need brake job but ...
by Bluebonnet. 04/25/19 05:12 PM
UOA on BMW 0w-30 on BMW F10 M5 with S63 TVDI V8
by AirBull. 04/25/19 05:08 PM
What to drink with trail mix?
by das_peikko. 04/25/19 04:55 PM
And This Folks, Is How You Buy Guns
by billt460. 04/25/19 04:43 PM
Tire leak with new wheels. What would YOU do?
by Lolvoguy. 04/25/19 04:20 PM
Red battery light came on, Ford E150.
by laserred96gt. 04/25/19 03:34 PM
2019 NFL Draft
by JustN89. 04/25/19 03:10 PM
Crabgrass!!!!
by gregk24. 04/25/19 03:06 PM
Drain and fill 08 Kia Rio.
by Jetsfan421. 04/25/19 02:59 PM
Cut Open - Mazda OEM @ 7,000kms
by mcwilly. 04/25/19 02:50 PM
Fender bender...headache!
by gregk24. 04/25/19 02:44 PM
Cerwin Vega 10" Subwoofers - $14.37 Each
by Greg L. 04/25/19 01:53 PM
Blain's Farm & Fleet synthetic oil $2.19/qt.
by BrewCityR. 04/25/19 01:24 PM
F1 - 2019 Azerbaijan Grand Prix
by gofast182. 04/25/19 12:00 PM
Installing an additional fuel filter?
by Ed_Flecko. 04/25/19 11:46 AM
Honda self propel only spining left wheel
by Tundragod. 04/25/19 11:38 AM
Cabin Filter Pics (15k miles)
by DoubleWasp. 04/25/19 11:30 AM
LiquiMoly Jectron Fuel Injection Cleaner
by Ddub. 04/25/19 11:12 AM
servicing a 2018 GM 6speed transmission
by gotnogunk. 04/25/19 10:23 AM
Wood9913, Lydia, jdar805866, PreludeDenarius, Ayodejidj
67902 Registered Users
109 registered members (53' Stude, Anduril, 28oz, Andygold, 240_Ed, AirBull, 11 invisible), 2,100 guests, and 23 spiders.
Topics288,046
Posts4,939,831
Members67,902
Most Online2,967
Mar 10th, 2019
Noisy HEPA Filter Motor - Which Lube? #4713482
04/01/18 06:41 PM
04/01/18 06:41 PM
New England
gathermewool Online content OP
gathermewool  Online Content OP
New England
This motor sounds fine at higher speeds (air noise exceeds motor noise), but at lower speeds this thing used to be whisper quiet. It continues to operate well, even at low speeds, but sounds very noisy at lower speeds. I tried a couple of drops on either side of the motor shaft, but it did jack squat to the noise.
The video below was actually taken AFTER using a few drops of 3-in-1 oil and then allowing a few minutes for gravity to work on each side of the rotor shaft. I then reassembled the fan and ran it for a minute or so at low, then high, then low speeds and it still exhibits the EXACT same volume-tone noise as before - no perceptible change...
Any suggestions? I find that most of my filters fans/motors get noisy and I've never been able to figure out how to lubricate them to get rid of the noise. I had to toss an older one, because its flow rate was so low for how much current it was drawing - even with the filter removed! I tried lubricating it and it made now difference.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4713533
04/01/18 07:37 PM
04/01/18 07:37 PM
VA
Gebo Offline
Gebo  Offline
VA
Mobil 0w-40. It will fix anything. grin
Pretty thick, huh?
And I'm not talking about the viscosity of the oil.
Sall good....
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Noisy HEPA Filter Motor - Which Lube? [Re: Gebo] #4713550
04/01/18 07:55 PM
04/01/18 07:55 PM
New England
New England
Pretty thick, huh?
Sall good....
Having a good night, are we? Beer2
Coffee2
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4713580
04/01/18 08:24 PM
04/01/18 08:24 PM
midwest
JamesBond Online content
JamesBond  Online Content
midwest
That's what I use in my fans and it works well.
I'm not familiar with these machines, is it just the small fan and a filter? Can you disassemble the motor any more than that? Can you run the motor with the squirrel cage removed? Is there dust in the blades? It sounds more like a balance/vibration noise than a motor noise. When the motors go bad I would expect it to make more of a "shhhhhhh" noise.
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4713590
04/01/18 08:40 PM
04/01/18 08:40 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
If it's a motor with sleeve bearings there is probably not much hope. You can try and lube it but it will not work long term.
But it's worth trying.
Possibly a replacement motor can be installed. It's likely to be a shaded pole motor.
2015 Ford F250 w/Powerstroke
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4713594
04/01/18 08:42 PM
04/01/18 08:42 PM
PimTac Offline
PimTac  Offline
Maybe some canned compressed air will blow out any dust. The previous comment about dust build up is true. I take it this unit has no prefilter. Maybe one could be added?
Cannot see signatures any longer so it doesn’t matter.
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4713657
04/01/18 10:01 PM
04/01/18 10:01 PM
New England
New England
The motor and centrifugal blower assembly are downstream of a screen pre-filter, HEPA filter and charcoal filter. I can't imagine a motor that has better filtration.
I cannot remove the electrical connector. With a pair of needle-nosed pliers, the connector would not budge.
I can't figure out how to dismantle the motor any further without risking damage. I'll have to research it further.
Here's the filter (I didn't pay as much as it's listed for now):
https://www.amazon.com/gp/product/B00IABVZGY/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4714055
04/02/18 11:33 AM
04/02/18 11:33 AM
New England
New England
Here's another video, this time showing the motor running without any attachments. Without the noise of the fan you can really here the motor whine. I cycled through the speeds, leaving it on "Turbo" at the end. I did not change the speed after switching it to "Turbo" - you'll notice that the hum/whine at max speed is cyclic. This thing has "Plasma wave technology". I'm not sure what that means, but it appears to have something to do with the two prongs you can see at the top left of the housing. There was no appreciable buildup and it doesn't connect to anything, so I'm not sure what its purpose is - maybe to "ionize" the air?
Don't mind the sound of mouth-breathing (and shaky camera) --> my two-and-a-half-year-old was hanging onto me while I recorded. happy
I'm running the motor, as seen in the video, to see if I can get the 3-in-1 to distribute down and maybe quiet things down. I've been running it on "Turbo" for 5+ minutes and it sounds the same, so far as I can tell.
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4714477
04/02/18 07:39 PM
04/02/18 07:39 PM
New England
New England
No luck - sounds the same as it ever did.
The motor was getting hot enough that it was uncomfortable to touch for more than 10-20 seconds, so I reassembled and have been running it on low essentially since I last posted.
It looks as if the stator housing can be split; however, it may take a lot of brute force that could ruin the motor. I searched for the motor by part number and nothing came up. Kinda hate that nearly every filter Iíve had was trashed due to substantially reduced motor function.
With that said, the Honeywell HEPA filter we keep in our room (Model 50250-S) has performed flawlessly over the past few years. I have even had to change out the filter! I clean the pre-filter and vacuum (HEPA vacuum with washable filters) quarterly (+/-) and it pumps out air seemingly like it did on day one!
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4721640
04/09/18 01:10 PM
04/09/18 01:10 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
In photo 5, drilling a small hole into that metal can surrounding the shaft would allow you to get more oil inside to saturate the wick. It must be drilled so that it points up upon reassembly to prevent the oil from running out. Same with the other bushing.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4724724
04/12/18 01:04 PM
04/12/18 01:04 PM
Canada
camrydriver111 Offline
Canada
Mobil 1
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4726415
04/14/18 05:34 AM
04/14/18 05:34 AM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
that sounds like a failing sealed ball bearing.
you might be able to replace them cheaply.
i had one fail in a similar filter and it was making an increasingly loud hissing noise that progressed to grinding/crunching.
called up motion industries with the number and got some high quality replacements for around $5 each.
i pressed them with a vice and sockets.
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4730511
04/17/18 10:31 PM
04/17/18 10:31 PM
New England
New England
I have no idea how to figure out which bearings are installed, let alone how to find a replacement. If you can lead me to an actual replacement (for that cheap) Iíll be forever in your debt! At $5 each, the new bearings would likely pay for themselves in energy savings, considering this thing runs at full tilt at least 8 hrs per day.
Problem: Iíd have to figure out how to break open the stator housing. I donít see an easy way t disassemble it. I, worried that trying to disassemble will result in a trashed motor. Iíd rather a noisy motor than zero motors.
Drill g a hole might be a feasible alternative, as well. Iíll keep that in mind if it gets worse. Flow seems close to normal, so Iíll hold off on anything more invasive.
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4730742
04/18/18 08:29 AM
04/18/18 08:29 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I would just get a new motor. Even if you can get more oil into it, the bearings probably sleeve, are worn out and will get worse as time goes by. If it's getting hot then the 3in1 oil may not be up to the task and the 0w40 oil is a better idea.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Noisy HEPA Filter Motor - Which Lube? [Re: gathermewool] #4731256
04/18/18 05:31 PM
04/18/18 05:31 PM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
you might get lucky and find that it is some standard frame size.
without having it in hand its hard to say if it is feasible to take it apart.
it looks like typical disposable junk from here.
too bad you are not near dayton.
i bet m&r electric could match up something.
might look for a place like them in your area.
but a good quality motor probably costs more than the whole unit.
