Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
33 registered members (Bailes1992, BrianF, Atesz792, bmod305, Brad_C, alcyon, 2 invisible), 692 guests, and 61 spiders.
Topics286,442
Posts4,908,226
Members67,622
Most Online2,967
Mar 10th, 2019
Rear bearing noise or tire noise? #4711598
03/30/18 02:14 PM
03/30/18 02:14 PM
Ozark Mountains
callbay Offline OP
callbay  Offline OP
Ozark Mountains
How can one tell the difference?
It's a 2011 Ford Fusion front wheel drive with 101,000 miles on it. I have checked the tires visually and no damage.
The noise is on smooth roads and can't be heard on rough ones.
Thanks!
Re: Rear bearing noise or tire noise? [Re: callbay] #4711604
03/30/18 02:17 PM
03/30/18 02:17 PM
WI
HoosierJeeper Offline
WI
Swap the front/rear tires maybe...if the front ones seem quiet.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Rear bearing noise or tire noise? [Re: callbay] #4711632
03/30/18 03:02 PM
03/30/18 03:02 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Cross rotate them. The edge of the tread is sharper on one side. When you X rotate the tires, you flip the sharp edges around and it usually hushes down the tires for awhile. I had an older neighbor when I lived in the city which I maintained his Chevy Colorado. He complained of tire noise, I cross rotated them and he was happy as it did the trick.
Me: 13' VW GTI 3 door 6 speed manual
Re: Rear bearing noise or tire noise? [Re: callbay] #4711648
03/30/18 03:24 PM
03/30/18 03:24 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Almost every one runs radials now a days . Years ago I heard x rotating the radials would cause the tread to seperate .. Truth or myth ?
Thanks , :-)
Wyr
God bless
Re: Rear bearing noise or tire noise? [Re: callbay] #4711658
03/30/18 03:34 PM
03/30/18 03:34 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Thanks , :-)
Wyr
God bless
Re: Rear bearing noise or tire noise? [Re: callbay] #4711746
03/30/18 05:20 PM
03/30/18 05:20 PM
PA
d00df00d Offline
d00df00d  Offline
PA
Thanks!
If it's a wheel bearing noise, it'll typically get louder or quieter in a turn (unless both bearings on the same axle are comparably worn).
E.g., if a wheel bearing on the right is worn, it'll make more noise in left turns (when there's more load on the right side) and less noise in right turns (when there's less load on the right side). And vice versa.
2008 BMW M3 Sedan 6MT
Re: Rear bearing noise or tire noise? [Re: callbay] #4711764
03/30/18 05:54 PM
03/30/18 05:54 PM
The land of USA-made Subies!
SubieRubyRoo Online happy
SubieRubyRoo  Online Happy
on my 2011 Fusion FWD, it was neither of these issues. It was the fact that the brake pads had not worn equally, and the inside pad had ground grooves into the rotor, but you couldn't hear any grinding. On the highway at about 75-80, it would show up as a hum/ringing noise like a bad rear wheel bearing. Replaced pads and rotors and never heard the noise again.
Re: Rear bearing noise or tire noise? [Re: callbay] #4711771
03/30/18 06:12 PM
03/30/18 06:12 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
If you still cant tell after rotating tires remove the rear wheels and lift the calipers off then rotate the hub by had, feel for any roughness and listen for noises. If either replace the hub unit, if not check for brake noise with the caliper in place and check the backing plate for contact.
This is from SKF and less than half the price of OE, do both on the same axle.
https://www.rockauto.com/en/moreinfo.php?pk=1842498&cc=3015243&jsn=493&jsn=493
Re: Rear bearing noise or tire noise? [Re: callbay] #4711798
03/30/18 07:05 PM
03/30/18 07:05 PM
northern NY
Driz Offline
Driz  Offline
northern NY
Run down the road over 40 mph. Do the drunken swerve back and forth repeatedly. If itís a wheel bearing it will groan growl or whatever a little when you sidebload the bearing like that. Not very scientific but it has always worked for me.
Re: Rear bearing noise or tire noise? [Re: Driz] #4711913
03/30/18 09:42 PM
03/30/18 09:42 PM
Canada
mcwilly Offline
mcwilly  Offline
Canada
Yes that is how my front bearing was, going down a winding road it was off and on.
2010 Subaru Sti 74,000km
2001 Toyota Echo 245,000km
Re: Rear bearing noise or tire noise? [Re: callbay] #4711950
03/30/18 10:49 PM
03/30/18 10:49 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Sounds like a tire issue.
Re: Rear bearing noise or tire noise? [Re: callbay] #4715660
04/03/18 11:21 PM
04/03/18 11:21 PM
texas
joel95ex Offline
joel95ex  Offline
texas
i never had rear bearings go bad but i had a civic with bad front bearings and the noise sounded like an airplane propeller --seriously-like the movie airplane and it kept getting louder--plus there was a bunch of dust similar to brake dust. like other said, jack it up and spin the wheel.
95 Accord 4cyl Vtec. 500,000+miles. RIP 😢
2013 sonata 117k miles
PP, QSUD,10w-30 fram ultra filter
07 civic SI 132k miles PP, M1 10w-30 fram ultra
