93 registered (4WD, Astro14, 28oz, AlaskaMike, 11 invisible),
1864
Guests and
80
Spiders online. |
Key:
Admin,
Global Mod,
Mod
64856 Members
68 Forums
282387 Topics
#4712250 - 03/31/18 10:52 AM
Re: Double By-Pass Oil Filter?
[Re: BlueOvalFitter]
Loc: The Old North State
Technically speaking there is a normal anti-drain back valve with an anti-siphon valve. The anti-siphon is in the center tube and seen near the outlet hole.
Iirc, the Ford Zetec engine specs a filter with that set up. In addition to adbv, the anti-siphon valve apparently needed to help assure oil remains in the filter.
There is also a separate dome bypass which performs it's normal function.
Edited by Sayjac (03/31/18 11:03 AM) Edit Reason: added comment
#4712285 - 03/31/18 11:26 AM
Loc: Waco, TX
All it does (like the supertech ST8316) is keep the entire filter full of oil
"The evidence demands a verdict". (Re:VOA)"it's nearly impossible to actually know the particular additives that are in there at what concentrations."
#4712316 - 03/31/18 11:50 AM
[Re: Linctex]
Loc: Cajun Country, La.
All it does (like the supertech ST8316) is keep the entire filter full of oil Is this aimed at oil filters that are inverted, AKA-dome end facing up, or on an angle 90* or more?
2007 F150 XL, 4.2 V6, 4R75E Transmission Pennzoil Platinum Euro 0W40, WIX 51516 XP Oil Filter "One Filter, One OCI!"
#4712438 - 03/31/18 02:34 PM
Loc: Florida, Cape Coral
I like your questions and comments BlueOvalFitter. Some id10t is trolling you. Ed
CX5 Touring 2.5L :-)
#4712502 - 03/31/18 04:11 PM
Loc: Waco, TX
All it does (like the supertech ST8316) is keep the entire filter full of oil Is this aimed at oil filters that are inverted, AKA-dome end facing up, or on an angle 90* or more? That would be logical reasoning.... I think the ZETEC had them horizontal
#4712506 - 03/31/18 04:16 PM
[Re: Linctex]
Loc: ohio
Linctex,
I checked the Wix filter site and they list a 51315 filter. But it appears to just be a regular filter. Baldwin, Fram and Purolator do not cross reference to a ST 8316. I'm having trouble understanding how this filter works. Along with a regular anti drain back seal / valve and bypass valve, as found on most filters, is there another one way seal/valve inside the center tube that keeps the oil in the filter?
#4712512 - 03/31/18 04:26 PM
[Re: xtell]
.....I'm having trouble understanding how this filter works. Along with a regular anti drain back seal / valve and bypass valve, as found on most filters, is there another one way seal/valve inside the center tube that keeps the oil in the filter? Yes there is. It can be seen in slacktide bitog's linked TG 8316 c&p. https://bobistheoilguy.com/forums/ubbthreads.php/topics/3866309/Not_bad_for_a_cardboard_Fram!_ As for the OT trolling accusation, not sure who that would be in this thread as imo and observation seems all answers put forth in an honest attempt to answer the topic question.
#4712523 - 03/31/18 04:42 PM
Loc: PNW
Yep, just a low pressure check valve in the bottom of the center tube to prevent the filter from siphoning/draining out the base center hole. Think of it as the center tube ADBV.
Apparently some engines can drain the filter from both the filter inlet and outlet.
#4712606 - 03/31/18 06:26 PM
[Re: ZeeOSix]
Loc: Western S.C. since 1996
... Apparently some engines can drain the filter from both the filter inlet and outlet. Maybe so, but I don't see how, considering that healthy ADBVs seem to require a little pressure to open them even in the forward flow direction. Maybe if the filter is mounted high there'd be enough hydrostatic pressure difference to open the valve and allow oil to siphon out. ??
2011 Toyota Prius now at 87K 1981 Mazda GLC (323) retired at 606K 1972 Subaru DL retired at 190K 1954 Chevrolet retired at 121K
#4712613 - 03/31/18 06:34 PM
Loc: San Antonio, TX
A friend's Audi TGDI uses an oil filter with both ADBV & anti-siphon valve to minimize delay in oil supply for the turbo. The Fram model number is PH / XG 10600, Mobil 1 is M1-404. This particular filter mounts vertically dome end up on the top side of the engine. It has a dome end BPV.
Edited by Nyogtha (03/31/18 06:39 PM)
"He who does not value the teacher, Or greatly care for the material, Is greatly deluded although he may be learned." - Lao-Tzu
