Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
32 registered members (bbhero, c502cid, alcyon, anndel, Bailes1992, 4 invisible), 560 guests, and 57 spiders.
Topics286,442
Posts4,908,257
Members67,622
Most Online2,967
Mar 10th, 2019
PCV Oil Catch Can weirdness with new oil... #4713862
04/02/18 07:34 AM
04/02/18 07:34 AM
E. Tennessee
WhizkidTN Offline OP
E. Tennessee
Ok, I've come across something I think is good but weird at the same time.
I've had both PCV and Intake OCCs (Saikou Michi brand) installed for several years now on my SX and loved the way they work. I drain them (never anything on the Intake side, it is always been the PCV side that has fluid) at every oil change. In the winter, you tend to get more water due to cooler temperatures. I would get about 1~2 oz of oily/watery fluid (smelled like gas as well) in the PCV can for every 5K mile driven (my daily driver). That was when I was running M1 0W-40 oil.
I switched to Castrol Edge 0W-40 oil and gotten some better UOA (by Polaris) a while back. At my last OCI this weekend (my third on Castrol), I found basically NO fluids in my OCCs! Only a few drops. I also cleaned mine out with Throttle Body Cleaner just to be sure I had nothing getting fouled up and it was fine. Keep in mind that this GDI turbo engine is very hard on any oil used and this engine normally gets lots of fuel dilution in the oil.
I know that Castrol has a lower NOACK value from the M1 oil I was running, but only thing I can summarize is that I'm getting much less blow-by with the Castrol edge and therefore far less is getting collected in the OCCs. I'll continue to watch it. Car runs strong, never uses oil and has no issues all through this oil brand change (over maybe a years time-frame).
Very strange but I think GOOD news! Thought I'd pass it along.
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (79K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (81K)
>EDGE 0W-20, Fram XG6607
Re: PCV Oil Catch Can weirdness with new oil... [Re: WhizkidTN] #4713868
04/02/18 07:43 AM
04/02/18 07:43 AM
Maryland
malibuguy79 Offline
malibuguy79  Offline
Maryland
Intresting.
I get a little bit of nastyness in mine on my turbo tercel after a few weeks on ST. same catch can BTW
Greg...the exhaust guy
I have a 10 Yaris, 97 Tercel 1nzfe swap coming, 82 Malibu 1uzfe swap in progress, 84 Bonneville street/strip car
She has 18 Fit and 01 Forester
Re: PCV Oil Catch Can weirdness with new oil... [Re: WhizkidTN] #4713995
04/02/18 10:15 AM
04/02/18 10:15 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
The crankcase id filled with oil mist when the engine is running. NOACK is inconsequential in this .
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: PCV Oil Catch Can weirdness with new oil... [Re: WhizkidTN] #4714069
04/02/18 11:53 AM
04/02/18 11:53 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Nice - good on you. Some oils work better in some situations ... smile
Re: PCV Oil Catch Can weirdness with new oil... [Re: CT8] #4714077
04/02/18 12:06 PM
04/02/18 12:06 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Isn't a lower NOACK oil going to produce less "oil mist?" If so that would support the OP's observation.
God Bless Our Troops
Re: PCV Oil Catch Can weirdness with new oil... [Re: demarpaint] #4714261
04/02/18 03:50 PM
04/02/18 03:50 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Noack is oil thickening? The pistons and cylinders etc are lube by oil flinging off of the con rods and crankshaft windage. Depending on the engine the cams and also the rocker arms cams etc splash/fling oil .
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: PCV Oil Catch Can weirdness with new oil... [Re: WhizkidTN] #4714868
04/03/18 08:11 AM
04/03/18 08:11 AM
E. Tennessee
E. Tennessee
FWIW: I should note that with this latest oil change (I do keep it to ~4K miles for my OCI), that I didn't notice as much of a gas smell in the old oil as I might have in the past - but that is very subjective! Again, not really sure what that may mean in the context of what I found with the OCCs, but it is interesting. This weekend, I'll double the PCV valve itself to make sure it is clear and working just to make sure that system if functioning as expected.
Re: PCV Oil Catch Can weirdness with new oil... [Re: CT8] #4715149
04/03/18 12:42 PM
04/03/18 12:42 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I thought it was evaporation loss from heat, and oil thickening as a result, which would back the OP's statement.
