New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
107 registered members (addyguy, 2004tdigls, arowbat, 2002 Maxima SE, Astro14, 11 invisible), 2,191 guests, and 65 spiders.
Topics286,350
Posts4,906,901
Members67,608
Most Online2,967
Mar 10th, 2019
Pennzoil Plat Hi-Mile Synth 5W-30, 07 4Runner #4711514
03/30/18 12:36 PM
03/30/18 12:36 PM
NJ
crainholio Offline OP
NJ
2nd sample from my '07 4Runner 1GR-FE 4.0L V6 with 179K miles, getting ready to replace the stretched timing chain and related components this Summer. It had a horrible oil change history under the original owner, with OCIs in the 20-25K mile average range and some past 30K miles. One tough engine and hopefully the internals are de-sludging nicely...we'll find out when we open it up to do the chains/sprockets/rails/tensioners.
The PZ jug has no Dexos markings, which accounts for the usual 2,000ppm Ca rather than the reduced quantity found in D1G2 versions. No LubeGard Bio added this fill, so the Moly # is what was in the PP and whatever little remained from the prior fill w/ AZO and 15oz LubeGard.
Re: Pennzoil Plat Hi-Mile Synth 5W-30, 07 4Runner [Re: crainholio] #4711517
03/30/18 12:38 PM
03/30/18 12:38 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Can't see anything on your report, even the blown-up image is like 0.5 font size.
Re: Pennzoil Plat Hi-Mile Synth 5W-30, 07 4Runner [Re: crainholio] #4711537
03/30/18 01:07 PM
03/30/18 01:07 PM
NJ
NJ
Working on a 13" screen here...let's try blowing up the numeric section a bit.
Re: Pennzoil Plat Hi-Mile Synth 5W-30, 07 4Runner [Re: crainholio] #4711545
03/30/18 01:20 PM
03/30/18 01:20 PM
Much better. Looks like the PPHM actually outperformed the AZO fairly handily! I'm sure at a much nicer price as well!
Re: Pennzoil Plat Hi-Mile Synth 5W-30, 07 4Runner [Re: crainholio] #4711550
03/30/18 01:25 PM
03/30/18 01:25 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
As far as wear metals are concerned nothing unusual. Go to regular OCI's with plain PCMO of your choice.
don't use.
Re: Pennzoil Plat Hi-Mile Synth 5W-30, 07 4Runner [Re: crainholio] #4711717
03/30/18 04:43 PM
03/30/18 04:43 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
How did you determine the chain is stretched?
1997 Maxima 197k, Castrol GTX Synblend 5W-30, FL400S
2004 Corolla 197k, VWB + SSS + Rislone cocktail, MGL51516
Re: Pennzoil Plat Hi-Mile Synth 5W-30, 07 4Runner [Re: crainholio] #4711826
03/30/18 07:55 PM
03/30/18 07:55 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Amzoil SS run for 3K miles? WOW!.
If the point was to clean out the inside, go with a know good cleaning oil that is cheap. Be careful cleaning an older engine like that because the sludge may be stopping the leaks. If you pour in some magic cleaner and dissolve all the sludge you might have seals leaking everywhere.
The engine doesn't need to be squeaky clean to run for 200+k miles. Just not plugged up enough to block oil passages.
Any Walmart name brand oil will do.
Re: Pennzoil Plat Hi-Mile Synth 5W-30, 07 4Runner [Re: SubieRubyRoo] #4711830
03/30/18 07:58 PM
03/30/18 07:58 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
That's what I thought as well, another low metal wear count from Pennzoil. cheers
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Pennzoil Plat Hi-Mile Synth 5W-30, 07 4Runner [Re: zorobabel] #4712582
03/31/18 05:56 PM
03/31/18 05:56 PM
NJ
NJ
I determined the chain was stretched while troubleshooting a recurring P0016 error code, finding approximately 6-8 degrees of retard at the #1 intake cam when the crank was at TDC zero mark. Also found the #1 chain tensioner over-extended as shown in the pic below.
Re: Pennzoil Plat Hi-Mile Synth 5W-30, 07 4Runner [Re: danez_yoda] #4712590
03/31/18 06:04 PM
03/31/18 06:04 PM
NJ
NJ
Agreed, the AZO had been on my shelf since 2013 timeframe and there's no other vehicle in my fleet I wanted to use it in...seemed like a great option for Winter. It was jet-black and with visible flecks of sludge on the dipstick when I decided to change it early.
Also agreed on engine flush "magic cleaner" and I avoid these. Just high-calcium Pennzoil/Quaker with lots of moly on board and shortened OCIs.
Re: Pennzoil Plat Hi-Mile Synth 5W-30, 07 4Runner [Re: crainholio] #4714308
04/02/18 04:42 PM
04/02/18 04:42 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
Thanks for clearing that up!
