The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
What's in Maxima oil?
by Truckedup. 03/23/19 06:29 PM
2015 Acura TLX 3.5L V6
by blackdiamond. 03/23/19 06:20 PM
Group 3 oil with best heat stability?
by LSXHitman. 03/23/19 05:24 PM
FixItDad28, RandomJoe, Sciascia, sosp197, peppercorn
67597 Registered Users
24 registered members (chevrofreak, Dave9, carlprop, Char Baby, Black_Thunder, 2 invisible), 618 guests, and 64 spiders.
Topics286,320
Posts4,906,414
Members67,597
Most Online2,967
Mar 10th, 2019
M1-113A bypass valve PSI? #4711540
03/30/18 01:13 PM
03/30/18 01:13 PM
PA
JAYNO20Z24 Offline OP
PA
Can anyone confirm what the PSI for the bypass valve on a M1-113A filter is? I know there are a few reports that the M1-113 filter was 15-17 PSI but I read one person stating it was bumped to 22 for the 113A and just want to know if anyone can confirm.
Re: M1-113A bypass valve PSI? [Re: JAYNO20Z24] #4711554
03/30/18 01:31 PM
03/30/18 01:31 PM
Texas
4WD Offline
4WD  Offline
Texas
Good luck I tried for the M1 M1-212 and nothing
Re: M1-113A bypass valve PSI? [Re: 4WD] #4711587
03/30/18 02:03 PM
03/30/18 02:03 PM
PA
PA
I figured as much. Kind of grasping at straws here. I need a 22psi bypass valve but I am hesitant to use the PF64 filter due to possible failures.
Re: M1-113A bypass valve PSI? [Re: JAYNO20Z24] #4711614
03/30/18 02:39 PM
03/30/18 02:39 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
Buy one tear it open and comparo the bypass spring to one from a filter with the bypass value you're after. It is just a spring and its strength can be measured.
Re: M1-113A bypass valve PSI? [Re: JAYNO20Z24] #4711745
03/30/18 05:20 PM
03/30/18 05:20 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
https://mobiloil.com/en/oil-filters/performance-oil-filters
By this I would probably say no, not 22 bypass. More like the pf48.
Re: M1-113A bypass valve PSI? [Re: JAYNO20Z24] #4711911
03/30/18 09:41 PM
03/30/18 09:41 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I do NOT think that you NEED a 22 psi bypass
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4710962/PF63E_filters
Re: M1-113A bypass valve PSI? [Re: Linctex] #4711991
03/31/18 12:24 AM
03/31/18 12:24 AM
PA
PA
Re: M1-113A bypass valve PSI? [Re: JAYNO20Z24] #4712001
03/31/18 12:54 AM
03/31/18 12:54 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Did you try calling Mobil Tech Line?
Re: M1-113A bypass valve PSI? [Re: ZeeOSix] #4712864
04/01/18 01:49 AM
04/01/18 01:49 AM
PA
PA
I sent them an email but I may give them a call on Monday.
