Account and posts removal
by newbe46 - 09/16/19 10:00 PM
Yamaha EF2800i break-in
by Uregina09 - 09/16/19 09:43 PM
Adding TCW3 to Gas Tank?
by maverickfhs - 09/16/19 08:45 PM
Motul 75w90 1L 12 pack $13.25
by wkcars - 09/16/19 08:36 PM
2019 Ford Fusion vs used?
by FL-400S - 09/16/19 08:33 PM
What is the reasoning for 2-fuel tanks on a rv?
by RazorsEdge - 09/16/19 07:54 PM
Thoughts and opinions on family haulers
by ram_man - 09/16/19 07:53 PM
2018 Silverado 5.3L M1 AFE 0W-20 5,065
by K20FA5 - 09/16/19 07:43 PM
18 Jeep 3.6 PPU 0w20 5k OCI
by IndyFan - 09/16/19 07:06 PM
Federal 9mm 115g FMJ Brass - $7.97/50 @ Walmart
by blupupher - 09/16/19 06:47 PM
Motorcraft FL-1995W different than than non-W?
by Cubey - 09/16/19 05:31 PM
1973 Bronco w/original 302
by BKinSD - 09/16/19 05:18 PM
B&S 21hp burning oil
by Mike141 - 09/16/19 04:28 PM
Prime Guard POF2222 C&P...
by AnthemBassMan - 09/16/19 03:36 PM
Verizon FIOS direct connect HD local channels
by Vikas - 09/16/19 02:36 PM
Bentonite grease abrasive properties?
by berlyn - 09/16/19 02:19 PM
'13 Camry, ATF replacement
by parshisa - 09/16/19 02:02 PM
R0CKETMAN, Southbend9, Bigaledge32, emilio15, Kokopelli34179
69303 Registered Users
70 registered members (A_Spruce, aquariuscsm, Ag76, b1amgm47, AZjeff, 7 invisible), 1,504 guests, and 26 spiders.
Topics294,667
Posts5,064,146
Members69,303
Most Online3,532
Jul 30th, 2019
Jet Ski oil questions #4712138 03/31/18 08:23 AM
M
mrnkc130 Offline OP
M
I have a 2017 Kawasaki Ultra LX Jet Ski (naturally aspirated) and I need to change the oil soon, the manual stated oil requirements are-
Kawasaki Performance 4-Stroke JET
SKIŽ Watercraft Oil*
Semi-Synthetic Oil*
Kawasaki Performance 4-Stroke Full
Synthetic Oil*
or other 4-stroke oils with API SG,
SH, SJ, SL, SM and JASO MA, MA1,
MA2 rating
Viscosity: SAE10W-40
I have a bunch of Penzoil Ultra Platinum 0W-40 Full Synthetic left over from a truck that I got rid of and i was wondering if I would be able to use this oil in my JetSki? If not any recommendation other than the Kawasaki branded oil?
Thanks in advance!
2017 Suburban LT
2016 Hyundai Accent
1946 Chevrolet 2-ton
2017 Kawasaki Ultra LX Ski
Re: Jet Ski oil questions [Re: mrnkc130] #4712162 03/31/18 08:50 AM
K
krismoriah72 Offline
K
I have a 2017 kawasaki Teryx.. probably close to the same engine.
Rotella 15w40 has all the specs you need and guys are getting 10s of thousands of miles with no issues.
Here is the VOA of the oil you listed
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3952093/Pennzoil_Platinum_Euro_0W-40_V
Perhaps you can mix this with the rotella and come up with a 10w40.
Re: Jet Ski oil questions [Re: mrnkc130] #4712166 03/31/18 08:55 AM
M
mrnkc130 Offline OP
M
its the 1400cc engine, same as in the motorcycles i believe. So mix Rotella t6 and this 1/2 and 1/2 and that would work?
2017 Suburban LT
2016 Hyundai Accent
Re: Jet Ski oil questions [Re: mrnkc130] #4712186 03/31/18 09:21 AM
spasm3 Online Happy
Online Happy
How about amsoil motorcycle MCF 10w40 or DB50 10w50?
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
Re: Jet Ski oil questions [Re: mrnkc130] #4712189 03/31/18 09:25 AM
K
K
15w40 T4 and mix one quart of yours in each time would be a good brew.
Re: Jet Ski oil questions [Re: krismoriah72] #4712209 03/31/18 10:04 AM
L
Linctex Offline
L
Pennzoil Ultra Platinum 0W-40 + 1 qt T4 Rotella 15W-40 does sounds like a good brew for this. Maybe even 50/50
Re: Jet Ski oil questions [Re: mrnkc130] #4712257 03/31/18 10:59 AM
MolaKule Offline
Global Moderator
Global Moderator
This would be my choice because of the increased levels of anti-corrosion, anti-rust additives:
https://www.amsoil.com/lit/databulletins/g2133.pdf
Quote:
Excellent Anti-Rust Performance
Good rust protection is not natural to motor oil; it comes only by design. AMSOIL
3YNTHETIC-ARINE%NGINE/ILISFORTIlEDWITHPOTENTINHIBITORSTHATGUARDAGAINST
damaging rust and corrosion. It protects engines during use and during inactivity or
long-term storage.
The value of a scientific theory is its ability to prompt further study, not that it has any relation to the established facts of scientific reality.
Re: Jet Ski oil questions [Re: Linctex] #4712270 03/31/18 11:14 AM
Snagglefoot Online Content
Online Content
Plus you can buy T4 by the pail. (Don’t pay attention to this Canadian price.)
If you want the job done right......do it yourself.
Re: Jet Ski oil questions [Re: mrnkc130] #4712290 03/31/18 11:31 AM
M
mrnkc130 Offline OP
M
Thank you all! I'll grab some rotella an mix it in! Just looking for a use for this expensive oil that I no longer need!
2017 Suburban LT
2016 Hyundai Accent
Re: Jet Ski oil questions [Re: mrnkc130] #4712291 03/31/18 11:32 AM
B
Bluestream Offline
B
Semi-Synthetic Oil*
Synthetic Oil*
MA2 rating
Thanks in advance!
I would use the Penzoil 0W40 over any T6 in a N/A watercraft engine. You dont have a wet clutch like a motorcycle. You dont need the detergents in T6, as these engine never get sludged, and often have under 100 hours. You dont need the zero weight from the Penz, but it will do no harm, a watercraft engine gets no more moisture in the oil than the average car. Unless you regularly submerge it under water...I use Castrol 0W40 in my 155HP Seadoo and T6 in GTR because of the wet clutch supercharger
2000 VW Beetle 1.8T M5
2006 Pathfinder 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
Re: Jet Ski oil questions [Re: mrnkc130] #4718233 04/06/18 11:18 AM
T
terminaldegree Offline
T
It's a 1500cc engine. And it's a peach of a motor!
mrnkc130- is the oil filter impossible to see on your Ultra, like it is on my 15f? I haven't changed it myself (extended warranty concludes this August), but I'm pretty sure lotsa folks remove the center storage tray to reach it more easily...
'16 Mini Cooper S, 32k
'10 F150 4.6 3v, 120k
'13 Kawasaki STX-15f, 180 hr
'96 Sport Nautique 351 GT-40, 745 hr
Re: Jet Ski oil questions [Re: mrnkc130] #4721794 04/09/18 03:07 PM
P
paulswagelock Offline
P
Run the 0w40 without mixing it. I have had Kawasaki jetskis with the 1500 for many years and I run Mobil 0w40, PP 0w40, Mobil turbo truck 5w40, Castrol 5w40 - they all are fine. I run these hard and trade them in every 5 years and they purr like the day I bought them at the end.
'15 Subura Impreza Sport
'16 Mercedes C300 4 Matic
'19 Ram Laramie Crew cab Hemi
'12 Toyota Rav4
'14 Acura ILX
'15 VW Jetta
Re: Jet Ski oil questions [Re: mrnkc130] #4728930 04/16/18 02:10 PM
A
Arctic388 Offline
A
how many hours are on the Jet Ski?
2015 Sierra Z71
1999 Malibu
1996 Tahoe 4x4
2015 Seadoo GTI SE 155 Limited
2017 Seadoo GTI SE 130
1998 Yamaha XL760
1996 Seadoo GTX
2005 Yamaha Grizzly 660
https://www.youtube.com/user/Arctic388/videos
Re: Jet Ski oil questions [Re: mrnkc130] #4746494 05/03/18 09:20 AM
M
mrnkc130 Offline OP
M
Sorry i haven't logged in for a little while.
Yes the oil filter looks a little difficult to get to, I haven't changed it yet and I don't think i will on the first oil change. I'll probably try putting a plastic bag around it.
I just bought a place at the lake and i've been moving everything out there, I plan on changing the oil before taking it out for the first time this season. It only has 21 hours on it but its been in the sump since new which is well over a year now and i'd feel better changing it. I don't really run it all that hard and always make sure its been running for 5-8 min before going wide open on it or anything.
The maintenance procedure I'm most concerned about is lubing the bearings on the impeller, I haven't found anything online explaining how to do it and its already past the recommended time to do that....then again it doesn't stay in the water when not being used so it may not be as critical.
2017 Suburban LT
2016 Hyundai Accent
