White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
31 registered members (billt460, claluja, c502cid, Cornershop, carlprop, 4 invisible), 840 guests, and 30 spiders.
Topics296,866
Posts4,960,379
Members66,982
Most Online2,688
Jan 19th, 2019
2016 Caravelle 19 EBO Bowrider - Trailer w/o brake #4714323
04/02/18 04:02 PM
04/02/18 04:02 PM
NY, USA, etc.
oilpsi2high Offline OP
NY, USA, etc.
Im looking at a boat for this season and found one for sale locally.
The boat is 1800 lbs dry, trailer id imagine is 800.
NY requires brakes if laden is over 3k and unladen over 1000. So this just barely passes.
Im just surprised the factory trailer doesnt cone with brakes. Fortunately the launch is 8 miles from my house and mostly flat. Id be towing with an 03 Dakota, 4.7 manual 4x4.
Should i install aftermarket brakes, or will it not be noticeable on such a short drive? Id like to take it to ofher lakes in the area, and those have hills.
Re: 2016 Caravelle 19 EBO Bowrider - Trailer w/o brake [Re: oilpsi2high] #4714336
04/02/18 04:19 PM
04/02/18 04:19 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I am curious as well because I have always noticed in owners manuals how the auto trans always has a higher towing capacity, and I have always wondered why. I have never towed anything with a manual trans.
I would argue that if you are within the laws you are probably cool, as I assume the law would be conservative with their requirements. Perhaps optimized brake pads just for the confidence boost.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: 2016 Caravelle 19 EBO Bowrider - Trailer w/o brake [Re: maxdustington] #4714345
04/02/18 04:34 PM
04/02/18 04:34 PM
wv
krismoriah72 Offline
wv
Semi Metallic pads and good safe following distances will get you where you need to go.
Imagine all the boats and travel trailers etc that were towed in the 50s, 60s, 70s, 80s with drum brakes. Alot of them towed with station wagons full of kids.
Re: 2016 Caravelle 19 EBO Bowrider - Trailer w/o brake [Re: oilpsi2high] #4714349
04/02/18 04:37 PM
04/02/18 04:37 PM
NY, USA, etc.
NY, USA, etc.
I actually think my trucks owners manual says trailer brakes are needed over 2000 lbs.
Re: 2016 Caravelle 19 EBO Bowrider - Trailer w/o brake [Re: oilpsi2high] #4714369
04/02/18 04:54 PM
04/02/18 04:54 PM
Northern Ontario, Canada
Danno Offline
Danno  Offline
The boat with fuel added is sure to be 2,000 lbs and then you have the trailer at 800 lbs. So, looks like you do need trailer brakes.
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: 2016 Caravelle 19 EBO Bowrider - Trailer w/o brake [Re: oilpsi2high] #4714484
04/02/18 06:42 PM
04/02/18 06:42 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I've pulled my single axle trailer with no brakes when it weighed closed to 3,500 pounds with the Trailblazer. It stopped ok, not great but certainly enough.
Buy it and determine yourself if it stops ok. If you aren't towing long distances or in mountains i wouldn't worry.
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: 2016 Caravelle 19 EBO Bowrider - Trailer w/o brake [Re: oilpsi2high] #4714520
04/02/18 07:20 PM
04/02/18 07:20 PM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
If it were me, I wouldn't bother. Trucks are built with towing in mind. Given the trailer weight, you have to realize the limitations though-- The truck's brakes are probably only good for light to moderate breaking over a long distance. And perhaps one good panic stop before the brakes get too hot. That means no mountain passes, or other severe duty driving. Only you'll know for sure when you drive the truck. I wouldn't equip the trailer with brakes until then. I've driven trucks with not enough brake hauling loaded trailers, and you'll immediately know if that's the case within a couple miles. It's what you're comfortable with for your driving conditions. Do you want to do 35mph the whole way giving LOTS of distance, or 65 with erratic drivers all around you? You wont know which you'll be facing until you actually drive the truck with said trailer.
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40 HDEO
04 Odyssey EX 184k Valv. Durablend 5w-30
96 Maxima GLE 255k Castrol Edge EP 5w-20
07 Chrysler Pacifica Limited 4.0L 134k Chevron Supreme 5w-20
Re: 2016 Caravelle 19 EBO Bowrider - Trailer w/o brake [Re: oilpsi2high] #4714834
04/03/18 06:42 AM
04/03/18 06:42 AM
Middle of Iowa
DriveHard Offline
DriveHard  Offline
Middle of Iowa
I had an 18' Bayliner (very similar size and weight) and a trailer with no brakes. I towed it no problem with a Saturn Vue. I think you will be fine. Just take it slow and drive smart.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: 2016 Caravelle 19 EBO Bowrider - Trailer w/o brake [Re: oilpsi2high] #4715277
04/03/18 01:58 PM
04/03/18 01:58 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Check out a 19" Crownline instead. Even if you have to go a few years older to get the price down.
