Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
PARTS PLUS PH 2876 CUT OPEN
by 53' Stude. 04/17/19 06:18 PM
'13 Mazda5 oil change?
by pandus13. 04/17/19 05:02 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
39 registered members (billt460, A1O, Billbert, bbhero, Bailes1992, 6 invisible), 634 guests, and 25 spiders.
Topics287,672
Posts4,932,028
Members67,838
Most Online2,967
Mar 10th, 2019
Napa Gold 1515 and 1452 #4714300
04/02/18 04:32 PM
04/02/18 04:32 PM
Golden Meadow, LA
mobilaltima Offline OP
Golden Meadow, LA
Can these two filters interchange besides the 1515 having a silicone ADBV and lower burst pressure of 290 vs the 1452 having a nitrile ADBv and burst pressure of 415 psi? All other specs are the same. I'd be using it on a '96 F150 with the 302 V8. the 1515 is the spec'd filter.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: Napa Gold 1515 and 1452 [Re: mobilaltima] #4714303
04/02/18 04:39 PM
04/02/18 04:39 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Both should work fine if burst pressure and ADBV material is the only difference. I'd go with silicone ADBV if using the filter for long OCI or in really cold weather.
Re: Napa Gold 1515 and 1452 [Re: mobilaltima] #4714311
04/02/18 04:49 PM
04/02/18 04:49 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
yes. My scout called for the 1452 if using Wix filters. Ph8a ,fl1a etc if using other brands.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Napa Gold 1515 and 1452 [Re: ZeeOSix] #4714463
04/02/18 07:31 PM
04/02/18 07:31 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
For any filter , in any weather.
Re: Napa Gold 1515 and 1452 [Re: Linctex] #4714485
04/02/18 07:44 PM
04/02/18 07:44 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
A silicone ADBV isn't always needed depending on use conditions, as I mentioned before. But yeah, it certainly doesn't hurt to always use a filter with a silicone ADBV.
Re: Napa Gold 1515 and 1452 [Re: mobilaltima] #4714618
04/02/18 10:15 PM
04/02/18 10:15 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I use the 1515 on the Harley, silicon is a must on that toaster. Bust pressure of 200+ psi, with bypass opening at 8. Internal bypass will be open long before burst pressure is achieved, and if you manage to blow it up, you are doing something wrong. My guess is the more structurally sound filter will filter less, with more coarse fibers giving it ability to withstand such pressures.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 108K oils, wix
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
