1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
29 registered members (citationxeleven, billt460, Cornershop, c502cid, Ag76, 4 invisible), 942 guests, and 27 spiders.
Topics296,903
Posts4,961,303
Members66,997
Most Online2,688
Jan 19th, 2019
QuickStruts and ride height #4713631
04/01/18 08:25 PM
04/01/18 08:25 PM
The Northeast
mclasser Offline OP
mclasser  Offline OP
The Northeast
Helped my buddy install 4 Monroe QuickStruts on his Toyota this weekend. Aside from some rusty bolts, the job went well and the car rides great. The rear now sits up a little taller than the front. Is this normal?
I put QuickStruts on my I35 a few years back and don't remember a change in ride height.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: QuickStruts and ride height [Re: mclasser] #4713645
04/01/18 08:44 PM
04/01/18 08:44 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Thinking they should go back down after a few thousand miles...
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: QuickStruts and ride height [Re: mclasser] #4713648
04/01/18 08:50 PM
04/01/18 08:50 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Id say its pretty normal. The car wasnt higher in the back to start with?
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: QuickStruts and ride height [Re: mclasser] #4713656
04/01/18 08:56 PM
04/01/18 08:56 PM
MA
Wolf359 Online content
Wolf359  Online Content
MA
It's pretty normal for them to be a little bit higher initially. After a few weeks with some weight on the springs, the ride height will settle down a little.
Re: QuickStruts and ride height [Re: mclasser] #4713746
04/02/18 12:40 AM
04/02/18 12:40 AM
Athens, GA
ctechbob Offline
ctechbob  Offline
Athens, GA
Depending on how the rear assembly mounts, you might want to do the final torque with either the car on the ground or the suspension arm compressed as it would be under the weight of the car. Likely though, the rear end will settle down over time.
2008 Acura TL Type S - 154k
2003 Honda Accord V6 - 207k
2000 Honda Accord I4 - 311k
Current Oil - Milesyn SXR5W30
Current Filter - Partsmaster 61334
Re: QuickStruts and ride height [Re: mclasser] #4713794
04/02/18 04:50 AM
04/02/18 04:50 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Every spring I have replaced always sat high intially and then settled down. Hpefully the ones on the other end aren't sagging. I always waited a little before getting aligned.
The "thinking" man's friend.
Re: QuickStruts and ride height [Re: mclasser] #4713876
04/02/18 07:12 AM
04/02/18 07:12 AM
Michigan
khittner Offline
khittner  Offline
Michigan
The QuickStruts on my '02 Camry worked like that, too. It may've been a measure of how sacked out the OEM springs were. Mine now have 100K miles on them, and the rears still seem a little higher, but ride fine, and it carries my son's and his buddies' golf bags without looking squashed. I actually hope the newly-available QuickStruts for the rear end my wife's '11 Highlander do the same thing; the Highlander seems fairly undersprung for a big vehicle, and it squats a bit in the rear when accelerating, etc., even though we've never loaded it heavily or towed anything.
Re: QuickStruts and ride height [Re: mclasser] #4713905
04/02/18 07:55 AM
04/02/18 07:55 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
While on vacation 2 years ago the drivers side front strut bearing failed on my 2007 Fusion. I had only that strut replaced, and never saw any change in height.
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: QuickStruts and ride height [Re: tig1] #4714371
04/02/18 04:56 PM
04/02/18 04:56 PM
MA
MA
It's the spring that determines the ride height not the strut. The strut just does the damping. The quick strut is one assembly with both spring and strut. So new springs always take a little while to settle down once they have some weight on them. Just a strut change wouldn't affect ride height.
Re: QuickStruts and ride height [Re: mclasser] #4714476
04/02/18 06:39 PM
04/02/18 06:39 PM
The Northeast
mclasser Offline OP
mclasser  Offline OP
The Northeast
I'll let him know to give the springs some time to settle. Thanks for the info fellas smile
