1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
29 registered members (citationxeleven, Char Baby, BobGoblin, Bailes1992, billt460, Blkstanger, 1 invisible), 905 guests, and 36 spiders.
Topics296,903
Posts4,961,308
Members66,997
Most Online2,688
Jan 19th, 2019
Tire rotation front to back ok? #4712225
03/31/18 09:31 AM
03/31/18 09:31 AM
FL
Jake777 Offline OP
Jake777  Offline OP
FL
I have two FWD vehicles I’m maintaining. A Honda Odyssey and a Nissan Altima. I know the proper tire rotation pattern fronts to rear and rear across over to front but it’s so easy to just jack up left side right side and simply drop the front to back and back to front. Is this “good enough”. Does anyone else use this more simple method and has everything worked out fine? And I realize directional tires are done this way. So anyone with directional tires have any advice on how their tires hold up just going front to back.
2018 Honda Odyssey EXL
2015 Honda Accord
2008 Nissan Altima S
Re: Tire rotation front to back ok? [Re: Jake777] #4712234
03/31/18 09:40 AM
03/31/18 09:40 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I cross rotate to even out cupping on my tires. The only time I do straight front to back is on directional tires. Yes it's more time consuming but it gives me more even tire weat and longer life in addition to keeping tires quiet.
Luke
Re: Tire rotation front to back ok? [Re: Jake777] #4712235
03/31/18 09:40 AM
03/31/18 09:40 AM
WI
HoosierJeeper Offline
WI
I think so. That's what you'd have to do if you had directional tires. Better than not rotating at all.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Tire rotation front to back ok? [Re: Jake777] #4712239
03/31/18 09:41 AM
03/31/18 09:41 AM
FL
Jake777 Offline OP
Jake777  Offline OP
FL
I figured that bu I was hopeful someone would tell me they do front and back only and haven’t noticed anything strange. Oh well I guess you just have to cross them.
2015 Honda Accord
Re: Tire rotation front to back ok? [Re: Jake777] #4712240
03/31/18 09:43 AM
03/31/18 09:43 AM
Upstate NY
Wheel Offline
Wheel  Offline
Upstate NY
I would think it would be helpful, even if not ideal.
If you run directional tires, front to rear swap is all you can do without remounting the tire on the rim.
2009 Subaru Legacy (N/A)
Castrol Edge and Subie (Fram) filter
Re: Tire rotation front to back ok? [Re: Jake777] #4712252
03/31/18 09:53 AM
03/31/18 09:53 AM
A Warm place to live in
berniedd Offline
berniedd  Offline
I do front to back tire rotations on my FWD and RWD cars and haven't seen anything odd happen. Tires are not directional and they do wear out evenly.
Re: Tire rotation front to back ok? [Re: berniedd] #4712253
03/31/18 09:56 AM
03/31/18 09:56 AM
FL
Jake777 Offline OP
Jake777  Offline OP
FL
Originally Posted By: berniedd
I do front to back tire rotations and haven't seen anything odd happen. Tires are not directional and wear out evenly.
That’s what I’m talking about. Anyone else?
2015 Honda Accord
Re: Tire rotation front to back ok? [Re: Jake777] #4712255
03/31/18 09:57 AM
03/31/18 09:57 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
That's Toyota's recommendation for tire rotation for my 04 Camry. Tires seem to wear evenly using this method.
Re: Tire rotation front to back ok? [Re: Jake777] #4712258
03/31/18 10:00 AM
03/31/18 10:00 AM
DFW
DBMaster Offline
DBMaster  Offline
DFW
Front to back is all I've ever done - for multiple cars over the last 35 years.
Re: Tire rotation front to back ok? [Re: Jake777] #4712263
03/31/18 10:08 AM
03/31/18 10:08 AM
Missouri
David2431 Offline
David2431  Offline
Missouri
I have been doing front to back only for several sets of tires each on the following vehicles:
2001 Dodge Ram 2 wheel drive
2001 Jeep Grand Cherokee 4 WD
2006 Corolla
I've never seen or felt a problem.
Re: Tire rotation front to back ok? [Re: Jake777] #4712265
03/31/18 10:09 AM
03/31/18 10:09 AM
Alberta
carviewsonic Offline
Alberta
Front to back is all I do, and I get close to the full rating (kms or miles) from my tires. I get an alignment done right away if I notice anything like a slight pull or off center steering wheel, usually due to a pot hole or similar.
'18 Impala
'05 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Tire rotation front to back ok? [Re: Jake777] #4712274
03/31/18 10:18 AM
03/31/18 10:18 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
If all you were looking for was someone to agree with you so you could take the easy way out why would you ask? If you want to do just front to back do it. Does it work, sure, is it better than not rotating, absolutely. Is it as good as cross rotating at preventing or removing heel to toe feathering or tread edge cupping, absolutely not.
Luke
Re: Tire rotation front to back ok? [Re: DBMaster] #4712280
03/31/18 10:24 AM
03/31/18 10:24 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Same here, for over 40 years now. I recently pitched a set of OE tires that went over 60K miles doing that, not because they were worn out, because they were 10 years old and I wanted a new set for the winter.
God Bless Our Troops
Re: Tire rotation front to back ok? [Re: FlyNavyP3] #4712287
03/31/18 10:28 AM
03/31/18 10:28 AM
FL
Jake777 Offline OP
Jake777  Offline OP
FL
You seem a bit defensive about your using the proper method vs me wanting a more easy way. I was looking to see if other people had used the “easy way” and could attest to it doing “just fine” when you search online all formal responses are specifically listing the “proper” method. I respect you for doing it the exact way specified and you are the better for it I’m sure. Who knows by asking I might have heard responses like “I tired that and it didn’t work out well”. But so far I’m getting the feeling that after a few years of front to back things might just be “fine”.
2015 Honda Accord
Re: Tire rotation front to back ok? [Re: Jake777] #4712288
03/31/18 10:30 AM
03/31/18 10:30 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
On a front wheel drive only with directional tires, The rear tires don't care what direction they turn - they are just along for the ride, more or less. So - cross the fronts when rotating to the rear.
