White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
29 registered members (billt460, claluja, c502cid, Cornershop, carlprop, Black_Thunder, 3 invisible), 844 guests, and 31 spiders.
Topics296,866
Posts4,960,379
Members66,982
Most Online2,688
Jan 19th, 2019
Pin from Parking brake cable to parking brake fell #4713658
04/01/18 09:04 PM
04/01/18 09:04 PM
Mississippi
PhuongFU Offline OP
PhuongFU  Offline OP
Mississippi
The pin that holds the parking brake cable to the parking brakes/expander fell out due to some negligence from me and Iím not sure what would be the best way to put it back together. When I reassemble it, it just falls out again. Iím thinking soldering or maybe liquid steel/jb weld. What do you guys think?
Re: Pin from Parking brake cable to parking brake fell [Re: PhuongFU] #4713678
04/01/18 09:40 PM
04/01/18 09:40 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Was it peened in the first place? I cannot remember if the pin is held in place by the sides of the other part of the expander.
Is it possible to wham it with a cold chisel and expand it?
Re: Pin from Parking brake cable to parking brake fell [Re: Kira] #4713710
04/01/18 10:28 PM
04/01/18 10:28 PM
Mississippi
PhuongFU Offline OP
PhuongFU  Offline OP
Mississippi
Iím not sure, but it just falls out now. Thinking of crimping the sides/edges or maybe use liquid steel or solder.
Re: Pin from Parking brake cable to parking brake fell [Re: PhuongFU] #4713792
04/02/18 04:49 AM
04/02/18 04:49 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I see a pin, a bracket and a cable. Is it part of the cable that fell off? What kind of car is this for?
Re: Pin from Parking brake cable to parking brake fell [Re: PhuongFU] #4714047
04/02/18 10:22 AM
04/02/18 10:22 AM
PimTac Offline
PimTac  Offline
It seems like we are missing something here. Is there supposed to be a retainer of some sort or another part that holds the pin in place? Knowing the make and model of car would help.
Cannot see signatures any longer so it doesn’t matter.
Re: Pin from Parking brake cable to parking brake fell [Re: PimTac] #4714189
04/02/18 01:21 PM
04/02/18 01:21 PM
Trav Offline
Trav  Offline
I'm thinking it may look something like this.
Re: Pin from Parking brake cable to parking brake fell [Re: Trav] #4714355
04/02/18 04:43 PM
04/02/18 04:43 PM
PimTac Offline
PimTac  Offline
By jove I think you got it Trav.
Re: Pin from Parking brake cable to parking brake fell [Re: PimTac] #4714721
04/03/18 01:41 AM
04/03/18 01:41 AM
Mississippi
PhuongFU Offline OP
PhuongFU  Offline OP
Mississippi
Itís a Mercedes clk500 2003, and no there was nothing that holds it in place.
Re: Pin from Parking brake cable to parking brake fell [Re: PhuongFU] #4714918
04/03/18 08:02 AM
04/03/18 08:02 AM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
On older Mercedes the pin is retained by the parking brake cam/lever mechanism.... its hard to explain. The mechanism folds over its self and is a pain to get hooked up.
Example of W124:
The pin is between the two yellow arrows, its that half circle in the middle of that wishbone-shaped lever.
Re: Pin from Parking brake cable to parking brake fell [Re: bmwpowere36m3] #4714987
04/03/18 09:07 AM
04/03/18 09:07 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
That design is very similar to my E34 and shouldn't let the pin fall out. Something has to be worn or misplaced I would think.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Pin from Parking brake cable to parking brake fell [Re: kschachn] #4715071
04/03/18 10:27 AM
04/03/18 10:27 AM
Connecticut, USA
Connecticut, USA
Once correctly assembled it shouldn't fall out... however getting it assembled and not having the pin fall out is tricky.
Re: Pin from Parking brake cable to parking brake fell [Re: kschachn] #4715237
04/03/18 01:30 PM
04/03/18 01:30 PM
Mississippi
PhuongFU Offline OP
PhuongFU  Offline OP
Mississippi
I think what happened was the connection on the cable portion, stretched out. So maybe I should try to crimp that part back? Or maybe liquid steel.
Re: Pin from Parking brake cable to parking brake fell [Re: bmwpowere36m3] #4715246
04/03/18 01:34 PM
04/03/18 01:34 PM
Mississippi
PhuongFU Offline OP
PhuongFU  Offline OP
Mississippi
Actually with this picture you cannot see it because this pin part connects to the cable. Maybe Iíll just look on the other side and see how itís done. But I believe they say itís held in place is, the cable portion that connects to the pin, is crimped down on it.
Re: Pin from Parking brake cable to parking brake fell [Re: PhuongFU] #4715353
04/03/18 03:26 PM
04/03/18 03:26 PM
Connecticut, USA
Connecticut, USA
The pin is visible (at least part of it)... here's another look:
The pin should be a slip-fit and unfortunately makes is difficult to get everything in place.
Re: Pin from Parking brake cable to parking brake fell [Re: bmwpowere36m3] #4716333
04/04/18 02:25 PM
04/04/18 02:25 PM
Mississippi
PhuongFU Offline OP
PhuongFU  Offline OP
Mississippi
Yep there it is! It just falls out when I put it back in
