Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
97 registered members (240_Ed, AandPDan, 97f150, advocate, anndel, 2015_PSD, 11 invisible), 2,260 guests, and 30 spiders.
Topics296,643
Posts4,956,486
Members66,950
Most Online2,577
Jan 14th, 2019
Cold start noise cx5 #4713628
04/01/18 08:22 PM
04/01/18 08:22 PM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
Vehicle: 2016 Mazda cx-5 2.5L 11,xxx miles
Cold start sounds like a can of marbles being shook around coming from engine. Goes away when I rev even the slightest bit or after like 10 seconds (feels like an eternity). Is this normal on skyactiv engines due to their filter not having adbv? Does the system have an internal valve? Is it because of Mazdas value line (Mexico made) of filters the dealership has? Did this before my oil change that the dealer did and after I put in 5 qts qsud 0w-20 and pe01-14-302a-mv filter
'13 Toyota Tundra 5.7-Idemitsu
'08 Hyundai Elantra-Mobil 1
'96 Ranger R72 90hpJohnson
'03 Ski Doo REV 600 H.O.
�01 Kawasaki KDX 220r
Re: Cold start noise cx5 [Re: pda1122] #4713639
04/01/18 08:36 PM
04/01/18 08:36 PM
PimTac Offline
PimTac  Offline
A quick way to rule out the filter would be to switch it. Im running the M1 EP 108A with no issues.
Of course any mechanical issues should not be ruled out but the filter change is a cheap and quick option to start with.
Cannot see signatures any longer so it doesn’t matter.
Re: Cold start noise cx5 [Re: pda1122] #4713651
04/01/18 08:53 PM
04/01/18 08:53 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I doubt it has anything to do with the filter, it sounds like its probably common direct injector noise to me.
Re: Cold start noise cx5 [Re: Trav] #4713680
04/01/18 09:45 PM
04/01/18 09:45 PM
US
JLTD Offline
JLTD  Offline
US
Wouldn't it continue past 10 seconds if it was injectors?
I agree with trying another filter.
I'm a thickie; assimilate
But 20s have their place
Using AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: Cold start noise cx5 [Re: JLTD] #4713787
04/02/18 04:42 AM
04/02/18 04:42 AM
Trav Offline
Trav  Offline
No. I should have said noise due to DI, it could be the injectors themselves, pump noise at the cam at cold start or cold combustion chamber noise which is more common with higher compression ratios and DI or diesels. IIRC the Sky Active engines have a higher compression ratio of around 14:1.
In any case there is nothing that can be done about it, its the nature of the beast for some engines. If the noise was present before and after the filter was changed I doubt both filters were bad, its a vertical filter with no ADBV (according to the OP) si if that's the case how could it be the filter?
Re: Cold start noise cx5 [Re: PimTac] #4713790
04/02/18 04:45 AM
04/02/18 04:45 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
That's what I would try. Oil could be getting past an anti bypass mechanism that's leaking after an overnight shutdown. An inexpensive try. You can try using of those doctor "thingys" you put in your ears to listen for the source. I think Harbor Freight might might have a cheap version.
The "thinking" man's friend.
Re: Cold start noise cx5 [Re: pda1122] #4713803
04/02/18 04:59 AM
04/02/18 04:59 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I thought mazda played some sort of games with the valve timing on these things on cold start to get the cat up to temperature ASAP? They all sounded horrible to me when starting ...
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Cold start noise cx5 [Re: pda1122] #4713828
04/02/18 05:49 AM
04/02/18 05:49 AM
Cincinnati
quint Offline
quint  Offline
Cincinnati
My wifes 2017 Mazda3 with the 2.5 sounds positively scary on cold stars. It lasts 1-2 minutes or until it starts getting warm, then it gets very quiet pretty quickly. I've driven enough Skyactiv's either test driving or as rentals and they were all this way. It sounds like a combination of marbles in a can and a small exhaust leak. If it doesn't sound like this once its warmed up I wouldn't worry about it at all.
1993 240sx convertible
2001 Sequoia
2012 Mazda 2
2012 Mazda 3 Totaled 3/16/18, R.I.P
2017 Mazda 3
2017 Kia Rio
Re: Cold start noise cx5 [Re: pda1122] #4713869
04/02/18 06:44 AM
04/02/18 06:44 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
SkyActive motors vary the valve timing during cold starts to warm up the cat quickly. They do this because the cat is pretty far from the motor (by todays standards) due to the long-tube headers. During normal operation the exhaust is better scavenged and part of the reason we can run 87 octane with a 13:1 compression ratio. Its 14:1 in regions where higher octane fuel is the norm.
Since the OP is from Maine, I assume you know what that sounds like. Mine will do it for ~30 seconds on a typical winter morning. It does not sound like DI clatter.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Cold start noise cx5 [Re: pda1122] #4713907
04/02/18 07:57 AM
04/02/18 07:57 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Try a MC FL910 which has the ADBV. I use that on my Fords with no start up noise.
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Cold start noise cx5 [Re: pda1122] #4713938
04/02/18 08:33 AM
04/02/18 08:33 AM
Idaho
CT8 Online content
CT8  Online Content
Idaho
Check the noise on another Mazda like yours then report back.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Cold start noise cx5 [Re: pda1122] #4714068
04/02/18 10:49 AM
04/02/18 10:49 AM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
I tried to get video of the sound but of course the vehicle didnt want to cooperate. It didnt make the sound today. shrug
Re: Cold start noise cx5 [Re: pda1122] #4714415
04/02/18 05:42 PM
04/02/18 05:42 PM
Trav Offline
Trav  Offline
You can try a filter but if it were a filter issue it probably wouldn't stop making noise one day and make it the next. Its under $10 so why not start with the cheapest thing first but I don't think you have a real issue, ask the Mazda dealer.
