Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
91 registered members (2015_PSD, Aero540T, AdditiveOCD, 77GrandPrix, 928, 2004tdigls, 8 invisible), 1,369 guests, and 41 spiders.
Topics297,006
Posts4,963,319
Members67,013
Most Online2,821
Jan 21st, 2019
What woukd you do with this transmission? #4712313
03/31/18 10:49 AM
03/31/18 10:49 AM
ca
monster1 Offline OP
monster1  Offline OP
ca
2004 Dodge Ram Cummins with 75,000 miles. Had my tire shop/autocare center drop pan, replace filter and top off trans fluid at about 55,000 miles. The fluid now looks dirty. It's reddish brown in color. Should I change filter and top off again or do a flush at home by pulling the return line and replacing the fluid as it gets pumped out? I've heard horror stories about flush machines, but if I do it at home using the return line, I see no difference because it's the transmissions pump doing the work.
Thanks for putting up with my posts.
Re: What woukd you do with this transmission? [Re: monster1] #4712317
03/31/18 10:52 AM
03/31/18 10:52 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Return line fluid exchange. Use the correct fluid. Check level per the owner's manual. Should be golden then.
Re: What woukd you do with this transmission? [Re: monster1] #4712320
03/31/18 10:54 AM
03/31/18 10:54 AM
San Rafael, CA
dogememe Online content
dogememe  Online Content
San Rafael, CA
if you have a dipstick, use one of those fluid extractor things. you can change like a gallon at a time that way, and just measure what comes out so you know how much to put back in.
2010 Ford Escape 2.5 ~92K Miles: RP 5W-30, AMSOIL SS FE ATF.
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30, AMSOIL OE MV ATF.
AMSOIL in EVERYTHING!
Re: What woukd you do with this transmission? [Re: monster1] #4712322
03/31/18 10:56 AM
03/31/18 10:56 AM
US
JLTD Offline
JLTD  Offline
US
Either way should be successful; the machine flush at higher mileage can be....bad.
I've always had good results with a pan drop/filter/refill every 30-50k depending in vehicle.
I'm a thickie; assimilate
But 20s have their place
Using AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: What woukd you do with this transmission? [Re: monster1] #4712323
03/31/18 10:56 AM
03/31/18 10:56 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Leave the filter in, I seriously doubt it is a restriction.
That is what I typically do, but I just let it run until I get bubbles, shout it off, hook it all back up again, then refill to the proper level. Repeat every 25,000 miles.
Re: What woukd you do with this transmission? [Re: monster1] #4712337
03/31/18 11:14 AM
03/31/18 11:14 AM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
The line flush should work. If it were my truck I would consider adding one of the spin on in-line filters.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: What woukd you do with this transmission? [Re: monster1] #4712344
03/31/18 11:23 AM
03/31/18 11:23 AM
NE
VNTS Offline
VNTS  Offline
NE
Get a new pan, put B&M drain plug in the pan, mopar filter, redline C+ or Amsoil ATF. do the pan drop filter, clean magnet and refill and then the cooler line flush, then in the future just drain and refill.
Re: What woukd you do with this transmission? [Re: monster1] #4712345
03/31/18 11:23 AM
03/31/18 11:23 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
If you can drop the pan and replace the filter, I see no reason to do anything else. Only consideration would be to try to find a pan with a drain plug.
No reason to flush if you can pan drop, imo.
Re: What woukd you do with this transmission? [Re: monster1] #4712348
03/31/18 11:30 AM
03/31/18 11:30 AM
Santa Barbara, CA
Santa Barbara, CA
Mag Hytec also makes nice pans, they have a drain plug and increased capacity.
Re: What woukd you do with this transmission? [Re: SatinSilver] #4712467
03/31/18 02:36 PM
03/31/18 02:36 PM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
+ 1000000
Re: What woukd you do with this transmission? [Re: monster1] #4712545
03/31/18 04:16 PM
03/31/18 04:16 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
What horror stories have you heard about a flush machine? It does the same thing you are considering doing with the return line except no one has to watch over it.
Now some times they add a chemical prior to flush. And of course they would need to add the proper ATF to the new fluid container in the flush machine. And some places will tell you the flush with their machine eliminates the need to change the filter. It does not.
But the basic process of a flush machine is sound.
2015 Ford F250 w/Powerstroke
Re: What woukd you do with this transmission? [Re: Donald] #4712598
03/31/18 05:14 PM
03/31/18 05:14 PM
ca
monster1 Offline OP
monster1  Offline OP
ca
From what I've read, depending on how the transmission was maintained, the flush causing crud to break off and start making problems for an otherwise ok transmission. Kinda like flushing an engine with high miles. And also the issue of flushing but not dropping the pan to change the filter.
