Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
98 registered members (2015_PSD, 01rangerxl, 69GTX, aaronc7, ABCarr, 7 invisible), 1,528 guests, and 57 spiders.
Topics286,092
Posts4,902,408
Members67,560
Most Online2,967
Mar 10th, 2019
Rotella T6 + T4 #4713235
04/01/18 12:27 PM
04/01/18 12:27 PM
Central Minnesota
garyw Offline OP
garyw  Offline OP
Central Minnesota
I run Rotella T6 Full Synthetic 5/40 in my 2006 Ford F-350 6.0 Diesel. I had some engine work done and the shop added 2 quarts of Rotella T4 Conventional 15/40 because some oil was lost. I only had about 50 miles on the T6. Should I change it or leave it go until my usual oil change of 3000 miles.
Re: Rotella T6 + T4 [Re: garyw] #4713237
04/01/18 12:30 PM
04/01/18 12:30 PM
Balearic Islands , Spain
FordCapriDriver Offline
No worries, and if i were you i would change the oil every 5-6k miles not 3k.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Rotella T6 + T4 [Re: garyw] #4713248
04/01/18 12:50 PM
04/01/18 12:50 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
Ford 6.0 might be a 'special ford design' that warrants low OCI.
Other, more knowledgeable BITOG'rs, feel free to chime in.
2004 Prius; 110K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Rotella T6 + T4 [Re: garyw] #4713265
04/01/18 01:21 PM
04/01/18 01:21 PM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
It will be fine.
If you want the job done right......do it yourself.
Re: Rotella T6 + T4 [Re: garyw] #4713267
04/01/18 01:22 PM
04/01/18 01:22 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Just watch the oil monitor.
2004 Corolla 129932
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Rotella T6 + T4 [Re: garyw] #4713339
04/01/18 03:30 PM
04/01/18 03:30 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
If the 6.0 is "bulletproofed & deleted", 5,000 in not a problem at all.
The oil is fine.
Re: Rotella T6 + T4 [Re: garyw] #4713345
04/01/18 03:33 PM
04/01/18 03:33 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Leave it 15W-40 is a better oil.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Rotella T6 + T4 [Re: garyw] #4713368
04/01/18 03:51 PM
04/01/18 03:51 PM
PA
ridgerunner Offline
ridgerunner  Offline
PA
Doesnt the 6.0 diesel use the engine oil for something other than a lube in its engine? thinking I read something like 3,000 PSI and high heat running a pump or something? Super rough on the oil, especially conventional oil.
Re: Rotella T6 + T4 [Re: garyw] #4713383
04/01/18 04:11 PM
04/01/18 04:11 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I wouldn't waste the rest of the new 5w40. That 2 qts. is a pretty small percentage considering it mixed in with 3 more gallons of the T6, and though I wouldn't, I know several guys that run 15w40 in their 6.0's. And bulletproofed or not, 3K sounds like a real waste especially on T6.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Rotella T6 + T4 [Re: garyw] #4713418
04/01/18 04:57 PM
04/01/18 04:57 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I ran 5K OCIs on the '03 6.0 PSD I had, the later 6.0s seem a little better than the earlier ones were. I would run it the full 5K and put in T4 10W30-it's just as good cold as the T6 and costs roughly half as much.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Rotella T6 + T4 [Re: bullwinkle] #4714441
04/02/18 07:13 PM
04/02/18 07:13 PM
Central Minnesota
garyw Offline OP
garyw  Offline OP
Central Minnesota
Yes, the 6.0 has been bulletproofed and deleted. I think the oil also drives the injectors.
Re: Rotella T6 + T4 [Re: garyw] #4714624
04/02/18 10:19 PM
04/02/18 10:19 PM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
Yes, your engine oil drives your injectors. Your motor has a high pressure oil pump "HPOP" mounted on the top front block next to your fuel bowl that pressurizes the injectors. That's why your motor takes so much oil. It is referred to as a HEUI injector, Hydraulically actuated Electronically controlled Unit Injectors.
P.S. even 5k oil change is overkill unless it takes you a year to accumulate 5k.
08 Tribeca 86k PUP 5w30 wix
06 Accord Hybrid 134k PPHM 0w20 wix
02 Chevy k3500 99k Delvac 1 esp 5w40 wix
00 F350 136k Delvac 1300 15w40 wix
Re: Rotella T6 + T4 [Re: garyw] #4714876
04/03/18 08:16 AM
04/03/18 08:16 AM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
The HEUI Fords are famous for shearing 5w40, so the oil probably ends up a 5w30. 15w40 and 10w30 stay in grade better in those engines. A couple of quarts of T4 15w40 isn't going to hurt anything.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Rotella T6 + T4 [Re: A_Harman] #4719763
04/07/18 05:49 PM
04/07/18 05:49 PM
Central Minnesota
garyw Offline OP
garyw  Offline OP
Central Minnesota
I only put on 5000 miles or less in a year. I will just change it once a year. If I switch to T4 15-40, won't it be pretty thick on a -20 degree morning and take a while to get up in the engine?
Re: Rotella T6 + T4 [Re: garyw] #4719904
04/07/18 08:05 PM
04/07/18 08:05 PM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
Yes! 15w40 will give you a harder time starting at -20F. Stick with the synthetic for your application then, didn't notice your from MN, gets really cold there! I change oil in all my vehicles once a year also, I don't even accumulate 5k per year, per vehicle.
