(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
87 registered members (advocate, 14Accent, 2015_PSD, Astro14, ArrestMeRedZ, AdditiveOCD, 8 invisible), 1,589 guests, and 34 spiders.
Topics296,757
Posts4,958,275
Members66,964
Most Online2,577
Jan 14th, 2019
Oil burner question 10W40/5W30 #4712569
03/31/18 04:40 PM
03/31/18 04:40 PM
Boston
lairdwd Offline OP
lairdwd  Offline OP
Boston
So my 2004 Jetta has an oil consumption problem with rings that were installed backwards. It's a well known problem of the MKIV Jetta - around 1 quart per 1000 miles during summer. I just did an oil change with 10w-40 weight and also mixed in some 5w-30. Let's call it 50/50 10W40 and 5W30.
Will the 5W-30 part of this blend be consumed at a faster rate than the 10W-40, or does it all just get mixed together. All valvoline. The 10W-40 is the maxlife syn blend. The 5w-30 is dino.
Re: Oil burner question 10W40/5W30 [Re: lairdwd] #4712571
03/31/18 04:43 PM
03/31/18 04:43 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
All mixed together.
The blend will "act" much more like a 10W-40 than a 5W-30.
Re: Oil burner question 10W40/5W30 [Re: lairdwd] #4712576
03/31/18 04:51 PM
03/31/18 04:51 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Id recommend a 10-40 without mixing in anything.
If you want the job done right......do it yourself.
Re: Oil burner question 10W40/5W30 [Re: lairdwd] #4712577
03/31/18 04:51 PM
03/31/18 04:51 PM
Boston
lairdwd Offline OP
lairdwd  Offline OP
Boston
I only drive the car 6K miles a year and with the consumption problem, I don't really need a super aggressive OCI , as oil is always fresh.
So this year instead of changing before and after winter, I decided to forgo the before change and drive a heavier weighted blend right through winter. Of course, we had one of our coldest winters of the year, but she turned over like a champ with only a couple that were tough cranks, even at below 0, where 40 weight starts to get real thick. So I judged that experiment a success.
This year, since the 5w-30 jug is open, I'll strictly be topping up with the lighter oil. By the time winter rolls around, should be mostly 5W-30( if they do truly mix.) laugh
Re: Oil burner question 10W40/5W30 [Re: Snagglefoot] #4712594
03/31/18 05:07 PM
03/31/18 05:07 PM
Boston
lairdwd Offline OP
lairdwd  Offline OP
Boston
I get it with the thicker oil = less consumption, less heat, better for old engines. But I've actually found it doesn't make a huge difference in my application for consumption. Maybe 25% less, possibly up to 50%? Given the low mileage I put on the car , not a huge deal.
My plan was to do do straight 10W-40 today, and then top up with 5W-30 right through to oil change next year. However, I only had 3 quarts left of the 10W-40, the last quart in was 5W-30. I indicated 50/50 in OP just to simplify.
Re: Oil burner question 10W40/5W30 [Re: lairdwd] #4712595
03/31/18 05:08 PM
03/31/18 05:08 PM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
Re: Oil burner question 10W40/5W30 [Re: Linctex] #4712654
03/31/18 06:22 PM
03/31/18 06:22 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Originally Posted By: Linctex
All mixed together.
Why so?
IIRC mixtures are generally skewed towards the lower viscosity component.
(Alhough with multigrades you don't really know exactly what's going to happen.)
Re: Oil burner question 10W40/5W30 [Re: Ducked] #4712685
03/31/18 07:07 PM
03/31/18 07:07 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Why so?
In the winter it is different - the mix acts like the heavier oil.
If you are resourceful, you can find 5W-40 on sale or clearance.
I have about 6 gallons of it, all bought for well below sticker price.
Re: Oil burner question 10W40/5W30 [Re: Linctex] #4712697
03/31/18 07:16 PM
03/31/18 07:16 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Why so?
I have heard of this "winter" of which you speak.
You got a source/ref for that, or is it based on personal observation?
I ask because offhand it doesn't seem to make sense, since temperature is already built in to the grade specifications.
I believe multigrade mixtures can be unpredictable though.
Re: Oil burner question 10W40/5W30 [Re: lairdwd] #4712751
03/31/18 08:40 PM
03/31/18 08:40 PM
Maricopa, Arizona
dave1251 Online happy
dave1251  Online Happy
Maricopa, Arizona
I bet the consumption will be about the same.
don't use.
Re: Oil burner question 10W40/5W30 [Re: Ducked] #4712753
03/31/18 08:41 PM
03/31/18 08:41 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Just search the topics on this forum.
Look for pour point depressants, cold weather etc etc
Yes, one tablespoon (10 ml) of 20W-50 in an entire sump of 0W-20 will not affect it that much, but thick oil in the winter makes all of the oil thicker.
Re: Oil burner question 10W40/5W30 [Re: lairdwd] #4712813
03/31/18 09:58 PM
03/31/18 09:58 PM
Chicago, IL
Brybo86 Offline
Brybo86  Offline
Chicago, IL
If running the mix year round...
When topping off in the fall use 5w30 to thin it out a bit more for winter.
I wouldn't top off with 10w40 in the winter
08 Honda Accord EX-L 2.4L M1 EP 0w20 145k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 193k
95 Yamaha Jog
Re: Oil burner question 10W40/5W30 [Re: Linctex] #4713027
04/01/18 07:14 AM
04/01/18 07:14 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Of course thick oil makes a mixture thicker (at any time of year). That's not in dispute, nor is it what you were saying earlier.
You said, effectively, that in a 50/50 mix of thick and thin oil the resultant mix will be skewed toward the thick end.
Thats certainly incorrect for straight oils. I'd be surprised if multigrades are sytematically the opposite of straight oils, though I know they are not entirely predictable,
The time of year is surely irrelevent. The grade of an oil is defined with respect to reference temperatures, not the calendar. Presumably what you mean is the effect is mostly seen on the first number.
