Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
114 registered members (AITG, A310, addyguy, 69GTX, 2009Edge, 10 invisible), 2,130 guests, and 50 spiders.
Topics296,735
Posts4,957,919
Members66,960
Most Online2,577
Jan 14th, 2019
recommendation ATF for worn out clutch pack #4713692
04/01/18 10:04 PM
04/01/18 10:04 PM
Toronto
tookien Offline OP
tookien  Offline OP
Toronto
Hello,
I have 4l60e transmission that leaked out all trans fluid (rusted cooler lines) and likely has worn out clutch pack and seal.
But it still runs but there is a delayed engagement @ 3-4 and just a little jerky on the 1-2 (depending on timing and acceleration), kind of annoying more than anything else.
I want to do another ATF full flush and filter change, but want to experiment a bit to get (possibly) a little smoother shifting. I already changed the solenoids on it.
Do you recommend Dexron 6 blend or full synthetic in this case? And perhaps lubeguard additive on top?
Thanks
Re: recommendation ATF for worn out clutch pack [Re: tookien] #4713697
04/01/18 10:09 PM
04/01/18 10:09 PM
NY
demarpaint Offline
demarpaint  Offline
NY
You could try the spec ATF and a bottle of LG red. It might help a bit, although if the parts are actually worn out I think you'll eventually be looking at a rebuild.
God Bless Our Troops
Re: recommendation ATF for worn out clutch pack [Re: demarpaint] #4713700
04/01/18 10:11 PM
04/01/18 10:11 PM
Toronto
tookien Offline OP
tookien  Offline OP
Toronto
what's spec ATF? is that just the regular Dexron 6 blend or full synthetic?
Re: recommendation ATF for worn out clutch pack [Re: demarpaint] #4713702
04/01/18 10:12 PM
04/01/18 10:12 PM
Toronto
tookien Offline OP
tookien  Offline OP
Toronto
LG has the 32oz, the 10oz and 2oz bottles.
the more the better?
Re: recommendation ATF for worn out clutch pack [Re: tookien] #4713706
04/01/18 10:22 PM
04/01/18 10:22 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Maxlife and LG red, the BITOG transmission elixir.
I assume he meant whatever atf is specified for your vehicle. Depending on age dexron 3?
I know how those shifts you describe feel, especially that 1-2.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: recommendation ATF for worn out clutch pack [Re: demarpaint] #4713707
04/01/18 10:22 PM
04/01/18 10:22 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
NO ATF fluid in the world (NONE) will fix a worn clutch pack.
Re: recommendation ATF for worn out clutch pack [Re: maxdustington] #4713716
04/01/18 10:35 PM
04/01/18 10:35 PM
Toronto
tookien Offline OP
tookien  Offline OP
Toronto
thanks, and it's a 2007.
I'm not sure if it's a myth or just plain misinformation, but I have read that fully synthetic ATF can be "too slippery" for the clutches.
Is that true? would it therefore be beneficial not to use fully synthetic if the clutch pack is (slightly) worn and therefore more friction the better?
Re: recommendation ATF for worn out clutch pack [Re: tookien] #4713738
04/02/18 12:01 AM
04/02/18 12:01 AM
FL
mcrn Offline
mcrn  Offline
FL
That is not true.....the add pack will determine how "slippery" the fluid is.
2012 Nissan Rogue
Re: recommendation ATF for worn out clutch pack [Re: tookien] #4713765
04/02/18 03:07 AM
04/02/18 03:07 AM
Kuwait
Falcon_LS Offline
Falcon_LS  Offline
Kuwait
You're probably fighting a losing battle here, but I would skip the Dexron-VI and go with a thicker fluid, like TES-295 and add 16 oz. of LubeGard Red with it. The esters in LubeGard might help some, but it's no guarantee.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
03 Expedition SSV: XG2
05 Envoy: XG9837
06 XJ8L: C2C41611
07 SRX: XG8765
Re: recommendation ATF for worn out clutch pack [Re: tookien] #4713766
04/02/18 03:37 AM
04/02/18 03:37 AM
NY
demarpaint Offline
demarpaint  Offline
NY
The 10oz bottle is good for most automatic transmissions. You can shoot them an email and they'll give you a dose/per quart of ATF, then base it on the transmission's capacity.
Re: recommendation ATF for worn out clutch pack [Re: tookien] #4713796
04/02/18 04:51 AM
04/02/18 04:51 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
If the clutches are worn out or missing friction material its a done deal. You cant fix broke.
Re: recommendation ATF for worn out clutch pack [Re: tookien] #4713878
04/02/18 07:15 AM
04/02/18 07:15 AM
Kevil,Ky
vwmaniaman Offline
vwmaniaman  Offline
Kevil,Ky
I have read that the old Ford style fluid is thicker and can help with low pressures and slow shifts.
Don't waste your time on a slipshod repair.
Re: recommendation ATF for worn out clutch pack [Re: vwmaniaman] #4713882
04/02/18 07:19 AM
04/02/18 07:19 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Yes but it won't replace worn out material or a unit in need of a rebuild as I alluded to earlier.
Re: recommendation ATF for worn out clutch pack [Re: tookien] #4713984
04/02/18 09:06 AM
04/02/18 09:06 AM
CT USA
Mc357 Offline
Mc357  Offline
CT USA
Is the 1-2 hard shift a bad sign? I have a 2000 Silverado same transmission, with the same feel 180k Miles, and a rebuilt transmission about 60k ago.
Re: recommendation ATF for worn out clutch pack [Re: tookien] #4714064
04/02/18 10:42 AM
04/02/18 10:42 AM
Tennessee
chrly919 Offline
chrly919  Offline
Tennessee
Maxlife ATF and Lubeguard Red. What have you got to lose? Won't fix it but it will make it more comfortable until it expires grin
99 Honda CRV AWD 250k
PHM 5w30 Purolator PureOne
14 Jeep G Cherokee Limited
93 Corvette coupe M1 5w30
01 Corvette coupe M1 5w30
