Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
95 registered members (4WD, 2015_PSD, 53' Stude, A310, 69Torino, 16 invisible), 1,831 guests, and 33 spiders.
Topics296,968
Posts4,962,592
Members67,009
Most Online2,821
Yesterday at 01:32 PM
Metal sheds/garages #4715828
04/04/18 07:03 AM
04/04/18 07:03 AM
OH
grampi Online content OP
grampi  Online Content OP
OH
I am thinking about getting a metal shed/garage. It will do double duty as both a shed and a garage. It will be 10' X 20' in size, and will have a garage door on both ends. I would rather have a wooden structure, but they are about double the price of the metal ones. I am hearing that these metal sheds sweat like crazy, which means everything kept inside will be covered with condensation a lot of the time. If this is true, it's simply not acceptable to have this taking place with the vehicle I plan on keeping inside. Is there any way to ventilate these sheds so this doesn't happen, or is what I heard not true?
Re: Metal sheds/garages [Re: grampi] #4715849
04/04/18 07:19 AM
04/04/18 07:19 AM
Minnesota
Lapham3 Offline
Lapham3  Offline
Minnesota
I put up a metal sheeted 'pole building' some years ago and used thin insulation batts with a plastic vapor barrier in the ceiling. It was a bit of a labor fuss but wasn't expensive and did the job as no dripping.
Re: Metal sheds/garages [Re: grampi] #4715850
04/04/18 07:19 AM
04/04/18 07:19 AM
One Step Beyond
MasterSolenoid Offline
One Step Beyond
I could see the 'inside' metal wall being damp as it would collect moisture from the air.
Just like your bathroom mirror steams up when you take a shower.
Check the shed manufacturer for venting options.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Metal sheds/garages [Re: grampi] #4715862
04/04/18 07:37 AM
04/04/18 07:37 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I'm going to be putting up one of the 10x17 harbor freight tarp garages. It's a good way to get around zoning regulations that don't allow for permanent structures or sheds.
Those also have issues with condensation. I'm planning on elevating mine an inch or two so it has airflow under it.
If you're building a permanent structure, you could probably do a fan or dehumidifier.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Metal sheds/garages [Re: grampi] #4715966
04/04/18 08:34 AM
04/04/18 08:34 AM
PimTac Offline
PimTac  Offline
You will need to install a turbine style ventilator on the roof.
Cannot see signatures any longer so it doesn’t matter.
Re: Metal sheds/garages [Re: grampi] #4716077
04/04/18 10:16 AM
04/04/18 10:16 AM
Arkansas
Win Offline
Win  Offline
Arkansas
I have a metal one bigger than what you are talking about, on a slab, overhead door and entry door on one end only, and I've never observed this. They're not that tight.
As an aside, I have a side business selling these things, wood frame and metal, from several manufacturers, and no one has ever complained about this. Despite the low cost, metal ones are poor sellers.
If you already have a slab, or will pour one, the metal ones are okay; they are more vulnerable to wind damage in my experience.
If crime is an issue, the metal ones can be breached with tin snips; the wood ones can be made more secure, but can also be broken into.
09 Torrent 3.6 V6 M1 0/30
09 Solstice 2.4 I4 Fram 5/30
08 G8 3.6 V6 ST Syn 5/30
04 Xj8 4.2 V8 Hav 5/40
99 S-10 2.2 I4 RECOVERED
94 Xj12 6.0 V12
Re: Metal sheds/garages [Re: grampi] #4716224
04/04/18 12:34 PM
04/04/18 12:34 PM
PA
ridgerunner Offline
ridgerunner  Offline
PA
Spray foam insulation on the inside and vent properly
Re: Metal sheds/garages [Re: grampi] #4716276
04/04/18 01:16 PM
04/04/18 01:16 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Off topic: Will that be big enough? Your Corolla is 15' long and if you leave 2' behind it so you can walk behind the car, there's maybe 3' left of room in front of the car for using it as a shed. Just an idea.
2015 Hyundai Sonata 2.4L 90k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Metal sheds/garages [Re: Nick1994] #4716864
04/05/18 06:03 AM
04/05/18 06:03 AM
OH
OH
There will be nothing else in the shed when the car is in there...and it's not for my Corolla, it will be for my Vette...
Re: Metal sheds/garages [Re: grampi] #4721440
04/09/18 09:52 AM
04/09/18 09:52 AM
OH
OH
I am now thinking of going with a carport instead. 3 full length walls will keep the vehicle dry and out of the sun, and with it being open I won't have any condensation issues...
Re: Metal sheds/garages [Re: grampi] #4721453
04/09/18 10:03 AM
04/09/18 10:03 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
It still see some condensation of course, dew/frost on many nights, but out of the rain and sun is better than nothing for sure.
I'd think your small metal garage idea with a insulated slab and spray foam insulation would be ideal though. Heat it with a small electric baseboard and it will be dry 99% of the time.
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: Metal sheds/garages [Re: IndyIan] #4722417
04/10/18 06:00 AM
04/10/18 06:00 AM
OH
OH
How can there be condensation inside when one end is completely open?
Re: Metal sheds/garages [Re: grampi] #4722441
04/10/18 06:36 AM
04/10/18 06:36 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Just simple thermal differences.
My wife and I were out in our (stone) garage a few weeks back. It was a horribly rainy day, so we were in there cleaning up and organizing stuff. It was also pretty cold.
Had the two garage doors open, so one end was "completely open".
EVERYTHING had condensation on it.
With the garage closed, everything was cold, and the humid air was effectively out of the little microclimate (as poorly sealed as the garage it - I like it to "breathe". One end open, and the humid air could readily mix and condensate on anything and everything.
Re: Metal sheds/garages [Re: grampi] #4722444
04/10/18 06:40 AM
04/10/18 06:40 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Has been used historically to make "air wells".
Open form structures that intentionally use thermal mass and surface area to form collectable condensation.
