Originally Posted By: road_rascal
This is the first brand new off the showroom floor vehicle I've bought since 1995. Reading the owners manual it says that Dexos1 0W20 is recommended for this engine and the sump is 4.2 quarts (this is the FWD version). So, when should I change out the factory fill and what's a good oil to use? Manual says use an AC Delco PF64 filter (which are easy to find). Thanks!
Originally Posted By: Danno
If it was my car, I would replace the factory fill at 1,500 miles, replace again at 5,000 miles, and stay on a 5,000 mile interval after that.
Any 0W-20 Dexos1 ver2 oil will be fine for the oil change, and yes, I would use OEM oil filters.
Why the push for D1G2 oil when the manual/manu recommends just Dexos-1 oil? Personally, I think this D1G2 thing is way overrated. Nothing wrong with D-1 oil and since it is recommended in a 2018 vehicle, that's what I would run and not give D1G2 oil a second thought.
