Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
114 registered members (AITG, A310, addyguy, 69GTX, 2009Edge, 10 invisible), 2,145 guests, and 48 spiders.
Topics296,735
Posts4,957,909
Members66,960
Most Online2,577
Jan 14th, 2019
First battery in back seat #4712893
04/01/18 03:21 AM
04/01/18 03:21 AM
Nebraska
Duffyjr Online content OP
Duffyjr  Online Content OP
Nebraska
For a few years now I have been using my Ctek a couple times a year on my vehicles to try and get the most out of my batteries. With the Buick I just picked up I see the battery is under the back seat but there is a place under the hood for jumping. Is this good enough to hook up my Ctek 4.3 or should I pull the seat and hook it up directly to the battery?
89 GMC Sierra VWB 5w30/TG3980
08 Lucerne CX Magnatec 5w30/TG3387A
02 DeVille VWB 5w30/CQ Blue
18 Toro Super Recycler T5 10w30
Re: First battery in back seat [Re: Duffyjr] #4712913
04/01/18 05:18 AM
04/01/18 05:18 AM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
You can hook where’s for jumping.
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealer’s overfilled, 16000 Km
Re: First battery in back seat [Re: Duffyjr] #4712926
04/01/18 05:43 AM
04/01/18 05:43 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Under the hood is fine, you can also hook a quick plug for it under the hood from the jump connector and a ground.
https://smartercharger.com/products/accessories-cat/ctek-comfort-connect/
Re: First battery in back seat [Re: Trav] #4712956
04/01/18 06:24 AM
04/01/18 06:24 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
+1. That's how I set up my BMW.
Re: First battery in back seat [Re: Duffyjr] #4713038
04/01/18 07:25 AM
04/01/18 07:25 AM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
The 2 posts under the hood is the best place to hook-up
Re: First battery in back seat [Re: Duffyjr] #4713135
04/01/18 08:53 AM
04/01/18 08:53 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Here is the answer.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: First battery in back seat [Re: JHZR2] #4713613
04/01/18 08:02 PM
04/01/18 08:02 PM
SF Bay Area
y_p_w Offline
y_p_w  Offline
SF Bay Area
I helped a BMW driver with a jump once using my jump starter. He connected it right in the back rather than the jump points under the hood.
Re: First battery in back seat [Re: y_p_w] #4713732
04/01/18 11:53 PM
04/01/18 11:53 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
On my 2011, that wouldn't be possible because of a large control item on the positive terminal.
Id suspect he voltage drop would be higher too.
Re: First battery in back seat [Re: JHZR2] #4714053
04/02/18 10:28 AM
04/02/18 10:28 AM
SF Bay Area
y_p_w Offline
y_p_w  Offline
SF Bay Area
Apparently what he did wasn't the way BMW recommends a jump be done. However, I've had attempts to jump where hooking up negative to ground didn't work so I just clamped it right on the negative terminal and hoped it didn't go up in a ball of hydrogen flames.
I am thinking that one reason they recommend jumping from the front is that it's closer to the starter.
Re: First battery in back seat [Re: Duffyjr] #4714105
04/02/18 11:39 AM
04/02/18 11:39 AM
Nebraska
Nebraska
So just how are these wired, do they go from the battery to starter then jump post or battery to jump post then to starter or is it split some where?
Just curious!
Re: First battery in back seat [Re: Duffyjr] #4714195
04/02/18 01:24 PM
04/02/18 01:24 PM
SF Bay Area
y_p_w Offline
y_p_w  Offline
SF Bay Area
Just curious!
Pretty sure that the positive terminal of the battery is directly wired to the positive post of the jumper post, and the negative terminal of the battery is wired directly to the chassis. It would just be distributing the positive as a single, connected node to whatever needs it.
There are some reasons for doing it. One is avoiding the heat/vibration under the hood. Another is weight distribution. However, that's an extremely long length of cable.
