White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
35 registered members (c502cid, carlprop, Black_Thunder, Blkstanger, BlakeB, bubbatime, 4 invisible), 882 guests, and 30 spiders.
Topics296,866
Posts4,960,375
Members66,982
Most Online2,688
Jan 19th, 2019
Page 1 of 3 1 2 3
Which two oils would you mix ? #4712891
04/01/18 02:56 AM
04/01/18 02:56 AM
Down Under
SR5 Offline OP
SR5  Offline OP
Down Under
Just for fun, if you had to mix together and use two fully formulated oils, which two would you select and why?
Not advising this, just thinking about things. I would select two different and complementary oils. My Aussie mix would be Penrite Vantage 10W40 and Nulon Euro 5W30.
Penrite Vantage 10W40 semi-synthetic is a Group II and Group III blend that does much of the heavy lifting with it's add pack. It's rated API SN/CF, ACEA A3/B4 and VW 502/505.
It's at the thin end for a 40 grade, with KV100 = 13.5 cSt, but just makes 10W with CCS (-25 C) = 6899 cP very close to the J300 limit of 7000 cP. So a viscosmetrically "tight" oil with low VII treat rate.
It does have a heavy add pack otherwise with,
TBN = 11.0
Zinc = 1220 ppm
Sulphated Ash = 1.1 % (high SAPS)
At the other end we have Nulon Euro 5W30, a full synthetic Group IV (PAO) based oil that carries one of the toughest factory OEM approvals VW 504/507 along with BMW LL-04, MB 229.51, ACEA C3 and API SN. It's at the thick end of the 30 grade with KV100 = 12.04 cSt. The well formulated base stock must do much of the heavy lifting here as it's a low SAPS oil with,
TBN = 5.4
Sulphated Ash = 0.5 %
Mix them together 50:50 and you get a PAO semi-synthetic (not the normal Group III semi-synthetic) with decent SAPS (~ 0.8%), decent TBN (~ 8.2), a good dose of zinc and a viscosity that sits close to the 30 & 40 grade border.
Sure, you don't know how exactly everything will work together, but it would work well enough for me
Re: Which two oils would you mix ? [Re: SR5] #4712894
04/01/18 03:29 AM
04/01/18 03:29 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Currently in wife's Captiva is
A jug (5L) of Helix AG 5W30 - bought 3 jugs at sell out prices.
A Litre of Nulon 25W60 - bought it as a monograde (no VII/PPD upset), high zinc, low S.A. with potentially high levels of brighstock (per Joe)...as an "additive" essentially.
In order to do 3 oil changes with the 3 jugs I could get, SOMETHING had to be mixed..at the end, so decided to "additise" second, fairly unique product.
Would also use Edge 25W50, or M1 V-Twin as an "Additive".
TGMO and M1 V-Twin, I could nearly live with I think.
(Note, no kittens were harmed in this, as I don't have to worry about cold weather performance, 25W-70 has performed fine in my climate)
Did some Q.A. (Quick and Aweful) testing to verify my guesses...
Re: Which two oils would you mix ? [Re: Shannow] #4712898
04/01/18 03:58 AM
04/01/18 03:58 AM
Down Under
SR5 Offline OP
SR5  Offline OP
Down Under
That Edge 25W50 or M1 V-Twin makes sense as an additive oil.
How about the PAO based Nulon Euro 5W30 with Penrite Mono Truck SAE 30. It s a pure Group II monograde with a decent add pack.
TYPICAL DATA (Mono Truck 30)
Density at 15C, kg/L 0.880
Viscosity, Kinematic, cSt at 40C 84
Viscosity, Kinematic, cSt at 100C 10.8
Viscosity Index 114
Zinc, Mass % 0.122
Sulphated Ash, Mass % 1.22
Base Number 9.4
Again, mix it 50:50 and that should produce something like a 15W30 semi-synthetic with ample TBN and ZDDP in a low VII package. The Group II & Group IV mix should offer decent oil life.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Which two oils would you mix ? [Re: SR5] #4712907
04/01/18 04:37 AM
04/01/18 04:37 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
I agree that it isn't optimal to mix oils but, we're not hurting anything either...when using motor oils. What I mean is, don't mix oil and atf or gear oil.
However, I have mixed so many oils over the past 45 years that you wouldn't believe it. Although I don't really mix anymore unless I have some straggler qts of oil to use up. And when I mixed oils, I ran the OCI the full length, I didn't cut it short just because I had a Frankenbrew.
Even today should I mix in a couple of straggler qts/brand/wgt of oil in an OCI, I run it the full length of the OCI(5k-7K miles) depending on whether it's dino or syn oil.
In the past(~1970s-80s), I have mixed 5 different brands and each brand being a different weight, e.g., 5W30/10W30/10W40/15W40/20W50.
Or even in the early 2000s, after discovering BITOG(Prod/Rebate/Sale section) and buying up a store shelf of oils that were being replaced/discontinued/changing ILSAC spec...0W20/0W30/0W40/5W20/5W30...You get the idea!
Today(just for fun in this thread), If I were to mix, Gee, IDK! I guess I would mix anything because I have never had engine issues due to oil. I've had engine issues due to poor designs and engines that were notorious for having problems but, not from oils.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Which two oils would you mix ? [Re: SR5] #4712917
04/01/18 05:27 AM
04/01/18 05:27 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
My current plan for next falls OIC is Gold jug Castrol 0W-20 Extended Protection 2 quarts with two quarts of Castrol 0W-40 EDGE. This will be going into my Toyota Corolla. I got the Extended Protection for $17 a Jug and the EDGE for $13 dollars a Jug.
2004 Corolla 128276
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Which two oils would you mix ? [Re: SR5] #4712966
04/01/18 06:31 AM
04/01/18 06:31 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
CPC SAE40 with Mobil Delvac MX 15W40, about 50:50. Been in for about 4 years. Might do it again.
Original reason was an oil leak. Reasons for doing it again are fairly speculative, but it would stretch my remaining Delvac MX, which proably can't be replaced, to two more oil changes.
Long time on a 5 year OCI.
Re: Which two oils would you mix ? [Re: SR5] #4713107
04/01/18 08:29 AM
04/01/18 08:29 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
How about a 0w40 or 5w40 on sale and throw in some SN rated Rotella, Delo, or Delvac to boost zinc and phosphate.
If you want the job done right......do it yourself.
Re: Which two oils would you mix ? [Re: SR5] #4713125
04/01/18 08:49 AM
04/01/18 08:49 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
One oil change may soon for be made up of my leftover qts:
  • 2 Qts of AutoZone 0w-20
  • 2 qts PUP 0w-20
  • 1 qt Mobil 1 EP 0w-20
  • 1 Qt Castrol Syn-Blend 5w-20
Not trying to make anything in particular.
Or these may end up as just some top off oil (you know you have too much oil when you use PUP or M1 to top off a din oil fill).
Only times I mixed for a specific reason was when I had some Mobil 1 15w-50 and Mobil 1 0w-30 that I wanted to thin it out, same for some Peak 5w-20 and 10w-40.
2018 Hyundai Santa Fe: Dealer oil, Mahle filter, 5k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: GTX HM 5w-20, EcoGard, 1yr
1994 Honda VT1100c: Peak 15w-40, PSL, 5k
Re: Which two oils would you mix ? [Re: SR5] #4713140
04/01/18 08:55 AM
04/01/18 08:55 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The other day I changed the oil in my neighbor's Hyundai Sonata, in went one quart "red bottle" Valvoline MaxLife 20W-50 and the rest SuperTech 5W-30 (she brought to me)
Currently have a Frankenbrew in my F150, too.
Re: Which two oils would you mix ? [Re: SR5] #4713241
04/01/18 11:36 AM
04/01/18 11:36 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
I'll intentionally mix oils if I need a final quart for an oil change. But I'll only mix oils with similar add packs. I won't mix high sodium oils like Valvoline/Napa with the high Calcium Sopus oils. And I don't like mixing the higher Magnesium oils like Mobil 1 20/30 grades with the other 2 styles. Prefer to keep Mag, Na, Ca oils separate. In an on the road emergency...yeah, add whatever ya brung.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Which two oils would you mix ? [Re: 69GTX] #4713257
04/01/18 12:07 PM
04/01/18 12:07 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Valvoline oils don't have sodium anymore; now they're using titanium
09' Camry LE
ST 5w30 and TG 4386(filter on for second 5k run)
Re: Which two oils would you mix ? [Re: SR5] #4713276
04/01/18 12:55 PM
04/01/18 12:55 PM
California
bshort Offline
bshort  Offline
California
I keep an empty 5 quart jug that I pour leftover oil into. When it's full, I change the oil in the old Ranger with it. It is nearly full now and contains: T6, M1 ESP, M1 HM, and maybe a pint of 30 that comes with a new lawn mower.
17 Chevrolet Colorado 2.8 5/40 D1 ESP (12K)
16 Chevrolet 2500 6.6 TDT 5/40 (8K)
10 Toyota Corolla M1 HM 5/30 (120K)
93 Ford Ranger T6 5/40 (310K)
Re: Which two oils would you mix ? [Re: SR5] #4713285
04/01/18 01:05 PM
04/01/18 01:05 PM
Hammehead Offline
Hammehead  Offline
Firstly, Id smell the containers to see if they are addpack compatible.
grin
ToYota Corolla XEI 2010 1zzfe
Kawasaki Ninja ZX9R B4
Taurus GL Vulcan
Citroen C5 phase I
I used to use syn, now whatever is on sale and never had problems. This noob knows stuff.
Re: Which two oils would you mix ? [Re: Snagglefoot] #4713449
04/01/18 04:46 PM
04/01/18 04:46 PM
Down Under
SR5 Offline OP
SR5  Offline OP
Down Under
Hey SF, yep a Euro oil and HDEO would work well.
So would an ILSAC PCMO and a high zinc & high HTHS diesel HDEO, to put a bit of meat on those ILSAC bones.
Re: Which two oils would you mix ? [Re: blupupher] #4713455
04/01/18 05:01 PM
04/01/18 05:01 PM
Down Under
SR5 Offline OP
SR5  Offline OP
Down Under
Yep, thick and thin work together, to bring it into that Goldilocks zone.
I sometimes see dirt cheap mineral 20W50, then I look at the full synthetic GTL Shell Helix Ultra 0W20, and I think of mixing the two. I never do it, as I would spend more on the SHU than I would save with the cheap 20W50. It's never worth it prize wise, I'm better off waiting for Castrol Magnatec to go on sale - plus then I know the exact quality of the oil I'm getting with the Magnatec.
Still we are just playing around here, and if you already had the stuff ... fill 'ya boots.
Page 1 of 3 1 2 3
