CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
52 registered members (Anthony, 2015_PSD, A1O, bbhero, Bailes1992, 6 invisible), 676 guests, and 28 spiders.
Topics287,673
Posts4,932,031
Members67,838
Most Online2,967
Mar 10th, 2019
Ford/Mazda Intake Manifold Runner Flaps Ticking #4713900
04/02/18 08:50 AM
04/02/18 08:50 AM
Illinois
Ambition5253 Offline OP
Illinois
A few months ago I purchased a 2008 Ford Fusion SE with the 2.3l Duratec. It has a tick coming from the intake manifold area. I started to investigate and realized that the noise is coming from these flaps that sit in the intake manifold runners. They are controlled by a vacuum solenoid and open/close to better deliver power. When I take the vacuum off the solenoid, the engine is very quiet. After doing some reading in other forums, some have said to replace the solenoid and others say the entire intake manifold must be replaced. Does anyone have experience with this issue? It affects quite a few other Fords and Mazdas. I would really appreciate any advice.
https://www.youtube.com/watch?v=5gaD0TXOASQ - This video shows a 2.0 duratec with the same issue
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: Ambition5253] #4713913
04/02/18 09:07 AM
04/02/18 09:07 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
I had the same problem with a 2007 Focus. Probably the manifold needs to be replaced.
2007 Ford Fusion 240,000 miles
M1 0-20 EP
2017 Ford Fusion 69K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: Ambition5253] #4713914
04/02/18 09:08 AM
04/02/18 09:08 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
That's from reversion pulses. Normal.
But are the flaps screwed on or riveted? They can become loose and buzz then possibly fall off.
This is a major problem with just about any engine that used "tumble valves" in the IM.
Old guys will remember heat riser ticking on dodge and Kreisler in the 60s and 70s. Same effect but different location.
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: ARCOgraphite] #4713922
04/02/18 09:14 AM
04/02/18 09:14 AM
Illinois
Illinois
I appreciate the info. Were you able to do the replacement yourself? Also nice job on getting ~225k out of your fusion so far. Does that one have the 2.3 or 3.0?
The flaps seem to be part of a rod that extends through the runners. I think the rod is plastic and the flaps are part of the mold.
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: Ambition5253] #4713937
04/02/18 09:32 AM
04/02/18 09:32 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
No problem with the Fusion, but the Focus was totaled before I got around to replacing the IM. Here is a video from a guy that just took the valves out.
https://www.youtube.com/watch?v=gRXRMHl34Ho
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: Ambition5253] #4714020
04/02/18 10:47 AM
04/02/18 10:47 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
On some Ford engines the IMRC runners rely on plastic bushings that keep them in place. These bushings wear out and crack after some time. They can make a noise and throw OBD codes.
Is this a factor?
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: Ambition5253] #4714057
04/02/18 11:34 AM
04/02/18 11:34 AM
N.H, U.S.A.
N.H, U.S.A.
Wow that IM is a piece of Junk design !
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: ARCOgraphite] #4714108
04/02/18 12:41 PM
04/02/18 12:41 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Toyotas, Hondas, and BMW have this system as well.
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: tig1] #4714174
04/02/18 02:03 PM
04/02/18 02:03 PM
The Orca
quint Offline
quint  Offline
The Orca
And Nissans....various motorcycles, and plenty others. Intake runner secondary butterflies are very common on MANY cars and bikes, going back quite a few years. it helps cold idle, affects low end torque, and affects emissions as well.
My wife was driving my 240sx on a regular basis for a while and said "The car feels sluggish lately" and I found the vacuum actuator for the secondary flaps was bad, keeping the flaps open full time when they should be pulled closed below 2500 rpm. I replaced it without telling her and she later said "Did you fix the car? It feels a lot peppier than it did".
Some people do away with the flaps and don't notice any difference. On my car, I chose to fix it because its definitely noticeable on this engine when they aren't working right.
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: Reddy45] #4714176
04/02/18 02:04 PM
04/02/18 02:04 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Is this a factor?
Not on these. That is on the 3.8 and 4.2 V6's. The Duratech 4 cylinders you usually have to replace the intake manifold. Sometimes you can get the shutter valve separate.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: ARCOgraphite] #4714180
04/02/18 02:11 PM
04/02/18 02:11 PM
Illinois
Illinois
Assuming you have the 2.3 in your fusion, have you ever had problems with your runner flaps? I wonder if my intake was defective from the factory and never really looked into. As far as taking the flaps out, I wonder what the implications might be.
Is this a factor?
No codes at all, just the ticking. I will keep those bushings in mind. That sounds like a cheaper fix vs an entire new manifold.
I dont mind the plastic manifold so much as I have had them in other cars and I never had an issue. But this runner flap thing is something else...
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: bdcardinal] #4714190
04/02/18 02:22 PM
04/02/18 02:22 PM
Illinois
Illinois
Is this a factor?
Looks like I can get the IMRC Valve/Solenoid separately, Mazda part L301-18-741. Not sure how difficult it would be to replace but Im considering doing the manifold so it shouldn't be any worse. Do you think a new solenoid might fix the problem?
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: Ambition5253] #4714243
04/02/18 03:22 PM
04/02/18 03:22 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
The solenoid generally isn't the problem, it is the actuator valve that on a lot of cars is only serviced with the manifold.
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: tig1] #4714275
04/02/18 04:07 PM
04/02/18 04:07 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
Yes, but apparently their implementation doesn't need replacement.
Thankfully, that device was removed on my B2300 as part of a redesign; early duratech ranger/b2300 are littered with this as a common fix.
2004 Prius; 113K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;135K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Ford/Mazda Intake Manifold Runner Flaps Ticking [Re: Ambition5253] #4714527
04/02/18 08:27 PM
04/02/18 08:27 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I would make sure one is available the same day before fiddling around with the old one.
You may or may not be able to cobble a permanent fix with oilite flange bushings depending on how its put together.
I would grab a used one and play with that, once I had a good repair swap it out. I like doing this type of repair just for fun. We use to bush Q Jet throttle plate shafts this way, the repair was way better than OE,
