Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on ‚Äúclearance‚ÄĚ at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
26 registered members (BlakeB, avi1777, AHernandez, Aero540T, billt460, 3 invisible), 517 guests, and 56 spiders.
Topics286,171
Posts4,903,558
Members67,572
Most Online2,967
Mar 10th, 2019
Page 1 of 6 1 2 6
1.5L Honda turbo oil dilution #4715610
04/03/18 09:57 PM
04/03/18 09:57 PM
Ontario, Canada
Highkm Offline OP
Highkm  Offline OP
Ontario, Canada
1st oil change on 2017 Honda CR-V 1.5l turbo. Note the level of fuel in oil. I has 20% of oil life before I changed the oil. I did very few short trips I.e less than 10km about 20 times in 11,000 Kimís. I would say that Honda should limit the first use of oil to 5000kms otherwise the viscosity goes below acceptable levels. What do you think?
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4715622
04/03/18 10:11 PM
04/03/18 10:11 PM
Ontario, Canada
Highkm Offline OP
Highkm  Offline OP
Ontario, Canada
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4715632
04/03/18 10:26 PM
04/03/18 10:26 PM
PimTac Offline
PimTac  Offline
There are lots of threads here regarding this engine and fuel dilution. I would go no more than 5000 miles on any oil.
Cannot see signatures any longer so it doesn’t matter.
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4715637
04/03/18 10:42 PM
04/03/18 10:42 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I would of changed FF at like 1-2k miles but thats just me. Why not try 8000 miles and re-test? My guess is around 8k your visc will have dropped to just about threshhold.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4715642
04/03/18 10:51 PM
04/03/18 10:51 PM
TX
parshisa Offline
parshisa  Offline
TX
How did the level look like on the dipstick? How much have you drained? I bet it was over 4qts. Just run premium gasoline and real synthetic oil and fuel dilution will be almost gone.
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4715661
04/03/18 11:21 PM
04/03/18 11:21 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Looks like the flashpoint is down, as well.
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4715673
04/03/18 11:31 PM
04/03/18 11:31 PM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
Call/send this to Honda and ask if this is acceptable.
My guess?
They blame your driving style whatever it may be.
08 Honda Accord EX-L 2.4L M1 EP 0w20 153k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 199k
95 Yamaha Jog
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4715708
04/04/18 12:54 AM
04/04/18 12:54 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
This reminds me of the first oil change I had done on my old Daihatsu back in 2007 except that my KV100, after 9000 miles, was even lower at 5.0 cst! My old car had a 1.0 litre normally aspired 3-pot so what you've found isn't unique by any means to Honda Turbos.
The good news is that your primary wear metals are relatively low and nothing to worry about. Remember that wear metal levels are usually at their highest at the first OCI as the engine beds in. I'd expect the numbers to drop back somewhat for subsequent oil changes.
I note that you're from from Canada so this oil has been subjected to driving in some exceptionally cold conditions and this will have contributed massively to the fuel dilution problem. Normally I'd say something here about Global Warming but it only revs up the mouthfrothing brigade so I won't! The other thing I've often wondered with these Honda engines is whether the coolant thermostat is set too low & oil seldom gets up to a temperature conducive to stripping condensed gasoline out of the oil.
It could of course be an issue with thin, low tension rings not adequately sealing the cylinders (the most likely cause on my Daihatsu). This kind of thing is great for fuel economy but bad for blow-by (which drives fuel dilution). Having a turbo will undoubtedly exacerbate blow-by. There's not much you can do about this.
Your Honda factory fill oil will be as good as it gets. Changing to another synthetic won't help you one iota. If the fuel dilution issue persists & bothers you, maybe move to a 5W30. With the fuel dilution, it will over time 'thin' to around about a 0W20.
If you're feeling adventurous, talk to Honda about replacing the radiator cap; one with a higher temperature set-point. It might be what this engine needs to purge the condensed gas from the sump.
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4715750
04/04/18 05:02 AM
04/04/18 05:02 AM
Suomi
Bjornviken Offline
Bjornviken  Offline
Suomi
And use a acea a5 spec
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4715786
04/04/18 06:53 AM
04/04/18 06:53 AM
key largo,fl
henni Offline
henni  Offline
key largo,fl
For some reading, check our the crv forum on this topic
Here and Here
Re: 1.5L Honda turbo oil dilution [Re: Rolla07] #4715835
04/04/18 08:10 AM
04/04/18 08:10 AM
Ontario, Canada
Highkm Offline OP
Highkm  Offline OP
Ontario, Canada
Iíve dropped in Amsoil 0w20 XL and will run for 8000km at which point Iíll extract some oil and send to lab. I think I understand now why Honda puts lots of molybdenum into ff oil. Metal to metal contact is expected during breakin period and with dilution even more so. Molybdenum slows down the wear but does not prevent proper break-in. That being said I donít think Hondaís ff is good enough to go full term without serious premature engine wear. New engineers at Honda have yet to experience long term effects of oil fuel dilution.
Re: 1.5L Honda turbo oil dilution [Re: parshisa] #4715844
04/04/18 08:17 AM
04/04/18 08:17 AM
Ontario, Canada
Highkm Offline OP
Highkm  Offline OP
Ontario, Canada
I have drained 3.7 or 3.8 L roughly. I check the dipsticks twice a week. If it were 4L it would smell of gasoline quite a bit at that would be more than 10%. That would also indicate a serious design flaw as well as bad software, enough to get me out of the vehicle.
Re: 1.5L Honda turbo oil dilution [Re: SonofJoe] #4715853
04/04/18 08:24 AM
04/04/18 08:24 AM
Ontario, Canada
Highkm Offline OP
Highkm  Offline OP
Ontario, Canada
These new crvs definitely do not warm up fast in cold Canadian weather and I am sure it greatly contributes to the dilution.
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4715856
04/04/18 08:25 AM
04/04/18 08:25 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Very high wear metals. It's no surprise with ultra thin oil in a highly loaded, turbocharged, direct injection engine. I'll bet you a dollar the wear metals decrease markedly with higher viscosity. It seems there have been a handful of engine failures too. Keep on top of it.
Re: 1.5L Honda turbo oil dilution [Re: Highkm] #4715877
04/04/18 08:47 AM
04/04/18 08:47 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
High octane fuel and Real synthetic.
Good luck finding a real synthetic.
Wait till you hit 15Kkms.
Wear-in reports always look bad, but,
that fuel dilution% is atrocious though.
I don't know if it will go away; reads like a ring/pistion design flaw.
AGAIN.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Page 1 of 6 1 2 6
