Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
98 registered members (02z, anndel, 97K15004WD, 15 invisible), 2,280 guests, and 33 spiders.
Topics296,880
Posts4,960,749
Members66,987
Most Online2,688
Jan 19th, 2019
Archoil AR9100 Additive Any Good? #4714239
04/02/18 02:18 PM
04/02/18 02:18 PM
Jacksonville, FL
Ltmax Offline OP
Ltmax  Offline OP
Jacksonville, FL
Been reading a bunch about how wonderful Archoil is in late model ford Diesel engines and the nanoborate anti wear additives sound like great stuff especially in high performance/high load engines.
Some of my friends have used it with great success elimiating rough running diesel injector issues.
Always been a little skeptical of most oil additives watching many come and go over the years, but if this stuff is as good as advertised, I'm strongly considering using their oil additive in my 2008 Ferarri built Maserati 4.2l gasoline engine.
Any of you experts have experience one way or the other with Archoil?
Many thanks.
Re: Archoil AR9100 Additive Any Good? [Re: Ltmax] #4714244
04/02/18 02:25 PM
04/02/18 02:25 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
The Archoil additive is tailored for the injection system (that uses high pressure oil to actuate the injectors) in primarily the Ford 6.0 diesel (read 6.oh-no). Although several people swear by it in the 6.0 I don't know that it will do much aside from lighten your wallet in your gas engine over a well formulated Euro Spec engine oil.
Luke
Re: Archoil AR9100 Additive Any Good? [Re: Ltmax] #4714254
04/02/18 02:37 PM
04/02/18 02:37 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Chromedome on powerstrokehelp.com sure swears by it. He is usually pretty reliable but can get a little preachy at times.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Archoil AR9100 Additive Any Good? [Re: Ltmax] #4714265
04/02/18 02:54 PM
04/02/18 02:54 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
FWIW there are many, many previous threads on Archoil, some of which are very long and detailed. You may wish to search for them.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Archoil AR9100 Additive Any Good? [Re: bdcardinal] #4714266
04/02/18 02:55 PM
04/02/18 02:55 PM
Jacksonville, FL
Ltmax Offline OP
Ltmax  Offline OP
Jacksonville, FL
I hear some top fuel dragster mechanics swear by it as well to protect the bottom end.
So far I don't see a down side of trying it but wanted to see if any of the chemical engineers who frequent this site had direct first hand experience or had conducted any lab tests not funded by the manufacturer or their competition.
Re: Archoil AR9100 Additive Any Good? [Re: Ltmax] #4714273
04/02/18 03:06 PM
04/02/18 03:06 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Every fuel car I've ever had the pleasure or turning a wrench on or talking to those who did got only one thing dumped in it... SAE 70 2-3 gallons depending on the era. We changed it every pass and after the in pit warmup before the pass. It always came out looking like yellow green frothy slime from the fuel dilution. No need to bother with additives when the engine gets 8 new pistons, rings, connections rods, and a full set of rod and main bearings every pass. No additives would have prevented the failures I've seen. Blackened bearings were usually the fault of the tuneup, broken rods and severed blower studs usually the same thing. For a while we had an issue with yanking all of the main studs out of the block.
Luke
Re: Archoil AR9100 Additive Any Good? [Re: kschachn] #4714284
04/02/18 03:16 PM
04/02/18 03:16 PM
Jacksonville, FL
Ltmax Offline OP
Ltmax  Offline OP
Jacksonville, FL
Been reading this board for many years (without posting any questions) from the searches I've done nearly all the Archoil threads in the past 2 years pertain to how it works in Ford diesel engines or talk about one of their other products (except for the interesting Dutch Coast Guard article).
Was hoping to see if anyone had more current test results over the past few years on AR9100 in gasoline engines.
Thanks Again
Re: Archoil AR9100 Additive Any Good? [Re: Ltmax] #4714286
04/02/18 03:18 PM
04/02/18 03:18 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
The problem with all such additives is that people "swearing" by it, "first hand experience" and testimonials is all you are going to get. You can find various studies on the individual components or purported ingredients, but if you will not find actual and meaningful laboratory tests on the whole additive to either prove or disprove their claims.
The thing is, it's not as if such tests are unknown or impossible to run. You will find too that it's generally the claims are made in such a way that even if the tests were run they wouldn't positively indicate either way (lots of "up to" language).
1994 BMW 530i, 241K
Re: Archoil AR9100 Additive Any Good? [Re: Ltmax] #4714287
04/02/18 03:20 PM
04/02/18 03:20 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
No, you would find them in the same searches that you've already done. Besides, such tests are beyond the scope of anyone on here that I know.
1994 BMW 530i, 241K
Re: Archoil AR9100 Additive Any Good? [Re: Ltmax] #4714332
04/02/18 04:13 PM
04/02/18 04:13 PM
California
mbacfp Offline
mbacfp  Offline
California
I have a UOA with AR9100 in a 3.7 Duratec on here. I used it with Mobil 1 5w20...numbers looked good...can say it quieted the engine vs my current PUP 5w20 without Archoil...will have a UOA without soon.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: Archoil AR9100 Additive Any Good? [Re: mbacfp] #4714362
04/02/18 04:48 PM
04/02/18 04:48 PM
Jacksonville, FL
Ltmax Offline OP
Ltmax  Offline OP
Jacksonville, FL
Awesome, that's exactly what I've been looking for, let me know, very appreciated!
Re: Archoil AR9100 Additive Any Good? [Re: Ltmax] #4714387
04/02/18 05:13 PM
04/02/18 05:13 PM
California
mbacfp Offline
mbacfp  Offline
California
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4533752/Re:_2012_Mazda_CX-9_Oil_Analys#Post4533752
Here it is.
Re: Archoil AR9100 Additive Any Good? [Re: mbacfp] #4714402
04/02/18 05:31 PM
04/02/18 05:31 PM
Jacksonville, FL
Ltmax Offline OP
Ltmax  Offline OP
Jacksonville, FL
Here it is.
Thanks!
Re: Archoil AR9100 Additive Any Good? [Re: Ltmax] #4714808
04/03/18 06:06 AM
04/03/18 06:06 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
It will be interesting to see the results without the additive as a comparison. Unfortunately it will be a different oil though? How will that be meaningful?
1994 BMW 530i, 241K
Re: Archoil AR9100 Additive Any Good? [Re: Ltmax] #4717839
04/05/18 11:17 PM
04/05/18 11:17 PM
[email protected] CZ firearm factory
Marco620 Offline
Marco620  Offline
Archoil 9100 ran well in my uoa but huge potassium. They s'mpled me out some Archoil 9300 which it getting used soon. They have been really good to me.
15' Civic 1.8 i-vtec 207,000 mi 0w20 Redline/Redline CVT/Archoil9200/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/Redline Si-1/87 E0 fuel
Son of a Navy Corpsman. Support vets!
