Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
124 registered members (Aero540T, 4WD, 69Torino, AdditiveOCD, 2015_PSD, 9 invisible), 1,710 guests, and 49 spiders.
Topics296,750
Posts4,958,214
Members66,964
Most Online2,577
Jan 14th, 2019
transmission cooler for coolant #4712535
03/31/18 04:02 PM
03/31/18 04:02 PM
out there
spasm3 Offline OP
spasm3  Offline OP
out there
I'm curious if you could use a plate and fin cooler like a hayden 679 with coolant.
My curiosity is with regards to mazda transmissions. It seems there are no transmission fluid lines on the cx-5. Apparently mazda uses a heat exchanger and runs coolant from the radiator to the transmission and back.
like this;
So it looks like it would be easy to tap into and run lines for additional transmission cooling.
Could you use a cooler like a hayden 679 with coolant?
Not sure if i want to do this, but it certainly does not look difficult. If not a transmission cooler, perhaps a small motorcycle radiator? ( i have no idea of the inlet outlet sizes though).
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: transmission cooler for coolant [Re: spasm3] #4712559
03/31/18 04:31 PM
03/31/18 04:31 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have used heater cores as "auxiliary radiators" on trucks that do a lot of heavy towing.
Re: transmission cooler for coolant [Re: spasm3] #4712570
03/31/18 04:41 PM
03/31/18 04:41 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I used one of their tube and fin models before for engine coolant before on a coolant/oil filter heat exchanger.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: transmission cooler for coolant [Re: spasm3] #4712584
03/31/18 04:57 PM
03/31/18 04:57 PM
Fort Worth, Texas
clinebarger Online content
clinebarger  Online Content
Fort Worth, Texas
It would do little to no good as you are not increasing the surface area of the transmission cooler.....You're increasing the effective size of the radiator.
There are options for you......
One idea is to have the "Cooler Plates" milled off the base plate, Then have AN fittings TIG welded to the base plate, Then you can plumb trans cooler lines.
2001 Chevy Camaro L92/4L80E
Re: transmission cooler for coolant [Re: spasm3] #4712660
03/31/18 06:25 PM
03/31/18 06:25 PM
ME
eljefino Online content
eljefino  Online Content
ME
What if your car feeds the tranny "hot side of the thermostat" coolant, like what goes to the heater core? If you add cooling on this side you could get worse heat and longer trans-warmup behavior, like delayed TCC.
Re: transmission cooler for coolant [Re: eljefino] #4712695
03/31/18 07:15 PM
03/31/18 07:15 PM
Fort Worth, Texas
Fort Worth, Texas
What car has the trans heat exchanger on the hot side? TCC delay is usually based on engine coolant temp.
"Heating" of the ATF via the cooler is a hard concept for me to grasp as I have data logged transmission cooler inlet & outlet temperatures on several different vehicles.....The cooler is always cooling the ATF
Re: transmission cooler for coolant [Re: spasm3] #4712714
03/31/18 07:40 PM
03/31/18 07:40 PM
out there
spasm3 Offline OP
spasm3  Offline OP
out there
I guess my thought was to route the coolant as it leaves the heat exchanger, to a mini radiator, or trans cooler before it returns back to the transmission.
I need to get under the vehicle and see how accessible the lines are. On the mazda forums, no one sees any atf temp sensors . I probably need a shop manual of the cooling system.
Re: transmission cooler for coolant [Re: spasm3] #4712736
03/31/18 08:18 PM
03/31/18 08:18 PM
Greenville SC
George Bynum Offline
Greenville SC
Ethylene glycol is used as a hydraulic fluid without (in almost all cases) any need for component changes. A heat exchanger designed for oil should have no problems with engine coolant.
