, is after the fix other leaks may sprout.
I think abandoning and rerouting is likely the better option.
My mother in laws house was built in 1980 in Florida. She had the same problem. They re-plumbed the entire house through the attic. You could dig up the concrete but that would be substantially more money. Get a few quotes from plumbers, they will likely qoute the same thing..
Plumbing through the attic can be annoying because your water is HOT coming through the pipes for the first minute, even the cold water. The cold water for the first minute, will be 110 degrees or so, until it flushes out all the water and cools down to normal ground water temp, 72ish.
Thanks guys,
Yes, copper pipe. House is 15 years old. 3300 square feet total, including the 3 car garage, 2400 under air.
You have to way out rerouting the section of piping inside the home somehow like walls or attic. What are the walls made of?
Here in the cold, they sometimes use re-circulation pumps to keep the water warm for a long run.
Would that be feasible for OP for cold water circuit?
Funny thing. Growing up in Kuwait before they had a water distribution system they delivered water via truck to house and pumped to tanks on roof. In winter we used the hot water tank inside house. In summer we reversed and the tanks on roof were the hot water(solar) and the inside water heaters shut off were cold water.
The home is concrete block, bathroom walls are tile. The drywall has very little room underneath. As the wood mounting strips are only about 1/2 inch. And that is where the wires are.
The plumbing comes up from under the slab. Does not go behind the wall
How about renting a thermal camera to detect where the leak is underneath and the location of the pipe? As for a solution, it's difficult to add anything without being on site. Do you have any photographs of your foundation before concrete was poured?
With lime erosion being a serious problem in FLA don't hesitate to fix that. I had this problem in my last house. Rent a concrete saw or pay someone to cut out the section of concrete. Replace the bad pipe. throw in stone base. pour a patch.
Pex over ceiling is cost effective, then the copper pipes can rot away without regard. It is a given the copper is eaten and gonna fail completely. Concrete eats pipes unless they are pvc or cpvc.
Originally Posted By: Cujet
I'd prefer to tunnel under than to cut the slab. Nice tile and all that.
Don't overlook the aforementioned plastic-pipe-inside-the-copper solution. Much less expensive and disruptive than tunneling or digging up the house floor.
