2019 Subaru Crosstrek FB20D - Oil choices
by cluster5. 03/26/19 09:31 PM
.05 Cent haynes manual
by Jman26063. 03/26/19 09:02 PM
Pennzoil Canada Rebate
by Snagglefoot. 03/26/19 09:01 PM
Burned out blinker
by Chris142. 03/26/19 09:00 PM
Best Moly add for timing chain health?
by RichR. 03/26/19 08:53 PM
Kenmore dishwasher quit.
by Trotter. 03/26/19 08:49 PM
Urethane with integrated clear coat cure time?
by FixItDad28. 03/26/19 08:39 PM
Chevron rykon premium mv alternative?
by Framer. 03/26/19 08:12 PM
Got a bunch of new old stock oil and filters...
by dogememe. 03/26/19 07:04 PM
Right turn signal blinking super fast
by das_peikko. 03/26/19 06:55 PM
Another fun car to work on.
by Chris142. 03/26/19 06:48 PM
Equivalent LED T8/T12 tubes?
by y_p_w. 03/26/19 06:37 PM
Do you use chemicals on your lawn?
by ZZman. 03/26/19 05:21 PM
Baked Cabbage Steaks
by StevieC. 03/26/19 02:57 PM
Best Store Bought BBQ Sauce?
by Redright9. 03/26/19 02:26 PM
Hankook tire rebate
by FordBroncoVWJeta. 03/26/19 01:14 PM
Framer, Joe_Gibbs, PerryPerrister, brak132, mike001100
67635 Registered Users
94 registered members (555, 2015_PSD, 4WD, 2010Civic, 2002 Maxima SE, 928, 9 invisible), 1,895 guests, and 97 spiders.
Topics286,475
Posts4,909,129
Members67,635
Most Online2,967
Mar 10th, 2019
Less zinc in Quaker State Defy High Mileage #4715140
04/03/18 12:28 PM
04/03/18 12:28 PM
SE British Columbia, Canada
Snagglefoot Online content OP
Snagglefoot  Online Content OP
Iíve been running Quaker State Defy High Mileage in an older car with good results controlling oil seal leaks. The PQIA just released some results which were covered in a post last week. The Defy product used to advertised on the front of the bottle as having a higher level of zinc. Now the Defy brand name only shows up on the back of the bottle and while it does talk about zinc, according to tests done by the PQIA in 2014 and 2018, the zinc level has gone from 1071 ppm to 890 ppm. Anyone know the full story on why Quaker State has made that move? Itís like itís now more in line with the other High Mileage oils.
If you want the job done right......do it yourself.
Re: Less zinc in Quaker State Defy High Mileage [Re: Snagglefoot] #4715159
04/03/18 12:50 PM
04/03/18 12:50 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Zinc doesn't do anything for controlling seal leaks. As tribologists like MoleKule have said repeatedly, the chemistries of additives is changing over time, and many of the new anti-wear and detergent compounds will not show up on a $30 VOA/UOA. Your engine will never even notice the difference between 1000ppm and 900ppm.
Oil technology is advancing at a rate faster than our want to pay to know what's actually in it.
Re: Less zinc in Quaker State Defy High Mileage [Re: Snagglefoot] #4715170
04/03/18 01:00 PM
04/03/18 01:00 PM
Yep, I agree zinc has nothing to do with seals, and the anti-wear additives are more sophisticated. I just get a kick out of the old QS advertising campaign that Defy will Ēget rid of 98% of future wearĒ or something to that effect. smile
Re: Less zinc in Quaker State Defy High Mileage [Re: Snagglefoot] #4715178
04/03/18 01:07 PM
04/03/18 01:07 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Marketing sells :^)
Re: Less zinc in Quaker State Defy High Mileage [Re: Snagglefoot] #4715183
04/03/18 01:14 PM
04/03/18 01:14 PM
Check the address on the next posting. They must have paid Dale a few bucks for this one.
Re: Less zinc in Quaker State Defy High Mileage [Re: Snagglefoot] #4715184
04/03/18 01:15 PM
04/03/18 01:15 PM
Re: Less zinc in Quaker State Defy High Mileage [Re: Snagglefoot] #4715402
04/03/18 05:45 PM
04/03/18 05:45 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Both QS Defy and M1 HM have dropped their zinc levels in the last year or so, it's been talked about before.
Why? I assume so that the IlSAC grades (20 & 30) can claim API SN rather than API SL. I assume that seeing the old SL spec may turn some people off, thinking it's old, when in fact both would meet all the modern SN quality standards except the Phos level limit.
I like ZDDP as an add as it acts as both an anti-wear agent to protect the engine metal and as an anti-oxidant to protect the oil from degrading. A little extra doesn't hurt anything, Penrite PCMOs in Australia have been using 1000 to 1200 ppm zinc for decades, with no reported problems.
Castrol Edge 5W30 A3/B4 is a Euro Full Synthetic that carries the OEMs of BMW LL-01 and MB 229.5, yet it is "only" API SL. Castrol clearly say, it meets all the quality standards of SN, but is above the Phos limits. I believe it has about 1000ppm zinc like most long life Euro oils.
Oil burning Audi, BMW, MB, etc have been surviving for years on ~ 1000 ppm zinc oils without destroying their exhaust cats anymore than people running a GM or Honda on ILSAC levels (~ 800 ppm zinc) oils.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Less zinc in Quaker State Defy High Mileage [Re: Snagglefoot] #4715440
04/03/18 06:33 PM
04/03/18 06:33 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I usually just add some Rislone Zinc to the oil for older cars. For a 5qt system 1 oz will bump it 75 ppm so 4-5 oz will bring you up to 1100-1200 ppm SL levels with 800 ppm SN oils.
https://www.walmart.com/ip/Rislone-3X-Co...13=&veh=sem
Re: Less zinc in Quaker State Defy High Mileage [Re: Snagglefoot] #4715469
04/03/18 06:51 PM
04/03/18 06:51 PM
Northeastern Vermont
littleant Offline
littleant  Offline
I noticed the change when they went to synthetic blend. Do not see it in conventional any more.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Less zinc in Quaker State Defy High Mileage [Re: Snagglefoot] #4715496
04/03/18 07:19 PM
04/03/18 07:19 PM
Iím thinking they are planning on dropping the Defy name and the whole zinc thing.
Re: Less zinc in Quaker State Defy High Mileage [Re: Snagglefoot] #4715689
04/04/18 12:04 AM
04/04/18 12:04 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Several high mileage oils have not only gone SN, but SN/GF-5. I think Defy is one of them. Snafflefoot might remember it wasn't too terribly long ago when some of the Shell HM products (and some competitors, too) had no API markings on them whatsoever.
Plain, simple Garak.
Re: Less zinc in Quaker State Defy High Mileage [Re: Snagglefoot] #4715701
04/04/18 12:25 AM
04/04/18 12:25 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
HDEO's if you still want Zn for an older flat tappet motor.
However, saying that - Chevron claims 50% less wear with their new CK4 HDEO's, even with reduced Zn for the mixed fleet crowd. Sounds like marketing to me ... Except that FedEX, UPS, the State of Cali, and many other have enough lawyers to make Chevron eat those words if it's just marketing ...
So my bet is Chevron knows what they are saying and they are using new organic AW compounds to reduce wear. I'll bet they are for real trade secrets that will take us years to unravel ... laugh
Re: Less zinc in Quaker State Defy High Mileage [Re: BrocLuno] #4716155
04/04/18 12:35 PM
04/04/18 12:35 PM
California
nthach Offline
nthach  Offline
California
I would ask my contact over at Chevron... but she works in Oronite on drivetrain lubricants through.
Also, as good as Chevron is(and I would happily run Supreme or Havoline in the Toyotas I maintain even though Prii have a nasty habit of drinking oil and the MZ family V6s can turn oil into sludge despite the fact the local dealer uses Chevron in everything), they aren't kryptonite either. Ford still hasn't approved Delo for the newest Powerstrokes yet.
