Account and posts removal
by newbe46 - 09/16/19 10:00 PM
Yamaha EF2800i break-in
by Uregina09 - 09/16/19 09:43 PM
Adding TCW3 to Gas Tank?
by maverickfhs - 09/16/19 08:45 PM
Motul 75w90 1L 12 pack $13.25
by wkcars - 09/16/19 08:36 PM
2019 Ford Fusion vs used?
by FL-400S - 09/16/19 08:33 PM
What is the reasoning for 2-fuel tanks on a rv?
by RazorsEdge - 09/16/19 07:54 PM
Thoughts and opinions on family haulers
by ram_man - 09/16/19 07:53 PM
2018 Silverado 5.3L M1 AFE 0W-20 5,065
by K20FA5 - 09/16/19 07:43 PM
18 Jeep 3.6 PPU 0w20 5k OCI
by IndyFan - 09/16/19 07:06 PM
Federal 9mm 115g FMJ Brass - $7.97/50 @ Walmart
by blupupher - 09/16/19 06:47 PM
Motorcraft FL-1995W different than than non-W?
by Cubey - 09/16/19 05:31 PM
1973 Bronco w/original 302
by BKinSD - 09/16/19 05:18 PM
B&S 21hp burning oil
by Mike141 - 09/16/19 04:28 PM
Prime Guard POF2222 C&P...
by AnthemBassMan - 09/16/19 03:36 PM
Verizon FIOS direct connect HD local channels
by Vikas - 09/16/19 02:36 PM
Bentonite grease abrasive properties?
by berlyn - 09/16/19 02:19 PM
'13 Camry, ATF replacement
by parshisa - 09/16/19 02:02 PM
R0CKETMAN, Southbend9, Bigaledge32, emilio15, Kokopelli34179
69303 Registered Users
60 registered members (AdditiveOCD, bdcardinal, ArrestMeRedZ, A_Spruce, boulderdentist, 6 invisible), 1,342 guests, and 26 spiders.
Topics294,667
Posts5,064,154
Members69,303
Most Online3,532
Jul 30th, 2019
Napa Gold 1515 and 1452 #4714300 04/02/18 04:32 PM
M
mobilaltima Offline OP
M
Can these two filters interchange besides the 1515 having a silicone ADBV and lower burst pressure of 290 vs the 1452 having a nitrile ADBv and burst pressure of 415 psi? All other specs are the same. I'd be using it on a '96 F150 with the 302 V8. the 1515 is the spec'd filter.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: Napa Gold 1515 and 1452 [Re: mobilaltima] #4714303 04/02/18 04:39 PM
Z
ZeeOSix Offline
Z
Both should work fine if burst pressure and ADBV material is the only difference. I'd go with silicone ADBV if using the filter for long OCI or in really cold weather.
Re: Napa Gold 1515 and 1452 [Re: mobilaltima] #4714311 04/02/18 04:49 PM
Chris142 Offline
yes. My scout called for the 1452 if using Wix filters. Ph8a ,fl1a etc if using other brands.
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Napa Gold 1515 and 1452 [Re: ZeeOSix] #4714463 04/02/18 07:31 PM
L
Linctex Offline
L
For any filter , in any weather.
Re: Napa Gold 1515 and 1452 [Re: Linctex] #4714485 04/02/18 07:44 PM
Z
ZeeOSix Offline
Z
A silicone ADBV isn't always needed depending on use conditions, as I mentioned before. But yeah, it certainly doesn't hurt to always use a filter with a silicone ADBV.
Re: Napa Gold 1515 and 1452 [Re: mobilaltima] #4714618 04/02/18 10:15 PM
Dyusik Online Content
Online Content
I use the 1515 on the Harley, silicon is a must on that toaster. Bust pressure of 200+ psi, with bypass opening at 8. Internal bypass will be open long before burst pressure is achieved, and if you manage to blow it up, you are doing something wrong. My guess is the more structurally sound filter will filter less, with more coarse fibers giving it ability to withstand such pressures.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 111K Frankenbrew, WIX 57173 (4 sale)
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 41k Idemitsu 0w20, WIX 57047
18 RAM 3500 2k VWB 15w40, DBL7349
