Hi folks. While doing a little pre season maintenance I had a mower that would not start . I noticed a bit of grass sticking out from under the fan shroud . When I removed the shroud I found the living quarters of a critter . Mower would have overheated had it ever started but ignition was packed full of trash too, causing the no start. Check and clean those shrouds ever so often . You never know what you will find .
