Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
19 registered members (billt460, Aero540T, avi1777, cjolson140, 3 invisible), 542 guests, and 55 spiders.
Topics286,171
Posts4,903,552
Members67,572
Most Online2,967
Mar 10th, 2019
suitable oil grade for MT & rear diff #4712035
03/31/18 04:44 AM
03/31/18 04:44 AM
Wiltshire, UK
bonjo Offline OP
bonjo  Offline OP
Wiltshire, UK
I run a toyota RAV4.2 uk model manual, 2ltr petrol.
here is the oil spec
for the g/box (actually it is a transaxle as there is no center diff) GL-5 SAE 80w90
rear diff (which is not an LSD) API GL-5 SAW90
A couple of years back, the dealer changed the oil but used their approved brand (castrol??)
I have used mobil synthetic gear oil previously in 2 & 4 wheel drive cars with good results. What bugs me is I cannot source synthetic API GL-5 SAW90 and most GL-5's are 75w90
any ideas or suggestions?? ???
Re: suitable oil grade for MT & rear diff [Re: bonjo] #4712042
03/31/18 05:02 AM
03/31/18 05:02 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: suitable oil grade for MT & rear diff [Re: bonjo] #4712047
03/31/18 05:16 AM
03/31/18 05:16 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
From the days when I was working at Toyota dealer...back in 2007..
Rav4 didnt have problems with universal 75w90 gl4/5 MT-1 gearbox oil...only corola and auris needed GL4 oil othervise changing gears become notchy...
We were using rebranded Texaco multigear S 75w90... A.k.a Petrol multi gl 75w90...
Get a PDS online (Texaco has it) and find oil with similar characteristics.. Kv40 kv100 etc
Re: suitable oil grade for MT & rear diff [Re: bonjo] #4712052
03/31/18 05:38 AM
03/31/18 05:38 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Re: suitable oil grade for MT & rear diff [Re: bonjo] #4715781
04/04/18 06:49 AM
04/04/18 06:49 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
I know of no fully synthetics in SAE 90 viscosity grade gear oils, though States do have fully synthetics 80W90 (not sure if it's GL4 or GL5).
Sourcing for a fully synthetics in SAE 90 GL5 is akin to one sourcing for mineral oils in say, 0W40 0W30 engine oils.
In my tropical ambients, OEM recommendations of GL5's in 80W90 and SAE 90 viscosity grades is akin to recommending mineral oils specifically ......
and that seems to apply in UK, IMHO.
Edit:
A SAE 90 grade has a [email protected]*C ranging from 135 cSt to 224 cSt pre-2000.
A fully synthetic 75W140 typically has a [email protected]*C of 170 cSt, and could be an alternative in your case.
Re: suitable oil grade for MT & rear diff [Re: bonjo] #4726265
04/13/18 09:28 PM
04/13/18 09:28 PM
Florida
artificialist Offline
Florida
Whenever I worked on a Toyota that called for SAE90 in the rear axle, the repair shops I worked for simply used conventional 80w90 or synthetic 75w90 and it was never a problem.
Wouldn't the transaxle have a PTO that takes power from the transaxle to the rear driveshaft? That would be another part that needs oil, and usually Toyota calls for 80w90 or SAE90 gear oil. You could use 75w90 synthetic if you want to.
2010 Lancer Ralliart Sportback
Re: suitable oil grade for MT & rear diff [Re: zeng] #4726344
04/13/18 11:27 PM
04/13/18 11:27 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Originally Posted By: zeng
Edit:
Amendments,the bold should read as:
"A SAE 90 grade has a [email protected]*C ranging from 135 cSt to 320 cSt pre-2000."
